Coco12
- 272
I know potential has an inverse relationship with distance. However what is the equation that deduces this?
Coco12 said:I know potential has an inverse relationship with distance. However what is the equation that deduces this?
Coco12 said:The question just asks that if a potential is 10 cm from a pt charge and then it is moved to 20 cm no would the potential change?
Coco12 said:How do you know it is electric force?
The inverse formula for potential is a mathematical equation that allows you to calculate the potential field from a known distribution of charges or masses.
The inverse formula for potential is derived from Coulomb's law for electric charges or Newton's law of gravitation for masses. It is a fundamental equation in the study of electromagnetism and gravity.
The inverse formula for potential has many practical applications in fields such as electrical engineering, astrophysics, and geophysics. It is used to model and understand the behavior of electric and gravitational fields.
Yes, the inverse formula for potential can be rearranged to solve for other variables such as charge or mass, depending on the scenario. This makes it a versatile tool in solving a variety of problems in different fields.
The inverse formula for potential assumes a static distribution of charges or masses and does not take into account any dynamic changes. It is also a simplified model, and in real-world scenarios, there may be other factors at play that can affect the potential field.
