IR burglar alarm
  1. Oct 3, 2009 #1
    I am trying to make burglar alarm which is to be triggred whenever someone crosses the IR beam emmited by a IR transmitter circuit.
    I will place the transmitter in one side of the corridor and reciever on the other site.
    I want to use TSOP1556 in the reciever module. So any help will be greatly appriciated.
  3. Oct 3, 2009 #2
    You might like to have a look at the following page:
    As you can see, there are alarms for everything.
    Unfortunately, alarms are also hard work. There is a lot of tedious running of wires and wiring of switches etc.
    Then there is the never ending list of "what-if"s.
    What if some bad guy crawls under the infra red beam? If you put it lower, what if your dog sets it off?
    What if the owner sets it off himself? How does he reset it without waking the neighborhood?
    The actual sender and receiver setup is the fun part. Knowing what to do next is the hard part.
    One way would be to hunt around on Internet and find some setup that you like the look of and follow it exactly.
    Another way would be to go to an electronics store and come home with some boxes that make up a burglar alarm. Then put it all together.
    Having said all that, the output of your receiver will be low if the IR signal is being received but high if the signal is blocked by something like a bad guy.
    Pin 4 (reset pin) of a 555 chip must be held high for the chip to oscillate.
    So, if you had the output of the receiver connected to pin 4 of a 555 chip and the rest of the 555 set up to oscillate in astable mode, you could make quite a lot of noise whenever the beam was blocked.
    You would really like to make a lot of noise for some time after the beam was blocked, though, so it was still making noise as the bad guy ran off down the street. So, even a simple system starts to get complicated.
    You could use a monostable 555 to hold the reset pin of another 555 high while it oscillated.
    But everyone would end up doing it a different way.
  4. Oct 3, 2009 #3
    One thing I am confused about TSOP1556 is that
    Some say that when it receives a continuous signal at 56KHz the output is low and whenever you obstruct it, its output will be high again.
    But the datasheet tells me that it ignores continuous signal at 56Khz. It only responds to interrupting (bursts) signal at 56Khz.
    From my experience, if I direct a continuous signal at 56Khz to the receiver, at first the output will be low, but soon becomes high again at begins to ignore the signal. When I obstruct the signal, still no change. But When the obstruction is removed the out becomes low again for a short time.
    I have used this property to make the alarm. But the problem is it neither detects very fast motion nor detects the slow one. It detects only medium motion.
  5. Oct 3, 2009 #4
    It is easy to generate pulses but send them in bursts, but I haven't seen one that needed that.
    I have one on 38 KHz which just goes low on the output if it gets 38 KHz IR light pulses, so maybe that is the sort you need.
  6. Oct 3, 2009 #5
    Actually, I have already developed one such. But the problem is, it don't responds if you interrupt the beam. It only responds if you leave the interruption quickly (thereby simulating a burst, i think).
Similar Threads - burglar alarm Date
Alarm clock DIY Nov 6, 2016
Alarm Clock and Wiring Jul 23, 2015
Setting of RFID Alarms Jul 3, 2015
Running 3 motors in circuit, where to insert lipo alarm? Mar 11, 2015
Mock burglar system. Infrared. Nov 24, 2011
