Which Salt Produces the Lowest Carbonate Ion Concentration?
  • Thread starter Thread starter Soaring Crane
    Equilibrium Ion
Barium carbonate (BaCO3) produces the lowest concentration of carbonate ions in solution due to its low solubility product constant (Ksp) of 2.6x10-9, indicating a strong favoring of reactants at equilibrium. The lower the Ksp value, the less the salt dissociates, resulting in fewer carbonate ions. The discussion clarifies that the term "equilibrium constant" should refer to solubility products in this context. To determine carbonate ion concentration, one must consider the relationship between the carbonate and barium ion concentrations in the solubility product equation. Overall, barium carbonate is confirmed as the salt yielding the lowest carbonate ion concentration.
Soaring Crane
The equilibrium constants are given for the following salts
MgCO3 = 6.8x10-6
CaCO3 = 5.0x10-9
BaCO3 = 2.6x10-9
What is the name of the salt that will produce the lowest concentration of carbonate ion in solution? Write the name not the chemical formula.
Is it barium carbonate?? Is there a direct relationship between carbonate concentration and E_c?
Thanks.
Yes, I think you are correct. The lower the Kc value, the more the reactants are favored (equilibrium position is far to the left), which would mean less dissociation, which would yield the lowest concentration of the carbonate ion on the products side.
MgCO3 = 6.8x10-6
CaCO3 = 5.0x10-9
BaCO3 = 2.6x10-9
As worded it doesn't make any sense. There is no such thing as an equilibrium constant for a given substance. There is an equilibrium constant for a given reaction.
You are probably talking about solubility products. If so, you are right.
As for the concentration - write reaction equation, write equation for solubility product. What is relation between concentration of carbonate ion and barium ion? Substitute.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
11K
