Homework Help: Ion beam in E and B field problem
  1. Nov 9, 2009 #1
    A beam of ions enters a region in which the electric field E and magnetic flux density B are normal to each other and both normal to the velocity of the ions. Show that if the velocity of the ions is related to the fields by
    v=ExB/B2
    then the ions pass through the region undeflected.
    2. Relevant equations
    Thinking of using
    F=qvxB
    but not sure.
    3. The attempt at a solution
    Substituting v from info into Lornetz force equation but it doesn't seem to answer the question.
  3. Nov 9, 2009 #2
    lanedance
    so for the ions to pass through unaffected, the force due to the elctric field & the motion through the magnetic must be equal & opposite (ie exactly cancel)
  4. Nov 9, 2009 #3
    So would it be more accurate to use
    qE=qvxB
    and then substitute in the v equation?
  5. Nov 9, 2009 #4
    lanedance
    sounds like a reasonable idea to me, give it a try
    couple of pointers though, just be careful with your signs as the forces neecd to cancel out
    now you could expand a vector triple product or make use of the orthoganalilty of the vectors in teh question & look at the magnitudes...
  6. Nov 12, 2009 #5
    gabbagabbahey
    If I were you, I would use the general form of the Lorentz force law [itex]\textbf{F}=q(\textbf{E}+\textbf{v}\times\textbf{B})[/itex], and plug in the velocity you are given...after using some vector triple product identities, you should find that the force on each ion [itex]\textbf{F}[/itex] is zero.
