Inverse of y=x+sinx: y= x - sinx
In summary, the conversation discusses the problem of finding the inverse of the function y=x+sin(x). The participants explore different methods, including using power series expansions and matrices. They eventually arrive at the solution of finding the derivative of the inverse at a specific point.
MercuryRising
28
find the inverse of y= x + sinx
i got as far as x=y+siny..but how do i get to y= ____?
thanks
How did you get as far as that??
It doesn't seem right.
In the neighbourhood of (x,y)=(0,0), you might use the technique of successive substitutions to gain a fairly accurate approximation:
1. First, expand your right hand-side in a power series, and get:
[tex]y=2x-\frac{x^{3}}{3!}+\frac{x^{5}}{5!}...[/tex]
2. Next, assume that x can be written as some power series in y:
[tex]x=\sum_{n=1}^{\infty}a_{n}y^{n}[/tex]
3. Plug in that power series in your equation:
[tex]y=2a_{1}y+2a_{2}y^{2}+2a_{3}y^{3}-\frac{a_{1}^{3}y^{3}}{3!}++++[/tex]
4. Thus, by comparing coefficients, you get:
[itex]a_{1}=\frac{1}{2}, a_{2}=0, a_{3}=\frac{1}{96}[/tex]
5. Hence, to the three lowest orders, you've got:
[tex]x=\frac{y}{2}+\frac{y^{3}}{96}[/tex]
If y= x+ sin x then x is NOT y+ sin y- in particular, if [itex]x= \frac{\pi}{2}[/itex] then [itex]y= \frac{\pi}{2}+1[/itex] but [itex]\frac{\pi}{2}+1+ sin(\frac{\pi}{2}+1) \ne \frac{\pi}{2}[/itex]. Simply subtracting sin x from both sides gives x= y- sin x, not y+ sin y. Essentially, you need to solve the equation
y= x+ sin x for x- and that cannot be done algebraically.
You could simply use a 2 by 2 matrix that reflects the function in the line y = x, that will be the same as the inverse.
I think he's using the method we all learned in high school: to get an inverse function, replace x with y and vice-versa, then solve for y (where y, in this case, is really [itex]y^{-1}(x)[/itex] ). For instance:
[tex]y = e^{x}[/tex]
Repleace x with y
[tex]x = e^y[/tex]
Solve for y
[tex]\ln{x} = \ln{e^y} = y[/tex]
Therefore, the inverse of [itex]y=e^x[/itex] is [itex]y=\ln{x}[/itex]
I doubt he's up to the point of using Power Series expansions (most people learn that after calculus, and this is the precalculus forum) or matrices.
That said, this one is tricky and I don't recall how you'd do it aside from the more complicated methods mentioned here.
since it seems like that finding the inverse is beyond high school calculus..maybe my approach to the probelm was incorrect
the probelms states f(x) = x + sin(x), g(x) is the inverse of f(x) so f(g(x)) = x
a) write an expression for f(g(x)) in terms of g(x) and
b) use f(g(x))= x to find g'(x) in terms of g(x)
i do not understand what it means by writing an expression interms of g(x) when i have no idea how to find the inverse..
I think they mean to write an expression that has "g(x)" in it. In other words just substitute g(x) for x in f(x)=x+sin(x).
For the second part I would just differentiate and use the chain rule.
ok.. so f(g(x)) = g(x) + sin(g(x)) = x
to find g'(x) in terms of g(x) i did
g'(x) + (g'(x))cos(g(x)) = 1..wait that doesn't seem right
I think that's what they wanted. Now just solve for g'(x).
ok... so g'(x) = 1/ 1 + cos(g(x))
now they want g'(pi)...and I am stuck again, i can't find any trig identities that can help me in g'(x)
Remember that if f(x) and g(x) are inverse functions then
[tex] g'(x) = \frac 1 {f'(g(x))} [/tex]
and if
f(x) = y
then
g(y) = x
so to find g'(x) at a point say t, g'(t), just solve f(x) = t for x then that value of x you find is g(t) then to find the derivative at that point just take 1 over the derivative of f evaluated at the x you found.
well, in this case f(x) = pi so x= pi
1/ f'(pi) = 1/ 1+ cos( pi) = 1/ 1-1 = 1/0 :confused:
No, f(x)=[itex]\pi[/itex], so
[tex]\pi=x + \sin{x}[/tex]
Can you think of the value of x that makes this true? This value is [itex]g(\pi)[/itex] because, by definition of the inverse function, if
[tex]f(a)=b[/tex]
then
[tex]f^{-1}(b)=a[/tex]
So then what you want to do is find f'(x) and then sub in the value of [itex]g(\pi)[/itex] that you get to find [itex]f'(g(\pi))[/itex]. You know where to go from there.
What is the inverse function of y = x + sinx?
The inverse function of y = x + sinx is y = x - sinx.
How do you find the inverse of a function?
To find the inverse of a function, switch the x and y variables and solve for y.
What is the domain and range of the inverse function y = x - sinx?
The domain of the inverse function y = x - sinx is all real numbers. The range is also all real numbers.
Is the inverse function of y = x + sinx the same as the original function?
No, the inverse function of y = x + sinx is y = x - sinx, which is not the same as the original function.
Can you graph the inverse function y = x - sinx on the same graph as the original function?
Yes, you can graph the inverse function y = x - sinx on the same graph as the original function by reflecting the graph of y = x + sinx across the line y = x.
