Interpreting the Constant c in a Savings Account Differential Equation
  • Thread starter David Donald
  • Tags
    Constants
In summary, the constant c in the equation y=W/k+ce^(kt) is what allows you to fit the solution to the boundary conditions in the actual problem. If the signs of the terms in the equation are changed, the solution might look different.
David Donald
31
Mentor note: moved to homework section
Hello! so I'm working on a homework problem where I need to
solve the diff equation dy/dt = ky - W
where Y is the amount of money in a savings account
W is a constant
k is another constant (growing at a percentage)
solving the diff equation
I got y = W(1/k) + ((c)/(e^-kx))
now my question is how do i interpret the constant c? what does the constant c mean?
David Donald said:
(e^-kx)
That should be ##t##.
##c## can be determined by the knowledge about the amount of the saving at a particular time.
"y" is "amount of money" in the account. It has units of, say, "dollars". "dy/dt" is the rate at which money goes into or out of the account. It has units of, say, "dollars per day". In order to have dy/dt= ky+ W, W must have units of "dollars per day" and k must have units of "per day" or "1/day".
Then, in y= W/k+ ce^(kt) (You have "c/e^(-kx)". Obviously, your "x" should be "t" and 1/e^(-kt) = e^(kt).)
Since k has units of "per day" and W "dollars per day", W/k has units of "dollars" as does y. Also t, the time, has units of "day" kt is "dimensionless" and e^(kt) also has no dimensions. That means that c must have dimensions of "dollars". Further, taking t= 0, we have y(0)= W/k+ c. c= y(0)- W/k. c is the amount of money in the account, initially, minus W/k. You don't say what "W" and "k" mean so I can't say what y(0)- W/k means.
It is easy enough to interpret [itex]k[/itex] as a (compound) interest rate and [itex]W[/itex] as a constant rate at which funds are withdrawn from the account.
Arbitrary constants of integration (such as [itex]c[/itex]) often don't have any good interpretation in terms of the application. However, their values are completely forced by requirements which come from the application. Here, for example, you might be interested in what the initial balance must be if the balance of the account is to be zero at some fixed time, or you might be interested in whether the balance will ever become zero given a specific initial balance.
W is an amount that is getting withdrawed each year
and K is a percentage based growth
As pasmith wrote, the constant is what allows you to fit the solution to the boundary conditions in the actual problem.
But check the signs in your solution. If you substitute it back into the differential equation does it look right?
1. What are constants in science?
Constants in science refer to physical quantities that remain unchanged throughout an experiment. They are typically represented by symbols and are used to describe the fundamental properties of the natural world.
2. Why are constants important in science?
Constants are important in science because they provide a standardized way of measuring and understanding the physical world. They allow for accurate and reproducible experiments, and help to establish the laws and principles of science.
3. How are constants determined?
Constants are determined through careful experimentation and observation. Scientists conduct multiple experiments and collect data to determine the numerical value of a constant. These values are then refined and confirmed through further experiments and peer review.
4. Do constants ever change?
In general, constants do not change. However, advances in technology and new discoveries may occasionally lead to updates or revisions of constants. These changes are carefully reviewed and documented by the scientific community.
5. What is the significance of the speed of light as a constant?
The speed of light, denoted by the symbol c, is a fundamental constant in physics. It is the maximum speed at which energy, information, or matter can travel in the universe. This constant plays a crucial role in many theories and equations, and is used to define the basic units of length and time in the International System of Units (SI).
