Inverse of Function f: R -> R Defined by f(x) = x^3+1
In summary, the function f: R -> R defined by f(x) = x^3 + 1 is one-to-one because f(a) = f(b) implies a = b. The inverse of f is f^-1(x) = (x - 1)^(1/3). When composing f with itself, the result is f(f(x)) = f(x^3 + 1) = (x^3 + 1)^3 + 1.
sapiental
118
a) determine if it is one to one
b)find its inverse
c) calculate (f o f)
if f(x) is one to one, if a = b, f(a) = f(b)
a) yes it is because a^3 + 1 can't equal to b^3 + 1 unless a = b, by definition, this function is onto
b)the inverse is f^-1 (x) = (x - 1)^(1/3)
c) f o f = f(f(x) = f(x^3 + 1) = (x^3 + 1)^3 + 1
just want to make sure i got this, thanks :)
For #1, by definition the function is 1-1 since you just said that if f(a) = f(b) then a = b, not onto. Onto means that if you have something in your codomain, b in R, then there's an element in your domain, a in R, such that f(a) = b for every b in R in the mapping F: R -> R.
For #2, let's see. If you have f(x) = x^3 + 1, then using basic manipulations, you get (y-1)^(1/3) = x if you let y = f(x). Then, change this to f^-1(x) = (x-1)^(1/3), which is what you got.
For #3, you got it. In this case, your x is equal to x^3+1 in F(x). Therefore, if F(x) = x^3 +1, then F(x^3 + 1) = (x^3 + 1)^3 + 1, which is what you also got.
Re-write #1 and all is good.
1. What is the inverse of the function f(x) = x^3+1?
The inverse of this function can be found by solving for x in terms of y. This means swapping the x and y variables and then solving for y. After some algebraic manipulation, the inverse function is found to be f^-1(x) = (x-1)^(1/3).
2. Does the inverse function exist for f(x) = x^3+1?
Yes, the inverse function exists for any one-to-one function, which means that each input has a unique output. In this case, the function f(x) = x^3+1 is one-to-one, so the inverse function exists.
3. How do I graph the inverse function of f(x) = x^3+1?
To graph the inverse function, you can use the original function's graph and reflect it over the line y=x. This means swapping the x and y coordinates for each point on the graph. The resulting graph will be a reflection of the original graph over the line y=x.
4. How do I find the domain and range of the inverse function of f(x) = x^3+1?
The domain and range of the inverse function can be found by examining the domain and range of the original function. The domain of the inverse function will be the range of the original function, and the range of the inverse function will be the domain of the original function.
5. How do I know if a function has an inverse?
A function has an inverse if it is one-to-one, meaning each input has a unique output. This can be determined by using the horizontal line test. If a horizontal line intersects the graph of the function more than once, then it is not one-to-one and does not have an inverse.
