Inverse linear least squares?
  1. Feb 9, 2008 #1
    Forgive me if the subject of this post is not accurate, I'm not quite sure what the correct terminology would be for what I'm trying to figure out.
    Currently I am using linear least squares via SVD to find the coefficients of a ten term polynomial, say f. This model allows me to predict some output y given some input x. Thats straightforward.
    What I would like to be able to do is turn this around and find a function g where g would take an input x, and output some y' such that f( y' ) = x.
    Is this familiar to anyone? I'm totally stumped.
  3. Feb 9, 2008 #2
    Why can't you do that now? In linear least squares, you are given a list of points, [itex]{(x_1, y_1), (x_2, y_2), \cdot\cdot\cdot, (x_n, y_n)}[/itex] and you construct an equation y= ax+ b whose graph passes close (in the least squares sense) to each of those points. Given any other x, the "predicted" y value is ax+ b. But linear equations are easily solved. Given any y, the "predicted" x value is just (y- b)/a. All the work has already been done in using linear least squares to find a and b.
  4. Feb 9, 2008 #3
    Yes but my equation is nonlinear. Let me try and explain better.
    Originally I start with two lists of points. Lets put them all on the x-axis for simplicity. The first list I will call actual coordinates. The second list I will call deviated coordinates. The deviated coordinates are simply the actual coordinates plus some offset. My prediction function f just predicts the deviation of an inputted actual coordinate.
    So if I input any actual coordinate x into f, f will give me a predicted deviation. So my predicted deviated point is x + f(x).
    Now say I know in advanced a point x. I need to find a way to determine a point x' such that f( x' ) gives me the deviation I need such that x' + f( x' ) = x.
    Does this make sense? Or am I missing something totally obvious?
  5. Feb 9, 2008 #4
    I don't think you are using the right terminology. I would think for inverse least squares you might look at something like this:
    Anyway, so basically what it sounds like is you fit a polynomial to a lower order polynomial using least squares. You have two choices. You can either find the roots of this lower order polynomial, or instead you can do a new least squares on the inverse function.
  6. Feb 9, 2008 #5
    Thanks, but can you please elaborate a bit. I'm not following you.
  7. Feb 9, 2008 #6
    Can you first try to write down the exact problem you are trying to solve clear.
  8. Feb 9, 2008 #7
    The problem is exactly as described in my second post. If you can say whats not clear, I'll try and explain a bit more.
Similar Threads - Inverse linear least Date
I Proving an inverse of a groupoid is unique Jan 1, 2017
Proof of invertibility Feb 4, 2016
Inversion problem Oct 13, 2014
Proof of a linear operator acting on an inverse of a group element Oct 7, 2013
Inverse Linear Transform Oct 17, 2012
