Lowest Ionization Potential: Atom e (55 133 Cs)
In summary, the element with the lowest ionization potential is Cs (cesium). This is because it has one lone electron in the outermost energy level, making it easy to remove. The other elements have filled energy levels, making their ionization potentials higher.
yxgao
123
Which of the following atoms has the lowest ionization potential?
a. 2 4 He
b. 7 14 N
c. 8 16 O
d. 18 40 Ar
e. 55 133 Cs
The answer is e. Can someone explain the general concepts and reasoning behind this? Thanks,
--YG
In my humble opinion this is dirty chemistry... The theory behind this goes back to electron shells in elementary chemistry for example the s1, s2, p1, s3, p2, d1 and so on. It is a matter of knowing which shells fill how man 'slots' there are in each level and intuiting the qualitative ionization potential. The s shells have 2 slots, the p shells have 6, the d shells have 10,and the f shells have 14... You can figure out where the electrons are with simple subtraction knowing the patterns of filling. Remember that the s orbitals of the n+1 level typically fill before the d orbitals of level n. It's easy to note the pattern of Ionization potential when shown a chart of them, check one out it'll be a tremendous help.
A) He; Helium is going to have a relatively high ionization potential because it has only two electrons which completely fill the lowest (and closest to positive nucleus) energy shell. {2 electrons in S1} 24.5 eV
B) N; Nitrogen fills up the lowest energy shell the s2 orbital and half of the p1 orbital (half an orbital is stabilier than half +1 of an orbital in the lower atomic numbers).{2 in S1, 2 in S2, and 3 in p1} 14.5eV
C) O; Oxygen is Nitrogen plus one and as mentioned above half a full orbital is stabiler than half plus one at this atomic level.{2 in S1, 2 in S2, 4 in p1} 13.6eV
D) Ar; Argon has filled S1, S2, P1, S3, and P1. Since it has filled them it has a high ionization potential of 15.8 eV.
E) Cs; Cesium is by far the best choice of these elements for the lowest ionization energy. It has S1->5 filled, p1->3 filled, and d1 and 2 filled. There is a lonesome electron in the 6th S orbital that is far out from the nucleus which is very easily removed due to it's distance and the fact that it is alone in an orbital. {2 in S1->5, 6 in p1->3, 10 in d1,2 and only 1 in S6.} IP of 3.9eV
I hope this helped, I'm not the best at exlpaining stupid chemistry!
Bored CSMPhysicist
The ionization potential of an atom refers to the amount of energy required to remove an electron from the atom. The lower the ionization potential, the easier it is to remove an electron from the atom. In this case, the atom with the lowest ionization potential is 55 133 Cs, also known as cesium.
Cesium has the lowest ionization potential because it has the largest atomic radius among these atoms. This means that the outermost electron in cesium is farther away from the nucleus compared to the other atoms. As a result, it requires less energy to remove the outermost electron in cesium, making it the atom with the lowest ionization potential.
On the other hand, atoms such as helium, nitrogen, oxygen, and argon have smaller atomic radii, meaning their outermost electrons are closer to the nucleus. This makes it harder to remove an electron from these atoms, resulting in higher ionization potentials.
In summary, the atom with the lowest ionization potential is 55 133 Cs because it has the largest atomic radius, making it easier to remove an electron from the atom.
1. What is the meaning of "Lowest Ionization Potential"?
The lowest ionization potential refers to the amount of energy required to remove an electron from an atom. It is a measure of how tightly an electron is held within an atom's outermost energy level.
2. Why is Cs (Cesium) used as the standard for measuring ionization potential?
Cs (Cesium) is used as the standard for measuring ionization potential because it has the lowest ionization potential of all elements on the periodic table. This makes it easier to compare and measure the ionization potential of other elements.
3. How is the ionization potential of an atom measured?
The ionization potential of an atom is measured by using a device called a mass spectrometer. This instrument measures the mass and charge of ions produced from the atom's ionization, allowing for the calculation of the ionization potential.
4. What does it mean when an atom has a lower ionization potential?
An atom with a lower ionization potential means that it is easier to remove an electron from its outermost energy level. This often indicates a higher reactivity and a tendency to form chemical bonds with other atoms.
5. How does ionization potential affect the properties of an element?
The ionization potential of an element can affect its properties in several ways. A lower ionization potential can make an element more reactive and likely to form compounds. It can also affect the element's electrical conductivity and its ability to participate in chemical reactions.
  • Beyond the Standard Models
12K
