1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Inverse of exponential matrix
  1. Dec 15, 2013 #1
    We have a matrix with dimension NxN.For some m belongs to N,m0 we have A^m0=0.We consider the exponential matrix e^A=I+A+A^2/(2!)+A^2/(3!)+A^m/(m!).Find the inverse matrix of e^A.
    I tried to write the e^A=e^A(m0)+A^m/(m!) or (e^A)^(-1)=( I+A+A^2/(2!)+A^2/(3!)+A^m/(m!))^(-1)=I+A^(-1)(I+2/3A(-1)+1/(m!)(A^(-1))^(m-1)) or (e^A)^(-1)=(e^(-1))^A=(1/e)^A=1/(e^A)=1/( I+A+A^2/(2!)+A^2/(3!)+A^m/(m!)),but I don't know how to proceed any further.How am I supposed to end up with m0 and the result of (e^A)^(-1) will equal to something(A),(A^(-1)?Please help.
  3. Dec 15, 2013 #2
    I cannot read a word of that. Please put a little bit of formatting into that.
  4. Dec 15, 2013 #3
    Sorry for that.For convenience I have a picture of the above.
  5. Dec 16, 2013 #4
    D H
    Staff Emeritus
    Hint: What is the general form for the inverse matrix of the matrix exponential?
  6. Dec 16, 2013 #5
    I don't know.We haven't learnt anything for exponential matrices.Should I consider a function or something like that?But we haven't been taught how to combine matrices and functions as well.
  7. Dec 16, 2013 #6
    D H
    Staff Emeritus
    For real and complex numbers, the exponential function is defined by ##\exp(z) = \sum_{r=0}^{\infty} z^r/r!## The matrix exponential is defined analogously: ##\exp(A) = \sum_{r=0}^{\infty} A^r/r!## Note that this assumes that ##A^r## makes sense. It doesn't make sense for an NxM matrix with N≠M. The matrix exponential is only defined for square matrices. It makes sense for square matrices because even though matrix multiplication is not commutative in general, it is for powers of a matrix: ##AA^n=A^nA##, and thus ##A^{n+1}## is well-defined.
    A useful identity for any two complex numbers u and v is that ##\exp(u+v) = \exp(u)\exp(v)##. This identity is not necessarily the case for square matrices: ##\exp(A+B)## is not necessarily equal to ##\exp(A)\exp(B)## for any two NxN matrices A and B. It does hold if A and B commute.
    You can use this identity for commuting matrices to find the inverse of ##\exp(A)##.
    Where did you come across this problem?
  8. Dec 16, 2013 #7
    Our professor in the university has this in a project we have to give in after the holidays for linear algebra...So the inverse of exp(A) will be found as a function of A,inverse A...what?But,yet,how will I proceed from exp(A)*exp(-A)=I (1),in order to find exp(-A),which is the inverse matrix to find?What will happen to the term A^m/(m!)?And first of all how will I show that there is the inverse matrix of exp(A) so as to begin from (1)?
  9. Dec 16, 2013 #8
    D H
    Staff Emeritus
    This is a *lot* simpler than you are making it out to be. You apparently already know that ##(\exp(A))^{-1} = \exp(-A)##. So compute ##\exp(-A)##. This isn't that hard! What's the general case? Next use the fact that your matrix A is nilpotent.
  10. Dec 16, 2013 #9
    Something like this:exp(-A)= I-A+A^2/2-A^3/6+...+-A^m1/m1!,where m1 is the value right before the value for which A^m=0?And now what?That's it?
  11. Dec 16, 2013 #10
    D H
    Staff Emeritus
    That's it.
  12. Dec 16, 2013 #11
    So the inverse of exp(A) equals with something that has the term m1?Why I don't feel it right?Are you sure?
  13. Dec 16, 2013 #12
    Dick
    What doesn't feel right? Suppose ##A^2=0##. Then exp(A)=I+A. exp(-A)=I-A. (I+A)(I-A)=I, can you see why?
  14. Dec 16, 2013 #13
    Yes,but the answer took me only a couple of lines to write.I mean it can't be that simple!And we have to take cases for m1 in order to determine the sign before A^m1,right?
  15. Dec 16, 2013 #14
    Dick
    The m1 term is (-A)^m1/m1!. If you want to write that as a power of A, then you could write (-1)^m1*A^m1/m1!. No need for cases. If you want to make the problem a LOT harder you could try to prove by expanding terms that exp(A)*exp(-A)=I. But I don't think you have to do that.
  16. Dec 16, 2013 #15
    Ok,thank you!
  17. Dec 16, 2013 #16
    D H
    Staff Emeritus
    It's not that hard if someone has already gone to the trouble of showing that if matrices A and B commute then ##\exp(A+B)=\exp(A)\exp(B)##. Set B=-A. This obviously commutes with A, so ##\exp(A+B)=\exp(A)\exp(B)## applies. With ##B=-A##, the right hand side becomes ##\exp(A)\exp(B) = \exp(A)\exp(-A)## while the left hand side becomes ##\exp(A+B)=\exp(A+(-A))=\exp(0)=I##. Thus ##\exp(A)\exp(-A)=I##, or the inverse of ##\exp(A)## is ##\exp(-A)## -- valid for any square matrix A.
    Showing that ##\exp(A+B)=\exp(A)\exp(B)## for any two matrices A and B that commute -- now that takes some work.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Inverse of exponential matrix
  1. Matrix Exponential (Replies: 4)
  2. Matrix exponential (Replies: 4)
  3. Matrix exponential (Replies: 4)
  4. Matrix Exponentials (Replies: 2)
Loading...
