Iron loss curve estimation
In summary, the individual is asking for advice on how to calculate iron loss in a permanent magnet synchronous machine with a speed of 24000 rpm (800 Hz) when the provided data sheet only includes frequencies up to 2500 Hz. Possible solutions include using curve fitting techniques or finite element analysis software, but it is also recommended to reach out to the manufacturer for more accurate data.
HerrWitz
Hi all,
I am recently calculating the iron loss in a permanent magnet synchronous machine with a speed of 24000 rpm (electrical frequency 800 Hz). However, the iron loss data from the data sheet is not sufficient since only frequency of 50 Hz, 100 Hz, 200 Hz, 400 Hz, 1000 Hz and 2500 Hz are given.
To calculate the iron loss, up to 13th harmonic (10400 Hz) has to be considered in this case. Since there is no prototype machine available, is there a way (e.g. curve fitting) to estimate the iron loss data in higher frequencies?
Thank you!
Hello,
Thank you for sharing your question and interest in calculating iron loss in a permanent magnet synchronous machine. I understand that the data sheet you have only provides information up to 2500 Hz, while you need to consider up to the 13th harmonic (10400 Hz) for your calculations.
One option for estimating the iron loss data in higher frequencies is to use curve fitting techniques. This involves using mathematical models to approximate the data and fill in any missing values. However, this method may not always be accurate as it relies on assumptions and may not capture the true behavior of the material at higher frequencies.
Another approach is to use finite element analysis (FEA) software, which can simulate the behavior of the material at different frequencies. This method may provide more accurate results, but it requires expertise in using the software and may be time-consuming.
If possible, I would also suggest reaching out to the manufacturer of the permanent magnet synchronous machine for additional data or information on how to estimate the iron loss at higher frequencies. They may have conducted tests or simulations at higher frequencies and can provide more accurate data for your calculations.
I hope this information helps and wish you success in your calculations.
1. What is an iron loss curve?
An iron loss curve is a graphical representation of the relationship between the magnetic flux density and the corresponding iron loss in a specific type of electrical steel. It is used to estimate the amount of energy that is dissipated as heat when an alternating current is passed through the steel.
2. Why is it important to estimate iron loss curves?
Estimating iron loss curves is important in the design and optimization of electrical machines, such as motors and transformers. It allows engineers to determine the most efficient type of steel to use for a specific application and to accurately predict the performance and operating temperature of the machine.
3. How are iron loss curves estimated?
Iron loss curves are typically estimated through laboratory testing using specialized equipment such as a single sheet tester or an epstein tester. These tests measure the magnetic flux density and corresponding iron loss at various frequencies and amplitudes, and the data is then used to create the curve.
4. What factors affect the shape of an iron loss curve?
The shape of an iron loss curve is affected by several factors, including the type and grade of electrical steel, the frequency and amplitude of the alternating current, and the temperature of the steel. Other factors such as the coating on the steel and the geometry of the sample can also impact the curve.
5. Are there different types of iron loss curves?
Yes, there are different types of iron loss curves for different types of electrical steel, such as silicon steel, nickel-iron alloys, and cobalt-iron alloys. The shape and characteristics of the curve can vary depending on the composition and properties of the steel, making it important to select the appropriate curve for a specific application.
  • Electrical Engineering
  • Mechanical Engineering
