Inverse transformations
  • Thread starter Mentz114
Mentz114
5,432
292
##{\Lambda_c}^b## is a Lorentz transformation and ##{\Lambda^c}_b## is its inverse, so ##{\Lambda_c}^b {\Lambda^c}_b## gives an identity matrix.
How can I write this, assuming it's possible, in terms of ##\delta##'s ?
##{\Lambda_a}^b {\Lambda_c}^a =\delta^b_c ##
Wrong.
Answers and Replies
WannabeNewton
547
##\Lambda^{a}{}{}_{c}\Lambda^{c}{}{}_{b} = \delta^{a}{}{}_{b}##; it's just regular matrix multiplication.
Mentz114
5,432
292
OK, thanks. I wasn't too far off.
Can I use a ##\delta## to relabel these indexes ? Like
##{\Lambda_c}^b {\Lambda^d}_a {\delta_d}^c = {\delta^b}_a\ \Rightarrow\ {\Lambda_c}^b {\Lambda^d}_a {\delta_d}^c{\delta^d}_c = {\delta^b}_a {\delta^d}_c ##
WannabeNewton
547
I can't parse what you wrote down because the indices are being summed over more than twice. But if you're asking if something like ##\Lambda^{a}{}{}_{c}\delta_{ab} = \Lambda_{bc}## is true then the answer is yes. Keep in mind that this is technically not index raising and lowering but rather just applying the definition of ##\delta_{ab}##. The two are different mathematical operations in spaces that aren't Euclidean.
Mentz114
5,432
292
Yes, I edited while you were writing and took out the raising/lowering.
I can also see now that what I wrote is not sensible. I'm actually trying to establish if for a geodesic ##u^a##
##{\Lambda_c}^b {\Lambda^d}_a u^c \nabla_b u_d = 0##
Messing ##\delta##s looks like a red-herring.
WannabeNewton
547
Is this an exercise from a textbook?
Mentz114
5,432
292
No. It comes from
[tex]
\begin{align}
\dot{v}_a &=\left({\Lambda_c}^b u^c \right)\nabla_b \left( {\Lambda^d}_a u_d \right)\\
&= {\Lambda_c}^b {\Lambda^d}_a u^c \nabla_b u_d + {\Lambda_c}^b u^c u_d \nabla_b {\Lambda^d}_a
\end{align}
[/tex]
I reason that if ##\Lambda## is an inertial boost then both terms must be zero. But the first term does not depend in any way on this distinction ( no derivatives of ##\Lambda##) so it must be identically zero. Am I wrong ?
WannabeNewton
547
I really can't understand what you're doing. What is ##\dot{v}_a##? I assume since you're using ##\nabla## that this is a general curved space-time in which case ##\Lambda## must be a local Lorentz transformation which is different from a global Lorentz transformation of ##(\mathbb{R}^{4},\eta)##.
Mentz114
5,432
292
Sorry, ##v^a = {\Lambda_b}^a u^b## and ##\dot{v}_a## is its proper acceleration.
So, this is not the correct way to boost in curved spacetime ? I suppose I could take this into the frame field of ##u^\mu## in which case I can boost the basis, which is legitimate. Hmm.
Suggested for: Inverse transformations
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
