Irrational Numbers
  • Thread starter kingwinner
I know that √2 is irrational (and I've seen the proof).
Now, what is the fastest way to justify that 2√2, 2-√2, 17√(1/2) are irrational? (they definitely "seem" to be irrational numbers to me) Can all/any these follow immediately from the fact that √2 is irrational?
Thanks!
Answers and Replies
Dick
26,260
619
The product of an irrational and a nonzero rational is always irrational. Prove this, it's not hard. The sum of an irrational and a rational is always irrational. Prove this, also not hard. This last one is not completely trivial. You just have to think about prime factorization. It's basically the same proof as that the sqrt(2) is irrational.
Let me try the last one,
Suppose
17√(1/2)=m/n
=> n17=2 m17
By unique prime facotrization, 2 must occur as a prime factor of n (since the right side has a "2"), so on left side, 2 to the exponent a multiple of 17
On the right side, 2 to the exponent (a multiple of 17) + 1
Contradiction!
So 17√(1/2) must be irrational. <====Is this proof correct?
On the other hand, I am still having trouble with understanding why 2√2 and 2-√2 are irrational. How can you know for sure that
"The product of an irrational and a nonzero rational is always irrational"
& "The sum of an irrational and a rational is always irrational" ?
I have no idea how to prove those...
Thanks for explaining!
NateTG
2,450
Assume, by contradiction that [itex]2\sqrt{2}[/itex] is rational, then you can write it as:
[itex]\frac{a}{b}[/itex]
with integers [itex]a,b[/itex], but then
[itex]\sqrt{2}=\frac{a}{2b}[/itex]
contradicts that [itex]\sqrt{2}[/itex] is irrational.
Dick
26,260
619
Suppose
17√(1/2)=m/n
=> n17=2 m17
Contradiction!
You aren't quite getting the 2^(1/17) proof either. Look up and understand the sqrt(2) proof. You HAVE to say "assume 2^(17)=m/n is in lowest terms", i.e. gcd(m,n)=1. Now you say 2*n^17=m^17. So m is even. So 2^17 divides 2*n^17. So 2 divides n. So n is even. Now what?
But I don't see where is it going wrong in the logic of my proof, would you (or anybody else) mind pointing it out, please?
Proof:
Suppose 17√(1/2)=m/n
=> n17 = 2 m17
Now factor n and m into primes, say
n=p1a1...pkak
m=q1b1...qkbk
where pi, qj are distinct primes
Then
p117a1...pk17ak=2 q117b1...qk17bk
If these are equal, then since 2 occurs in the prime facotrization on the right side, it must occur on the left side (by uniqueness of prime factorization), so 2=pi for some i. Also, 2 MAY occur in one of qj
So left side we have 217ai for some integer ai
Right side we have 2 x 217bj for some integer bj
So it's impossible for these 2 numbers to be equal. Factorization into primes is unique, but 217ai cannot be equal to 2 x 217bj)
And my method also seems to work in a more general situation like proving that 3√(2/7) is irrational, too. But the method of proving that √2 is irrational doesn't seem to work here...
Please let me know if I am wrong anywhere.
Thanks!
Dick
26,260
619
I believe you. 17*ai=17*bi+1 doesn't work. 1 isn't divisible by 17. But it really is the same proof as for sqrt(2). In that case you get 2*ai=2*bi+1. Still doesn't work. 1 isn't divisible by 2 either.
Is there a neat way to prove that 3√(2/7) is irrational?
NateTG
2,450
You might as well just move on to a generic proof for all roots of rational numbers.
In wikipedia, there is a method using the concept of unique prime facotraztion to prove that a number is irrational, so I think my proof on 17√(1/2) being irrational is also correct.
http://en.wikipedia.org/wiki/Square_root_of_two#Proof_by_unique_factorization
17√(1/2)=m/n
But I noticed that there are two BAD cases: m=1 or n=1. No prime factorizations exist, so the step in my proof
"...Now factor n and m into primes, say
n=p1a1...pkak
m=q1b1...qkbk
where pi, qj are distinct primes"
is not valid. How can I actually prove that it also works in these 2 cases?
Can somebody help me, please?
Tom Mattson
Staff Emeritus
The proof? There isn't just one!
Are you aware of the following result?
Theorem: The Rational Root Theorem (RRT)
Let [itex]a_nx^n+...+a_1x+a_0=0[/itex] be a polynomial equation with [itex]a_i\in\mathbb{Z}[/itex] for all [itex]i[/itex], and with [itex]a_n,a_0\neq 0[/itex]. Then [itex]p/q[/itex] be a rational root for the equation with [itex]p[/itex] relatively prime to [itex]q[/itex] and [itex]q\neq 0[/itex].
Then:
(i) [itex]p[/itex] divides [itex]a_0[/itex], and
(ii) [itex]q[/itex] divides [itex]a_n[/itex].
Now consider the equation [itex]x^2-2=0[/itex], which clearly has [itex]\sqrt{2}[/itex] as a root. By RRT, the only possible rational roots are -2,-1,1,2. But none of them works!
Therefore, [itex]\sqrt{2}[/itex] is irrational.
I don't know about the fastest way, but a viable way would be to construct polynomial equations as I have done above, and apply RRT. Here, I'll do another one for you.
Let [itex]x=2\sqrt{2}[/itex]. Then [itex]x^2=8[/itex], or [itex]x^2-8=0[/itex].
Clearly, this equation has [itex]2\sqrt{2}[/itex] as a root. By RRT, the only possible rational roots to that equation are -8,-4,-2,-1,1,2,4,8. But none of these works. Therefore, [itex]2\sqrt{2}[/itex] is irrational.
Comprede?
Then:
Comprede?
Sorry about that, but I thought that was only one way before, since only one proof in presented in my class...but now I am aware of many proofs...
17√(1/2)=m/n
n=p1a1...pkak
m=q1b1...qkbk
Does anyone have any idea how to deal with the case m=1 or n=1? I am stuck here...
sorry for being offtopic and interfering.. but how can one proove that √2 is irrational?
Dick
26,260
619
(1/2)^(1/17)=1/n -> 2=n^(17). That's ridiculous. 2 isn't the 17th power of any integer. (1/2)^(1/17)=m/1 -> 2*m^(17)=1. Also ridiculous. 1/2 isn't the 17th power of any integer. Was that really so mysterious?
Related Threads on Irrational Numbers
  • Last Post
  • Last Post
  • Last Post
12K
  • Last Post
  • Last Post
  • Last Post
18K
