Homework Help: Into Physics Momentum
  1. Jul 13, 2015 #1
    A 15,000 kg loader traveling east at 20 km/h turns south and travels at 25 km/h. Calculate the change in the loader’s
    a. kinetic energy.
    b. linear momentum.
    2. Relevant equations
    KE=(1/2)mv^2
    p=mv
    p(i)=p(f) : I am assuming I can ignore gravity
    3. The attempt at a solution
    I know there is already a thread for this problem but I am having trouble understanding how to describe the change in linear momentum,
    I feel okay with part a:
    a) 20km/hr = 5.56m/s
    25km/hr=6.94 m/s
    KE2-KE1
    1/2mv2^2 - 1/2mv1^2
    1/2 (15000)(6.94)^2 - 1/2(15000)(5.56)^2
    361227-231852
    129375J
    But for part b I am confused as to what to quantify as the change in linear momentum. So far I have:
    b)
    p(east) = mva
    (15000kg)(5.56m/s)
    83400 kg*m/s
    p(south) = mvb
    (15000kg)(6.94m/s)
    104100 kg*m/s
    And then I used pythagorean and inverse tan to find a resultant momentum of 1.3 * 10^5 with an angle of 51 degrees south of east.
    Is this my final answer? Do I need to subtract this from the initial momentum in the easterly direction? Why or why not?
    Any help is appreciated, thanks!!!
  3. Jul 13, 2015 #2
    pi is not equal to pf.
    You have the external forces of the wheels and the road.
    You need to compute the initial and final momentum vectors and subtract them (as vectors).
  4. Jul 13, 2015 #3
    Dr. Courtney, thanks for your answer. I'm not sure I understand where to begin following your suggestions
  5. Jul 13, 2015 #4
    SammyS
    Staff Emeritus
    Hello cassie123. Welcome to PF!
    It appears that you're adding the two momentum vectors. To find the change, you should subtract. Right?
  6. Jul 13, 2015 #5
    Thanks SammyS!
    Yes, that makes more sense that I should subtract.
    Can I just subtract the south momentum from the east or does the directionality mess that up? Or I think I could also use the change in velocity multiplied by mass. I am getting confused thinking about whether I need to resolve vectors, since they are already on the coordinate plane. And to me it makes sense that the change in direction would be 90 degrees from east to south but I'm having a hard time knowing how to handle this!
  7. Jul 14, 2015 #6
    SammyS
    Staff Emeritus
    If you want to find how much something has changed, you take the final value and subtract the initial value from that. In other words, subtract the initial (east) from the final (south).
  8. Jul 14, 2015 #7
    Maybe I'm overcomplicating it. Thanks again!
Have something to add?
Draft saved Draft deleted
