Irrationality of Rational Exponents
In summary, the definition for a^{m/n} where m and n are integers and a is any real number is a^{\frac{m}{n}}=Exp(\frac{m}{n}Log(a)), where Exp(x)=1+\sum_{i=1}^{\infty}\frac{x^{i}}{i!} and Log(x) is the inverse of the Exp function. This definition only works for positive numbers. For negative numbers, a more complex definition involving complex numbers may be necessary. There is also a convention to interpret a^{\frac{1}{2}} as a positive number, but it can be multi-valued in certain cases.
agro
46
What's actually the definition of [itex]a^{m/n}[/itex] where m and n are integers and a is any real number? Suppose I define it as the n-th square root of [itex]a^m[/itex]. Wouldn't it be inconsistent with other stuffs?
What stuffs? For example, [itex]a^1[/itex] is supposed to be a. But 1 = 2/2 and, using my earlier definition, [itex]a^{2/2}=\sqrt{a^2} = |a|[/itex]. Thus if we use my definition, [itex]a^1[/itex] wouldn't be the same as [itex]a^{2/2}[/itex] for a < 0.
So, what's the definition in use for [itex]a^{m/n}[/itex]?
Thanks a lot.
Mathematics news on Phys.org
Short answer:
[tex]a^{\frac{m}{n}}=Exp(\frac{m}{n}Log(a))[/tex]
where:
[tex]Exp(x)=1+\sum_{i=1}^{\infty}\frac{x^{i}}{i!}[/tex]
Edit: This works only for positive numbers "a".
It's "easy" to create an exponent form for a=0.
For negative numbers a, I think you'll have to resort to complex numbers definitions of powers, which might involve delicate questions concerning the logaritmic branch you use.
I'm not familiar with how these issues concerned with negative a's are actually resolved by mathematicians.
I think one thing you've missed argo is that [itex](a^2)^{\frac{1}{2}} = \pm \sqrt{a^2}[/itex]
If we specifically state that a has only one value then we will know it is either [itex]\sqrt{a^2}[/itex] or [itex]-\sqrt{a^2}[/itex]
I don't think so, jcsd:
I am quite certain that [tex]a^{\frac{1}{2}}[/tex] signifies the positive number.
It depends on the context, arildno.
How would you express the question "what number(s), when squared, produce the value a"?
In some cases you do want only the positive roots, but some times you are interested in all roots; when you are, it is often true that none of them are purely positive (in the sense that they are complex numbers; e.g., the fifth roots of 1+0.1i).
I was talking about the convention of using the expression [tex]a^{\frac{1}{2}}[/tex] as a positive number, not every solution of every imaginable equation.
Since you said "as a positive number", I take it you are talking about real numbers. In that case, ax for x negative, or fractional, is defined only for a> 0.
You're right it is defined as the principal value.
This matter is nothing but a definition, but I had a text that saw it this way:
[tex]\sqrt{a^2}=[/tex] absolute value of a if a >0 and =-absolute value of a if a< 0. That is to say, you have to assign that value depending upon the case. Does that make sense?
No, that doesn't make sense. That would be the same as saying,
"Since 4=(-2)2, then [tex]\sqrt(4)= -2[/tex]" as well as
"Since 4=(2)2, then [tex]\sqrt(4)= 2[/tex]".
[tex]\sqrt{4}= 2[/tex] no matter how you GOT the 4!
Agreed. In my edit to my original reply, I broached the subject of negative a's (in an admittedly inadequate manner), and thought this subject must probably be resolved by treating a as a special case of a complex number.
Of course once you start using complex numbers many functions (including fractional powers) become many-valued. Real valued functions on the real numbers are always, by definition, single valued.
I'm not sure i understand your semantic distinction that means sqrt is many valued from C to C, but not from R to R. Functions are single valued, though we often refer to things as many-valued functions to indicate that some choice is usually required, though this doesn't require the introduction of complex numbers.
You could be right, but that book I was referring to was a 9th grade text on Trigomentry, if I remember right. Trig signs are usually assigned according to the quatrant they are in.
What would you do with this? sin(x)=[tex]\sqrt{1-cos(x)^2}[/tex]
I think you answered your own question. If the sign depends on the quadrant, then the formula [itex]\sin(x)=\sqrt{1-\cos(x)^2}[/itex] is incomplete; you must multiply by a sign. Certainly the formula is not the same as [itex]\sin^2(x)+\cos^2(x)=1[/itex].
What are rational exponents?
Rational exponents are exponents that are expressed as fractions, where the numerator is the power and the denominator is the root. For example, 41/2 represents the square root of 4, which is 2.
Why are rational exponents considered irrational?
Rational exponents are considered irrational because they cannot always be expressed as a simple fraction or decimal. For example, the square root of 2 cannot be expressed as a fraction or decimal, so it is considered an irrational number.
How do irrational rational exponents differ from rational irrational exponents?
Irrational rational exponents are exponents that are irrational numbers raised to rational powers, such as √21/2. Rational irrational exponents are rational numbers raised to irrational powers, such as 4√2. Both types of exponents result in irrational numbers.
What is the significance of irrational exponents in mathematics?
Irrational exponents are important in mathematics because they allow us to express numbers that cannot be represented as simple fractions or decimals. They also play a crucial role in advanced mathematical concepts such as logarithms and exponential functions.
How are irrational exponents used in real-world applications?
Irrational exponents are used in various fields such as physics, engineering, and finance to model complex systems and make accurate predictions. For example, in physics, irrational exponents are used in equations that describe the behavior of natural phenomena like radioactive decay and population growth.
  • General Math
  • General Math
  • General Math
