Intersection of two subspaces
  • Thread starter mccoy1
mccoy1
117
I'm given two subspaces L and K of P2 (R) are given by
L = { f(x) : 19f(0)+f ' (0) = 0 }
K = { f(x) : f(1) = 0 }.
Obtain a non-trivial quadratic n = ax2 + b x +c such that n is element of the intersetion of L and K.
19f(0) =19[a(0)^2+b(0)+c] = 19c
df/dx = 2ax+b...so f'(0) = b. therefore L= {19c+b = 0}.
K = {a+b+c = 0}
let X be an element of both L and K and equate the two equations: So r(19c+b) = s(a+b+c), for r, s reak numbers. 19cr+br =as+bs+cs. c(19r-s)-bs+a(r-s) = 0. I'm stuk from there.. Any help would be appreciated.
Thank you.
Answers and Replies
spamiam
360
Have you learned Gaussian elimination yet? If so, try using it to solve the system of equations
a + b + c = 0
b+19c=0​
You should have one free variable.
HallsofIvy
43,021
970
K = {a+b+c = 0}
Yes, those are your two equations.
Thank you.
Where in the world did r and s come from? Since both 19c+ b and a+ b+ c are equal to 0, they are equal to each other. But writing only 19c+ b= a+ b+ c loses the information that they are, individually, equal to 0.
I recommend writing both a and b in terms of c so that you can write \(\displaystyle ax^2+ bx+ c\) entirely in terms of c. Since you are only asked to find a non-trivial quadratic, choose c to be any non-zero number.
mccoy1
117
Check post below...thanks
mccoy1
117
Where in the world did r and s come from? Since both 19c+ b and a+ b+ c are equal to 0, they are equal to each other. But writing only 19c+ b= a+ b+ c loses the information that they are, individually, equa; to 0.
HallsofIvy, thanks for pointing that out. I was desperate to use some constants lol. Now, let me see if I can solve it (I'll post the ans shortly). meanwhle, can you please check the solution abve.Cheers
mccoy1
117
Okay, c=-ax^2-bx.......(I)
But form a+b+c =0 and 19c+b=0, a = 18c and b = -19c. Substituting them into (I) gives:
c =-(18c)x^2-(-19c)x . So 1=-18x^2+19x. Hence g(x) = -18x^2+19x-1. Is that correct? I'm not thinking clearly at the moment....thanks guys.
mccoy1
117
I think I still need help..I have a feeling that my soln above was wrong. How about this:
a+b+c =0, so a = -b-c and -19c = b ..
So intersection = [-b-c, -19c, c] = [-b,0,0) +c[-1, -19, 1]. How would I continue from there? Cheers.
Oh wait, b =-19c, so c[19,0,0]+c[1,-19,1] = intersection. So when c = 1, the equation of the intersection would be 18x^2-19x+1...signs were incorrect..
Thanks guys.
spamiam
360
Why do you think your original answer is wrong? Doesn't it satisfy both of the equations?
HallsofIvy
43,021
970
You originally got [/itex]g(x) = -18x^2+19x-1[/itex] but changed to [itex]18x^2-19x+1[/quote] which is just the negative of the other. For any vector space, if v is in the space then so is -v.
mccoy1
117
I was just intamidated by the difference in sign. Yes it satifies both equation..I have just checked.
which is just the negative of the other. For any vector space, if v is in the space then so is -v.[/QUOTE]
Absolutely..
Thanks guys for your great help. It's appreciated:).
Suggested for: Intersection of two subspaces
  • Last Post
  • Last Post
