Homework Help: Inverse Laplace transform
  1. Sep 12, 2014 #1
    Find the inverse Laplace transform of the expression:
    F(S) = [itex]\frac{3s+5}{s^2 +9}[/itex]
    2. Relevant equations
    3. The attempt at a solution
    From general Laplace transforms, I see a pattern with laplace transforming sin(t) and cos(t) because:
    L{sin(t)+cos(t)} = [itex]\frac{s+1}{s^2 +1}[/itex]
    All I'm missing here is a couple of constants(?).
    I know that the laplace transform works like this:
    L{Asin(Bt)+Ccos(Dt)} = [itex]\frac{Cs}{s^2 +D}[/itex] + [itex]\frac{A*B}{s^2 +B^2}[/itex]
    Looking at my original problem, I can see that I need B to equal D, ##D^2## + ##B^2## = 9, C = 3 and A*B = 5.
    If I set A = 5, B = 3, C = 9 and D = 3 I get ##3^2## + ##3^2## = 18, 5
    3 = 15 (putting numbers into my equations above).
    Therefore I need to divide the whole expression by 3 to get my correct answer:
    L{[itex]\frac{1}{3}([/itex]5sin(3t)+9cos(3t))} = [itex]\frac{3s+5}{s^2 +9}[/itex]
    Is there a simpler way to do this? Or do I just have to use the trial and error method until I find the correct factors/constants?
    Any input on this will be greatly appreciated. Thanks
  3. Sep 12, 2014 #2
    HallsofIvy
    What? One of the equations above said A*B= 5 which is NOT satisfied by A= 5, B= 3. You have only three equations for the four values A, B, C, and D. And there is no reason to assume that A, B, C, and D must be integers.
    Use the fact that the Laplace transform, and so its inverse, is linear.
    [tex]\frac{3s+ 5}{s^2+ 9}= 3\frac{s}{s^2+ 9}+ 5\frac{1}{s^2+ 9}[/tex]
    and look up their inverse transforms separately.
    The laplace transform of [itex]cos(\omega x)[/itex] is [itex]\frac{s}{s^2+ \omega^2}[/itex] so the inverse transform of [itex]3\frac{s}{s^2+ 9}[/itex] is [itex]3 cos(3x)[/itex]
    The Laplace transform of [itex]sin(\omega x)[/itex] is [itex]\frac{\omega}{s^2+ \omega^2}[/itex] so the inverse transform of [itex]5\frac{1}{s^2+ 9}= (5/3)\frac{3}{s^2+ 9}[/itex] is [itex](5/3)sin(3x)[/itex].
Have something to add?
Draft saved Draft deleted
Loading...
