Invariant Mass in Gravitational Fields: Special Relativity
In summary, the conversation discusses the concept of invariant mass in special relativity and how it is calculated using the difference between energy squared and momentum squared. It also explores the idea of invariant mass in different metrics and how it is not affected by gravitational fields. The conversation then delves into a specific example using the Schwartzchild metric and how it can lead to unphysical results if not considered properly. The concept of coordinate speed is also discussed and it is emphasized that it has no physical meaning. Finally, the conversation ends with a discussion on how to compute the velocity, momentum, and energy of a photon in a given coordinate system.
DuckAmuck
236
40
TL;DR Summary
What happens to invariant mass of an object when it gets closer or further from a gravitational body?
In Special Relativity, you learn that invariant mass is computed by taking the difference between energy squared and momentum squared. (For simplicity, I'm saying c = 1).
[tex] m^2 = E^2 - \vec{p}^2 [/tex]
This can also be written with the Minkowski metric as:
[tex] m^2 = \eta_{\mu\nu} p^\mu p^\nu [/tex]
More generally, if there is a different metric (for example Schwartzchild), you would write it as:
[tex] m^2 = g_{\mu\nu} p^\mu p^\nu [/tex]
Now the question is, if invariant mass does not change from one metric to the other, you get the equation:
[tex] 0 = (g_{\mu\nu} - \eta_{\mu\nu})p^\mu p^\nu [/tex]
This seems to give unphysical results.
I solved for a photon in the Schwartzchild metric, and the only physical solution available is if the Schwartzchild radius is 0. So this seems to imply that invariant mass (or lack thereof) is not invariant under gravitational fields.
Any help here would be much appreciated. Thank you.
No you do not. The Minkowski metric has nothing to do with the manifold you are now considering. The invariant mass does not depend on the coordinate system you choose and you can, in a single point, always find a coordinate system so that the metric takes the form of the Minkowski metric. However, as you transform your expression to that coordinate system, the components of the 4-momentum will also change.
Short answer: nothing. An object's invariant mass is an invariant property of the body.
Note that the inner product of a particle's four-velocity with itself is always ##1##:
##g_{\mu\nu}u^\mu u^\nu = 1##
Therefore, the inner product of a particle's four-momentum with itself is always ##m^2##.
If, as you move through spacetime, the components of the metric change then the components of your four-velocity and four-momentum change to preserve these invariant quantities.
Likes vanhees71
OP is using a timelike metric convention. Let’s stick to that in order to reduce confusion.
0=(gμν−ημν)pμpν0=(gμν−ημν)pμpν​
That equation doesn't make any sense. If the components of p are given in local Minkowski coordinates then you use ##\eta##, if the components of p are given in some other coordinates then you use g. You cannot contract vector components given in one coordinate system with the metric components given in another coordinate system. That is indeed unphysical!
Likes vanhees71
I see now. So it should be written:
[tex] 0 = g_{\mu\nu}p^\mu p^\nu - \eta_{\mu\nu} p'^\mu p'^\nu [/tex]
Likes vanhees71 and Dale
Thanks for clarifying this. It was what I was thinking but did the math wrong.
Yes, and that equation will hold.
Likes vanhees71 and PeroK
Some follow-up questions. If there's a photo traveling toward the center of a gravitational body, we have:
[tex] m^2 = 0 = g_{\mu\nu} p^\mu p^\nu [/tex]
If we simplify by saying motion is along the x-axis:
[tex] g_{00} E^2 + g_{11} p^2 = 0 [/tex]
Plug in the Schwartzchild metric, and we get
[tex] \frac{\left(1 - \frac{r_s}{4R}\right)^2}{\left(1 +\frac{r_s}{4R}\right)^4} = \frac{p^2}{E^2}[/tex]
This seems to imply light slowing down to be subluminal in a gravitational field?
[tex] v = \left|\frac{p}{E}\right| = \frac{1 - \frac{r_s}{4R}}{\left(1 + \frac{r_s}{4R}\right)^2} \leq 1[/tex]
If you were to try to indirectly measure the mass of the photon here by measuring energy and momentum, you would get a non-zero mass?
[tex] m_{\text{fake}}^2 = E^2 \left( 1 - \frac{\left(1 - \frac{r_s}{4R}\right)^2}{\left(1 +\frac{r_s}{4R}\right)^4} \right) [/tex]
No, it just illustrates that coordinate speed has no physical meaning.
Evaluating coordinate components ##E## and ##p## of the 4-momentum is not "measuring energy and momentum". Try computing the measured energy and momentum of a photon according to an observer hovering at rest at the same value of ##R##. You will find that ##E = p## (and if you compute the measured speed of that photon according to that observer, you will find that it is ##1##).
Likes vanhees71, Dale and PeroK
PeterDonis said:
No, it just illustrates that coordinate speed has no physical meaning.Evaluating coordinate components ##E## and ##p## of the 4-momentum is not "measuring energy and momentum". Try computing the measured energy and momentum of a photon according to an observer hovering at rest at the same value of ##R##. You will find that ##E = p## (and if you compute the measured speed of that photon according to that observer, you will find that it is ##1##).
Ok. What is it I am computing? How do I compute the velocity, momentum and energy of the photon in this scenario?
You need to express those quantities as invariants and then compute them. For example, the energy of a photon as observed by an observer is given by ##E = V \cdot P##, where ##V## is the observer's 4-velocity (normalised to 1) and ##P## is the 4-momentum of the photon.
You started an "A" level thread on this topic; anyone with the appropriate background knowledge for an "A" level thread should already know the answer to this. Every GR textbook I've read assigns exercises like this as homework problems.
What background do you have in GR?
None. I took a class that covered SR. That's why I am asking here.
Then this thread should not be an "A" level thread, since you don't have the requisite background. Changing thread level to "I".
I would also recommend taking some time to work through the basics of GR. Sean Carroll's online lecture notes give a decent introduction:
https://arxiv.org/abs/gr-qc/9712019
Likes vanhees71
Coordinate velocity. Or something like that. Note that ##p^0\neq E## (assuming ##E## is the energy measured by an observer at rest with respect to the coordinate system) in general, which may be confusing you.
1. What is invariant mass in gravitational fields?
Invariant mass in gravitational fields refers to the mass of an object that remains constant regardless of its velocity or the gravitational field it is in. It is a concept in special relativity that takes into account the effects of gravity on an object's mass.
2. How is invariant mass different from rest mass?
Rest mass is the mass of an object when it is at rest, while invariant mass takes into account the effects of gravity on an object's mass. In other words, invariant mass is the total mass of an object, including its rest mass and the additional mass gained due to its velocity and the gravitational field it is in.
3. How does special relativity explain invariant mass in gravitational fields?
Special relativity explains invariant mass in gravitational fields through the famous equation E=mc², which states that an object's energy (E) is equal to its mass (m) multiplied by the speed of light squared (c²). This equation shows that an object's mass increases as its velocity increases, and this increase is further amplified by the effects of gravity.
4. Can an object's invariant mass ever change?
No, an object's invariant mass remains constant regardless of its velocity or the gravitational field it is in. This is a fundamental principle of special relativity.
5. How does the concept of invariant mass affect our understanding of gravity?
The concept of invariant mass in gravitational fields helps us understand that gravity is not just a force between two objects, but it also affects the mass of those objects. This is why objects with larger masses have a stronger gravitational pull. It also helps us understand the relationship between mass, energy, and gravity, as described by Einstein's theory of general relativity.
