Homework Help: Inverse of a 2X2 matrix
  1. Sep 13, 2010 #1
    Find the inverse of matrix A
    02
    30
    3. The attempt at a solution
    I was thinking of doing a row swap to get a diagonal matrix with nonzero diagonal entries, PA (a.k.a. B). I want this matrix's inverse, B-inverse (easily found by dividing the ones of the identity matrix by the diagonal entries) to serve as a means to get to A-inverse
    I want to use this relationship specifically: (B-inverse)(PA)=(A-inverse)(A)=I. I want to multiply all sides by A-inverse to show that (B-inverse)(P)=(A-inverse), but I am really shaky as to how I properly utilize the multiplication rules for matrices in this case.
    For example: Would multiplying both sides by A-inverse cancel out A? Wouldn't I be applying A-inverse to the outermost matrix and not even hit A?
    To sum: Where I really get lost is how to properly manipulate matrix equations in order to cancel.
    Let me know if you have any questions. Sorry I couldn't make the post more visual. Don't know how to draw out matrices.
  3. Sep 13, 2010 #2
    You could just use the identity that any matrix times its inverse equals the identity matrix.
  4. Sep 13, 2010 #3
    To use this identity you augment your matrix with the identity matrix. So you start with (A|I) where I is the identity matrix. You use matrix operations to transform A into I and your augmented matrix will be A^-1.
    So you start with:
    02|10
    30|01
    And you want to use elementary row operations to make your matrix to look like:
    10|ab
    01|cd
    Where a,b,c,d will make up you’re a^-1
  5. Sep 13, 2010 #4
    This is Guass-Jordan, no? So even though I am permutating the original matrix to get another matrix, the end result is A^-1, not the inverse of the matrix after permutation?
  6. Sep 13, 2010 #5
    HallsofIvy
    Or just use [tex]\begin{bmatrix}a & b \\ c & d\end{bmatrix}\begin{bmatrix}0 & 2 \\ 3 & 0\end{bmatrix}= \begin{bmatrix}1 & 0 \\ 0 & 1\end{bmatrix}[/tex]
    to get the equations 0a+ 3b= 3b= 1, 2a+ 0b= 2a= 0, 0c+ 3d= 3d= 0, and 2c+ 0d= 2c= 1. Those equations are pretty close to begin trivial, aren't they?
  7. Sep 13, 2010 #6
    Mark44
    Staff: Mentor
    There's a formula that can be used to find the inverse of a 2x2 (only) matrix.
    [tex]\text{If} A = \begin{bmatrix}a & b \\ c & d\end{bmatrix},[/tex]
    [tex]A^{-1} = \frac{1}{|A|}\begin{bmatrix}d & -b \\ -c & a\end{bmatrix}[/tex]
    Of course, it must be true that |A| is not 0.
  8. Sep 13, 2010 #7
    At the moment we are ignoring the determinant formula for the 2x2 case. That's what that is, right, Mark 44?
    Thanks for all the help. I don't know why I was going the direction I was with this. For some reason I keep thinking this class requires a ridiculously abstract approach when, in most cases, I can use simpler mechanisms.
