Is 1,4-benzoquinone aromatic
  1. Apr 20, 2010 #1
    I am not sure how to use Huckel's rule to determine whether this compound is aromatic or not. It seems that inside the ring, there are only 4 pi electrons, and can the e- between C and oxygen move towards the ring?
  3. Apr 20, 2010 #2
    alxm
    I'll give you a hint: They can't.
  4. Apr 20, 2010 #3
    when we count the no of pi e- , don't we consider the "possible resonance" structure?
    Also, can we say this is a "fully delocalized" system?
  5. Apr 21, 2010 #4
    chemisttree
  6. Apr 22, 2010 #5
    but for C=O , is it possible for us to draw as -C-O+ for prediction( although C is less electronegative than O)
    for molecules with alternative resonance structure, do we need to consider all ?
  7. Apr 22, 2010 #6
    DrDu
    Hueckels rule is derived from MO theory, why do you want to count resonance structures then?
  8. Apr 22, 2010 #7
    so it is really inside the ring?
  9. Apr 22, 2010 #8
    DrDu
    Certainly to some degree. But aromaticity is not a totally well defined concept and Hueckels rules can sometimes be misleading. What about a diamagnetic ring current? NMR shifts of the Carbons and Hydrogens? Are there any experimental results?
  10. Apr 23, 2010 #9
    I wasn't anticipated to use extensive mathematics to explain simple molecules in intermediate organic chemistry courses. I think Huckel's rule is sufficient to explain them. But there are tautomers / one of the resonance structures . Hence, it is important to consider the structure to see if one of them got aromaticity in one structure (e.g. keto-enol tautomerism)
    anyway, the compound is not aromatic.
  11. Apr 23, 2010 #10
    chemisttree
    If you were to produce the correct tautomer, you would have a zwitterion where the formal charges were on the oxygens. In that case the ring itself would be aromatic. But if you consider the ground state, it isn't. That zwitterion is waay higher in energy than the rather modest aromatic stabilization energy you get as a result of shuffling the electrons into just the right locations.
