Invisibility Cloak Update: Bending Light & Metamaterials
  • Thread starter MonstersFromTheId
In summary, the article discusses the concept of creating an invisibility cloak using metamaterials to bend light around objects. While this may be achievable for radar waves, it is more difficult for visible light due to the shorter wavelengths. The article also mentions a "loophole" that could potentially allow for faster than light speeds, but it is still limited by the speed of light. The conversation then goes on to discuss the potential uses and consequences of such technology.
MonstersFromTheId
142
This article is pretty neat. It talks about creating an invisibility "cloak" that works by bending light around things through the use of "metamaterials". Apparently this wouldn't be all that hard to do for making things invisible to RADAR waves (i.e. creating an invisibility "cloak" that, although it doesn't make things invisible to the naked eye, DOES make them invisible to radar) since radar waveslengths are measured in millimeters.
The problem with doing the same thing for visible light is that visible light is measured in nanometers, and at those short wavelengths you'd have to be able to manufacture and control the materials from which the "cloak" is made at nanometer scales.
Here's the link to the article:
http://www.msnbc.msn.com/id/12961080/
(Be sure to click on the link in that article to the "loophole" they're talking about as well)
I DO think a correction needs to be made to what this article says about using this particular "loophole" to get around the fact that light being bent around something takes a longer path.
My understanding of that particular little "loophole" is that although the peak pulse of a light beam can be shifted forward, there by giving the APPEARANCE of THE PEAK PULSE of the light beam traveling at FTL speeds, the transmission of ANY form of *information* is *still* limited to the speed of light in a vacuum.
I.e. Einstein's "causality" has not yet been disproven, and to date there's still no reason to suspect it can be.
That, at least to my little layman's brain says, that if a bird flew behind an invisibility cloak like the one described here, there'd still be distortions visible due to some parts of the image the cloak passes to your eyes taking a longer path to your eye than others.
Regardless, I thought it was a hell of an interesting idea.
Enjoy!
They had a similar article on the BBC web site. And, the impression I got was the light would have to be manipulated in such a way that it doesn't scatter. They pointed out that un-like water [that will wrap around an object], light [photons] tend to go in various directions when coming in contact with an object. Even with this issue sorted out, I would think a side view would appear like a optical distortion with increased distortion around the circumference.
be available to the military sooner than you think.
I wonder if it would possible to see this being used in Iraq. Just think about those insurgents having to worry about invisble americans.
"I wonder if it would possible to see this being used in Iraq. Just think about those insurgents having to worry about invisble americans."
Heh. Are you kiddin'? As if we don't have enough problems already. Picture it for just a moment...
Loose the keys to your car?
Invisible americans must have taken them!
Where's your homework?
Invisible americans stole it!
The electricity substation blew up again?
Invisible americans must have done it!
The gas in your cab was siphoned off last night?
Invisible americans!
Look! The candle on the table just flickered!
Who used the last of the tea?
Oh no! The cat's pregnant!
INVISIBLE AMERICANS! INVISIBLE AMERICANS! THEY'RE EVERYWHERE!
Meanwhile, back in the good 'ol US of A where people are more "sensible" we'd have...
Democrats convinced Invisible Republicans are rigging votes.
Republicans convinced Invisible Democrats are rigging votes.
The "Black Helicopter" crowd would be going out of their already loosely tethered minds.
There'd be headline banners in every tabloid about Invisible Baby snatching rings.
And, just to prove that some things are universal regardless of where you grow up...
"Billy? Where's you physics report on Metamaterials?"
"Umm, ah, INVISIBLE TERRORISTS SOLE IT! They did! I swear!"
Maybe this whole "invisible cloak" thing is just a bad idea no matter how you slice it.
INVISIBLE BABIES? :bugeye: :eek:
Invisible babies must have taken them!
Invisible babies took it!
The electricity substation bleu up again?
INVISIBLE BABIES@!
first we've got to figure out how to do it. then we can think about what to use it for.
then again,
that's what they did with the nuclear bomb (besides winning the war)
and look at the way how nuclear weapons are being restricted to this day.
(of course excluding North Korea's actions.)
1. How does an invisibility cloak work?
An invisibility cloak works by using metamaterials, which are materials engineered to have properties not found in nature. These materials are designed to manipulate light in a way that makes an object appear invisible. The cloak is made up of tiny structures that are smaller than the wavelength of light, causing light to bend around the object and creating the illusion of invisibility.
2. What is the latest update on invisibility cloak technology?
The latest update on invisibility cloak technology is the use of bending light instead of reflecting it. This newer approach utilizes metamaterials that can control the direction of light, allowing it to bend around an object and make it disappear. This update has shown promising results in laboratory experiments and has the potential to improve the effectiveness and versatility of invisibility cloaks.
3. Can invisibility cloaks make anything completely invisible?
No, invisibility cloaks cannot make anything completely invisible. They can only work on specific wavelengths of light and are most effective when used on small objects. Additionally, the cloaks are limited by the size and shape of the object they are trying to hide, as well as the angle at which it is viewed. Therefore, while they can make objects appear invisible under certain conditions, they cannot completely hide them from all perspectives.
4. What are the potential applications of invisibility cloaks?
The potential applications of invisibility cloaks are vast. They could be used in military technology to make objects or even entire vehicles invisible to enemy detection. In the medical field, they could be used to hide instruments during surgeries, allowing for more precise and less invasive procedures. They could also have applications in telecommunications, optics, and consumer products.
5. Are there any ethical concerns surrounding the development of invisibility cloaks?
As with any new technology, there are ethical concerns that need to be addressed. One potential concern is the use of invisibility cloaks for surveillance and invasion of privacy. There are also concerns about the potential misuse of this technology for criminal activities. It is important for scientists to consider these ethical implications and for regulations to be put in place to ensure the responsible use of invisibility cloaks.
  • Other Physics Topics
  • General Engineering
  • Classical Physics
