Inverse Laplace Transform
  • Thread starter Swapnil
Swapnil
459
My book on signal processing says that:
[tex] f(t) = \frac{1}{2\pi j} \int_{c-j\infty}^{c+j\infty} F(s) e^{st} ds = \lim_{\Delta s \to 0} \sum_{n = -\infty}^{\infty} \Big[ \frac{F(n\Delta s)\Delta s}{2\pi j} \Big] e^{n\Delta s t}[/tex]
I don't get this. How/Why can you write a integration over a complex variable as the above sum?
edit: I forgot a coefficient [tex]\frac{1}{2\pi j}[/tex] on the LHS. Sorry about that. Its fixed now.
Answers and Replies
DeadWolfe
454
Isn't that definition of a Reimann integral?
gammamcc
150
I understand how you could be confused! It would have to be explained what \Delta s is in the sum since the integral seems to have s lie on a vertical line c + jy in the complex plane (real y). So do we perhaps have \Delta s =
j\Delta y???
Supposing the above and not knowing anything else about F, using a Riemann sum, you should have limit as \Delta s -> 0 of sum over n of the following terms:
F(c+n\Delta s)\exp((c+n\Delta s)t)\Delta s
which is the limit as \Delta y-> 0 of the sum of terms
F(c+n j \Delta y)\exp((c+ n j \Delta y)t)j\Delta y
The 2\pi j in the denominator seems something like Cauchy's integral thm., but we need to know quite a bit more about F to get that. (Is F an entire fuction? Does it vanish very rapidly away from the y-axis in the complex plane?)
Generally speaking, the independence of c on the RHS makes the formula dubious.
Can you still get the money back for the book?
Swapnil
459
I understand how you could be confused! It would have to be explained what [tex]\Delta s[/tex] is in the sum since the integral seems to have [itex]s[/itex] lie on a vertical line [tex]c + jy[/tex] in the complex plane (real y). So do we perhaps have [tex]\Delta s =
j\Delta y[/tex]???
Supposing the above and not knowing anything else about [tex]F[/tex], using a Riemann sum, you should have limit as [tex]\Delta s -> 0[/tex] of sum over [itex]n[/itex] of the following terms:
[tex]F(c+n\Delta s)\exp((c+n\Delta s)t)\Delta s [/tex]
which is the limit as [tex]\Delta y-> 0 [/tex] of the sum of terms
[tex]F(c+n j \Delta y)\exp((c+ n j \Delta y)t)j\Delta y[/tex]
The [tex]2\pi j[/tex] in the denominator seems something like Cauchy's integral thm., but we need to know quite a bit more about [tex]F[/tex] to get that. (Is [tex]F[/tex] an entire function? Does it vanish very rapidly away from the y-axis in the complex plane?)
Generally speaking, the independence of [itex]c[/itex] on the RHS makes the formula dubious.
Edited gammamcc's post to look nice...
Suggested for: Inverse Laplace Transform
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
