Iodine 131 β- disintegration
  • Thread starter duchuy
Homework Statement:
Determine the emmited particle
Relevant Equations:
I --> Xe* + e- + ν_
Hi,
I'm struggling to understand an answer in my MCQ.
It states that a scintigraphy would detect γ photons emitted by the iodine's nucleus, and the answer was correct.
But I don't understand how it would detect γ photons from the iodine's nucleus since it disintegrates by forming Xe*, an electron and an antineutrino. So even if it is caused by an electronic rearrangement due to the appearance of a new electron, it would emit a X photon.
To a certain extent, we could say that excited Xe nucleus would emit γ photons but I really don't understand how the iodine's nucleus could emit γ photons...
Can someone please explain to me thank you!
Answers and Replies
Steve4Physics
378
Homework Statement:: Determine the emmited particle
Relevant Equations:: I --> Xe* + e- + ν_
Hi,
Your equation is missing mass (and atomic) numbers. Knowing which isotopes are involved is essential. And your antineutrino symbol should have a bar over it.
However, I guess you are talking about I-131. Look-up the 'decay scheme for I-131' and you will see a mix of ##\beta## and ##\gamma## radiation is produced.
Yes, sorry, I am talking about I-131. But I don't understand how the gamma photon is produced and I can't seem to find an explanation for the origin of the gamma photon emitted by I-131's nucleus. I see how gamma radiation is produced by the excited Xe nucleus, but not by iodine's.
Steve4Physics
378
EDITED - sorry, I re-read the question and have changed my answer...
I think the statement:
"scintigraphy would detect γ photons emitted by the iodine's nucleus"
is an oversimplification to avoid describing the excited states of Xe.
The gamma photons are emitted by the excited Xe nuclei.
What's happening in the diagram is actually what's troubling me. Iodine's nuclei decays into an excited xenon atom. The excited xenom atom emits gamma photons to attain a lower and stable energy state by emitting gamma photons. Therefore the nuclei that emits gamma photons is the excited xenon's, not I-131, right?
From what I understand, I-131's nuclei decays by transmutating a neutron into a neutron, electron and antineutrino to attain a lower energy state due to its neutron excess, it doesn't emit gamma photons.
Steve4Physics
378
I agree. (I don't know if you read my updated post #4.)
It is quite common to attribute the gamma photon to decay of I-131 and write an equation such as
##^{131}_{53}I → ^{131}_{54}Xe + \beta^- + \gamma + \overline {\nu_e}##
This ignores the (intermediate) excited state of Xe for convenience/simplicity. Many years ago I taught physics to radiography students. The equation they used would have been
##^{131}_{53}I → ^{131}_{54}Xe + \beta^- + \gamma##
So the level of detail depends on the context. The original question was not rigorously stated.
Ok I see thank you so much for your help. So in case where I'm using I-131 to detect hyperthyroidism by scintigraphy, the sensors should surround the patient completely because gamma photons are emitted in all directions right? And again, sincerely, thank you sir!
Steve4Physics
378
There is no reason that 'the sensors should surround the patient completely'. A well designed system is sensitive enough to only require a few percent of the photons to be collected.
We had a setup specifically for thyroid measurements (hyperthyroidism, hypothyroidism and ca). It consisted of two detectors (each being a scintillator + PM). Both were pointed to the thyroid - one at the front of the patient's neck and one at the back of the neck. This had the advantage of reducing errors due to patient positioning because the combined response curve was quite 'flat' in the region between the detectors.
Related Threads on Iodine 131 β- disintegration
  • Last Post
  • Last Post
  • Last Post
11K
