Inverse ln function
Determine[tex] f^{-1}(0)[/tex] of [tex] f(x) = ln (4-7x) + ln(-7-5x)[/tex]
[tex]f(x) = ln (4-7x) + ln(-7-5x)[/tex]
What I did was
[tex]y = ln (4-7x)(-7-5x)[/tex]
Then I swapped x and y to attempt to make the inverse function
[tex]x = ln (4-7y)(-7-5y)[/tex]
and I start to solve for y
[tex]e^{x} = 35y^2 + 29y -28[/tex]
But this is where I am stuck. What do I do now? :/
Answers and Replies
fzero
289
Do you remember the quadratic formula?
Yeah. But I don't think it would work here. Would it?
fzero
289
You have to be careful because only one of the roots is compatible with the domain on which f(x) is defined.
Also, I just realized you swapped x and y. Don't do this as you're just going to confuse yourself. Just write
[tex] y =f(x), x = f^{-1}(y)[/tex]
and solve for x.
and solve for x.
Yeah, the second part is undefined as you cannot take the ln of a negative number. So should I discard that root and write [tex] y = ln (4-7x) [/tex] and solve for x out of here?
fzero
289
By roots I meant the solutions of the quadratic equation you get, not the terms in f(x). You can't change f(x), but you can determine the range of x for which both terms in f(x) are well-defined. Remember that x doesn't have to be positive, just the argument of the log function does.
fzero
289
I'm confused.
Can you write down an inequality on x such that
is well-defined?
is well-defined?
x < -5/7?
fzero
289
x < -5/7?
It's actually x < - 7/5. Now find the roots of the quadratic equation
[tex]e^{y} = 35x^2 + 29x -28[/tex]
and determine if either of them are consistent with that inequality.
But it's not equal to zero :/. I would just get -1.4 and 4/7.
fzero
289
Rewrite it in the form
[tex] 35x^2 + 29x -(e^{y}+28) =0. [/tex]
What the? I never even knew that's possible.
I just sub that into the quadratic formula with [tex] c = (e^{y}+28) [/tex]
fzero
289
Well we're considering x as a function of y, so x(y). As long as the coefficients depend on y and not explicitly on x, it's still a quadratic equation in x.
ugh this is so confusing :/
Is the answer -1.414?
fzero
289
I have another question of inverse ln.
Let's say you have [tex]-(ln (x)+2)^{1/2}[/tex]
The domain would just be [tex]0 < x </= e^2[/tex]
The inverse of it would be [tex] x = e^{(-y^2 + 2)}[/tex]
Would the domain of the inverse function just be x < 0? which is the range of the original function.
fzero
289
The domain of y(x) is just [tex]x>0[/tex]. The inverse function is positive for all y (including imaginary y), so there's no problem.
Explain.
when x = 8, it doesn't exist.
fzero
289
Explain.
The log requires x>0. The square root is real whenever its argument is positive, imaginary if the argument is negative. The exponential is defined over the real axis, because of the square in its argument it gives a real even when y is imaginary. x(y) is defined everywhere that y(x) and vice-versa.
I'm going to presume and say I am wrong. Now, I am more confused!
HallsofIvy
41,847
966
The answer to what question? You originally asked for the inverse function. Do you think the inverse function is "-1.414"?
You have reduced your problem to the equation
[tex] 35y^2 + 29y -(e^{x}+28) =0[/tex]
(I have swapped x and y as you did before) and you want to solve for y.
The quadratic formula says that solutions to the equation ay^2+ by+ c= 0 are given by [tex]\y= \frac{-b\pm\sqrt{b^2- 4ac}}{2a}[/tex]
Here, a= 35, b= 29, and [itex]c= -(e^x+ 28)[/itex]. Since c involves the variable x, so will the solution to that quadratic equation. You will need to check to see whether the "+" or "-" in "[itex]\pm[/itex]" is proper for this problem.
HallsofIvy
41,847
966
In order that we be able to take the logarithm, we must have x> 0. In order to be able to take the square root, we must have [itex]ln(x)+ 2\ge 0[/itex] or [itex]ln(x)\ge -2[/itex]. Since ln is an increasing function that is the same as saying [itex]x\ge e^{-2}[/itex]. That is NOT the same as [itex]x\le e^2[/itex]! Since [itex]e^{-2}> 0[/itex], we have both [itex]x> 0[/itex] and [itex]x\ge e^{-2}[/itex] just by taking [itex]x\ge e^{-2}[/itex]. That is the domain.
Be careful about writing x as a function of y. If y= 3x, then x= y/3 is the same function, not the inverse. The inverse function to y= 3x is y= x/3.
The original function is given by [itex]y= -(ln(x)+ 2)^{1/2}[/itex]. The inverse function is given by [itex]x= -(ln(y)+ 2)^{1/2}[/itex] but we want to write "y= " so we need to solve for y. Squaring both sides gives [itex]x^2= ln(y)+ 2[/itex] so that [itex]ln(y)= x^2- 2[/itex] and then [itex]y= e^{x^2- 2}[/itex]. The "-" in the original disappeared when we squared both sides. Stictly speaking, the natural domain of [itex]y= e^{x^2- 2}[/itex] is "all real numbers" but this is NOT that function:
Yes, exactly! When [itex]x= e^{-2}[/itex] in the original function, y= 0. As x increases without bound, ln(x) increases without bound and so does the square root of ln(x)+ 2. But y is the negative of that. The range of the original function is "all x< 0" and so the domain is also, just as you say! (A function and its inverse "swap" range and domain just as the "swap" x and y.)
So my domain for the original function is wrong too? How? It cannot go past e^2 or otherwise you'd have a negative square root.
Related Threads on Inverse ln function
  • Last Post
13K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
