Inverse Square Law: Gravitational & Electromagnetic Forces
In summary, the gravitational and electromagnetic forces are inversely proportional to the square of the distance due to the spatial dispersion of the field. This can be seen through examples such as a light bulb's brightness being affected by its distance from the observer. There is still debate on whether this idea is fundamentally true or derived from more fundamental concepts. The inverse square law is also seen in other phenomena such as the chances of hitting a target in a game like paintball. However, in certain circumstances such as in general relativity and electrodynamics, the forces may not follow an inverse square law.
eep
227
do we know why gravitational and electromagnetic forces inversely proportional to the square of the distance? is there any sort of underlying principle as to why they must be this way?
It's basically just due to spatial dispersion of the field. The farther it is from the source, the more area it has to be spread over. A crude example might be a light bulb. If you put a 40-watt bulb in your refrigerator, it will be too bright. The same bulb in a typical living room would be too dim, and if it were in the Astrodome, it would barely show up.
Although the (brilliiant) idea of a fixed amount of "force-area" was the clue Newton found in order to formulate his gravitational law, whether this idea in its full generality (for a variety of phenomena) should be regarded as fundamentally "true" or how it is derivable from more fundamental ideas, is, I believe, still an open issue.
This is a question that has bugged me too. I always thought that if you imagine the force spreading out radially from a point it is like an enlarginng sphere. The surface area of the sphere is propotional to r squared. That's just the way I pictured it though, and like I said, it has always bugged me.
If you start gravitation from Newton's law of gravity, and EM from Coulomb's law then the 1/r^2 seems ad hoc. But if gravity or EM are started with Gauss's law (which is an equivalent starting point) then the 1/r^2 comes out as a natural consequence of the 4pi r^2 area of a sphere.
And why should Gauss' law be anything but an ad hoc fantasy?
Just because you start off with fancier maths doesn't resolve the issue.
At some level the answer to these types of questions is "Because this equation matches experimental results well under certain conditions."
Gauss's law is true more generally than Coulomb's law. Coulomb's law would indicate that if a charge moves, then the [itex]\vec{E}[/tex] field changes intantaneosly at every point in space. Gauss's law, in conjunction with the rest of Maxwell's equations, gives the correct result that the change propagates at the speed of light. This would seem to indicate that it is more fundamental.
I like to think like this, imagining the logic of the proportionality of what seems to be experimentally involved and considering what is being described.
In this case, with two bodies situated in the points A and B, I would try the way of thinking the force as inversely proportional the the distance AB and inversely proportional to the distance BA.
As an example let me introduce a game, paint ball. Let the player A have his gun as well as the player B. If both have fixed areas. If each one is aiming at the other, and if A only shot again after his last shot has touched B and reciprocally, it is natural to indentify the frequency of A hitting B as inversely proportional to the distance AB. Also the frequency of B hitting A is inversely proportional to the distance BA which is equal to AB (this, although aparently obvious, seems to me as fundamental to this issue). So, if we intend to compute the frequency of hearing an "ouch", no matter the author, A or B, the expression for this frequency would involve the inverse square law in distance, as it seems to me up to now.
DaTario said:
It is natural to indentify the chances of A hitting B as inversely proportional to the distance AB (consider solid angle in the anallysis). Also the chances of B hitting A is inversely proportional to the distance BA which is equal to AB (this, although aparently obvious, seems to me as fundamental to this issue).
Actually, that probabilty seems to be proportional to the inverse of the square of the distance. If A has a certain constant area, then the solid angle he substends from B's position is proportional to the inverse of the square of the distance. If we assume that B shoots in all directions with equal probability, then this angle is proportional to the probability of a hit.
DaTario said:
So, if we intend to compute the chances of hearing an "ouch", no matter the author, A ou B, the expression for tis chance would involve the inverse square law in distance, as it seems to me up to now.
True that it would involve the inverse square, but over large distances the [itex]\frac{1} {r}[/tex] term would be more important. This can be seen because the probability of at least on hit is equal to 1 minus the probability on no hits. Assume the probability of A hiting B is [itex] \frac{k} {r}[/tex] which is the same as the probability of B hitting A. Then the probability of A not hitting B is [itex](1- \frac{k} {r})[/tex]. Therefore the probability of A not hitting B and B not hitting A is [itex](1-\frac{k} {r})^2=1-\frac{2k} {r} + \frac{k^2} {r^2}[/tex]. This means the probability of either A hitting B or B hitting A is [itex]1-[1-\frac{2k} {r} + \frac{k^2} {r^2}]=\frac{2k} {r} - \frac{k^2} {r^2}[/tex]
Sorry, I guess you have read the uneditted post.
Yeah, I did. The last part is right that way.
I think it should be pointed out that the gravitational and electromagnetic forces are 1/r^2 forces in only certain special circumstances. Things get more complicated with GR and Electrodynamics.
What specific situations are you referring to ?
