Inverse matrices question.
  • Thread starter peripatein
Main Question or Discussion Point
Hello,
Would it be correct to say that if for every two different vectors x and y, A*x ≠ A*y (where A is a symmetrical matrix), then A is NOT necessarily invertible? In other words, albeit for any two different vectors x and y symmetrical matrix A times one of the vectors is not equal to A times the other, A is not necessarily invertible?
Answers and Replies
Correction, in case A is a square matrix (of order nXn)
Erland
136
If A is an n x n - matrix such that Ax ≠ Ay for all pairs of distinct n-vectors x and y, then A is invertible.
Let us examine the following singular matrix:
2 0 4
1 -1 3
0 -1 1
For any two different vectors I claim that that matrix multiplied by the first vector will never be equal to the multiplication of that same matrix by the second vector.
Hence, the matrix does not necessarily have to be singular for the proposition to be valid and hold.
Wouldn't you agree?
Erland
136
2 0 4
1 -1 3
0 -1 1
Wouldn't you agree?
Certainly not. As you said, the matrix is singular. This means that there is a nonzero vector x such that Ax=0 (such an x can easily be found if we solve the system Ax=0). On the other hand, A0=0, so Ax=A0, despite that x≠0.
Okay, so the proposition does not hold in case A is singular, but does that per se guarantee that it holds, for EVERY two different vectors, if A were not singular, i.e. invertible?
Erland
136
Yes, for if A is invertible and Ax=Ay, then x=Ix=(A-1A)x=A-1(Ax)=A-1(Ay)=(A-1A)y=Iy=y, that is, x=y.
The system Ax=b has a unique solution, x=A-1b, if x is invertible. Otherwise, it has either no solution or infinitely many solutions.
Thank you very much! :-)
AlephZero
6,994
291
The easy way to see this is false is consider the special case of x ≠ 0 and y = 0.
Ay = 0, so for every x ≠ 0, Ax ≠ 0.
If A is singular, there is a vector x ≠ 0 such that Ax = 0, which is a contradiction. Therefore A is non-singular.
Related Threads on Inverse matrices question.
  • Last Post
  • Last Post
20K
  • Last Post
10K
  • Last Post
  • Last Post
