Where Do the Diagonals of a Parallelogram Intersect?
In summary, in a parallelogram $ABCD$ with known vertices $A=(0,0)$ and $B=(1,0)$, the position of $D$ can be found in terms of $C=(x,y)$ as $D=(x+1,y)$. The diagonals of the parallelogram intersect at point $M$ which can be found using the connection between the coordinates of points and vectors. This is known as a theorem. The order of vertices in a quadrangle or polygon is usually denoted by $XYZW$ if visited in counterclockwise or clockwise order. The position of $M$ can also be found as $M=\left( \frac{x}{2}, \frac
evinda
MHB
3,836
Hello! (Wave)
Suppose that a parallelogram $ABCD$ has vertices $A=(0,0)$ and $B=(1,0)$. In terms of $C=(x,y)$, find the position of $D$ and where the two diagonals will intersect.
Then we will have something like that:
View attachment 5378How can we find the coordinates of $M$, i.e. the point at which the two diagonals intersect?
Mathematics news on Phys.org
Note that $\overrightarrow{AC}+\overrightarrow{AB}=\overrightarrow{AD}=2\overrightarrow{AM}$. You should use the connection between the coordinates of points and the coordinates of vectors, as well as rules for operations on vectors in terms of coordinates.
Does it hold that $\vec{AD}=2\vec{AM}$ from the fact that each diagonal of a parallelogram separates it into two equal triangles?I found that $D=(x \pm 1, y)$.
Let $M=(\mu_1, \mu_2)$.
So we have $\vec{AD}=(x \pm 1, y)$ and $\vec{AM}=(\mu_1, \mu_2)$.
So $\vec{AD}=2\vec{AM} \Rightarrow x \pm 1= 2 \mu_1 \text{ and } y=2 \mu_2 \Rightarrow \mu_1=\frac{x \pm 1}{2} \text{ and } \mu_2=\frac{y}{2}$
Thus $M=\left( \frac{x \pm 1}{2}, \frac{y}{2} \right)$. Right?
Yes, but it's easier to refer to the known fact that diagonals in a parallelogram are divided in half by the intersection point.
It should be $D=(x + 1, y)$ because the $x$-coordinate of $B$ is $1$, not $-1$. The rest is correct.
Is this known as a theorem?
Couldn't we have D=(x-1,y) if we put D at the position I put C at the graph that I have drawn and C at the position of D?
Or am I wrong?
Yes.
You are right, it depends on the order of vertices. In fact, calling a quadrangle (and, more generally, a polygon) $XYZW$ usually means that the order of vertices is $X,Y,Z,W$ if they are visited in the counterclockwise or clockwise order. Using this rule, the parallelogram in post #1 should be called $ABDC$.
Yes.
Ah, I see... (Nod)
So $X$ has to be connected with $Y$, $Y$ with $Z$, $Z$ with $W$ and $W$ with $X$, right?
I considered the parallelogram ABCD and then I got that $\vec{AC}=2 \vec{AM} \Rightarrow (x,y)=(2 \mu_1, 2 \mu_2)
\Rightarrow \mu_1=\frac{x}{2}$ and $\mu_2=\frac{y}{2}$.
So $M=\left( \frac{x}{2}, \frac{y}{2} \right)$, right?
That's how it is usually done.
Correct.
Great... Thanks a lot! (Smirk)
1. What is an intersection point?
An intersection point is a point where two or more lines, curves, or surfaces intersect or cross each other.
2. How is an intersection point calculated?
An intersection point is calculated by finding the values of the variables that satisfy the equations of the lines, curves, or surfaces that are intersecting.
3. Can an intersection point exist for more than two lines or curves?
Yes, an intersection point can exist for any number of lines or curves, as long as they intersect at a single point.
4. What does an intersection point represent in graphical representations?
An intersection point in graphical representations represents the point where two or more lines, curves, or surfaces cross or touch each other.
5. How are intersection points used in real-life applications?
Intersection points are used in various fields such as mathematics, engineering, and physics to solve problems and analyze data. They are also used in computer graphics to create realistic images and animations.
  • General Math
  • General Math
  • General Math