One of the specific situations are, I guess, "extra dimensions" :smile: . If a world was D-dimensional (only space dimensions counted), the radial dependence of the force would be:
[tex]F(r) \sim \frac{1}{r^{D-1}}[/tex],
each new dimension introduces another factor 1/r. As far as current experimental results show, down to a milimeter (or 0.1 mm; something like that) scale, gravity follows [tex]1/r^2[/tex] law. Offcourse, this is only the beggining of the story with extra dimensions, but I wouldn't go any deeper :) .
Suppose you have a negative charge, and a small distance away you have a charge of equal but opposite magnitude. Then the electric field in the surrounding space will have a 1/r^3 dependence.
I think that the situation of two charges near each other occurs more frequently then "extra dimensions" :smile:
In that case you still have a [itex]\frac{1} {r^2}[/itex] force from each charge, but they tend to cancel to some extent over large distances and the total force is close to being proportional to [itex]\frac{1} {r^3}[/itex] at large distances. However Coulomb's law is not violated because the force from each charge is still proportional to [itex]\frac{1} {r^2}[/itex].
A simple real situation where Coulomb's law is violated is the following: a point is located 1 light year from a charge. The charge then moves at .5c for [itex]\frac{1}{2}[/itex] a year, so that at the end of this time it is .75 light years from the point in question. Coulomb's law would require that the [itex]\vec{E}[/itex] field at this point be stronger than it was [itex]\frac{1}{2}[/itex] a year ago, but we know that this is impossible because it would reqiure information (in the form of the [itex]\vec{E}[/itex] field) to travel faster than the speed of light. Gauss's law still holds in this case, though, because the [itex]\vec{E}[/tex] field has not changed at any point on the sphere centered at the charges original position with radius 1 light year, so [itex]\oint\vec{E}\cdot d\vec{A}[/itex] will still have the same value over this surface. Gauss's Law will actually hold over any surface, including those with part of the [itex]\vec{E}[/itex] field changed and the rest not.
edit:Something simmilar is true of gravity. Information in the form of an increased gravitational force can also not travel faster than c. Actually, it is my understanding that there is no gravitational "force" in general relativity, but certainly don't claim to know what I'm talking about when it comes to GR.
Ok I agree, some other laws of nature may (and in fact do) disturb the Coulomb's law. But the ontology of the inverse square law is still strong. Note that if you calm down the situation (force the situation to be electrostatic of gravitostatic, the 1/(r*r) comes out again after a finite time. In this sense, it seems to be an interesting procedure to attribute to the inverse square law the status of existing thing inside the domains of Newton's Force Based Physical Theories.
True :smile:, but I like more Euler's :) example.
Well, 1/r^2 dependence is not followed by either nuclear (or strong) force, or the weak force, but that's beyond Newton's simple theories.
thanks for the responses. it suddenly dawned on me one nite that the force laws must follow the inverse square law because of the fixed amount of "force-area" idea. now obviously the inverse square law doesn't make sense in terms of relativity, but the general idea just seemed to "click".
i don't know if you have gotten your question/challenge answered yet, but Gauss' Law is the only law that can work in a 3-dimensional (3 spatial dimensions) world and with conservation of energy or whatever "flux" is coming out of the point source. do you see why, given a 100 watt light bulb radiating omni-directionally, that the intensity (measured in watts/m^2) must have to be [tex] \frac{100 w}{4 \pi r^2} [/tex] at a distance of [tex] r [/tex] from the center of the light bulb (modeled as a point source)? is that ad hoc fantasy?
r b-j
1. What is the Inverse Square Law?
The Inverse Square Law is a physical law that describes the relationship between the strength of a force and the distance between the objects exerting and experiencing that force. It states that the force is inversely proportional to the square of the distance between the objects.
2. How does the Inverse Square Law apply to gravitational forces?
The Inverse Square Law applies to gravitational forces because the strength of the gravitational force between two objects is inversely proportional to the square of the distance between them. This means that as the distance between two objects increases, the gravitational force between them decreases.
3. How does the Inverse Square Law apply to electromagnetic forces?
The Inverse Square Law also applies to electromagnetic forces, such as the force between two electrically charged particles. This means that as the distance between the particles increases, the force between them decreases according to the Inverse Square Law.
4. Why is the Inverse Square Law important in physics?
The Inverse Square Law is important in physics because it helps us understand and predict the behavior of forces, such as gravity and electromagnetism, at different distances. It also allows us to calculate the strength of these forces and how they change with distance.
5. Are there any exceptions to the Inverse Square Law?
While the Inverse Square Law applies to many physical phenomena, there are some exceptions. For example, the force between two magnets does not follow the Inverse Square Law, as it depends on the orientation and size of the magnets in addition to the distance between them. Additionally, the Inverse Square Law does not apply to the strong and weak nuclear forces, which govern interactions between subatomic particles.
  • Other Physics Topics
12K
  • Mechanics
