Is d/dx e^-x = e^-x ?
  • Thread starter matttan
1st qs: I know that d/dx of e^x is e^x, but how bout negative power?(see example below)
and 2nd qs: If the power if not x but 3x + 4, y=e^(3x+4) then is d/dx e^(3x+4) = e^(3x+4) ?
:confused:
epenguin
651
You mean d(e^-x)/dx
Do you know what is df[g(x)]/dx in general?
25
You mean d(e^-x)/dx
I will use other notation:smile:
If f(x)=e^-x then do f'(x)=e^-x ?
epenguin
651
In another notation do you know what [f(g(x))]' is ?
(And apart from calculation it is possible to visualise it.)
25
Yup I think I know f(g(x)) but are u using this to explain d/dx e^-x = e^-x and before that, is d/dx e^-x = e^-x correct?
:confused:
1. d(e^-x)/dx = -e^-x, use the chain rule to solve it.
2. Again, use the chain rule, take the derivative of e first then 3x+4
epenguin
651
e-x is just a very simple example of f[g(x)] .
To be asking this question you must have done some calculus lessons before. It is a mistake to never go back to look at earlier lessons.
OK - what is f'(-x) in general??
symbolipoint
Education Advisor
962
:confused:
For question #1, e-x=[tex]\frac{1}{e^x}[/tex]
So you are looking for the derivative of a rational function.
EDIT: the formatting tool did not work. RightSide is supposed to be 1/(e^x)
symbolipoint
Education Advisor
962
Actually, I am not certain if my intended response in #9 is correct; I BELIEVE it is correct only because I could understand the meaning of negative exponent. (For me, been a long time since Calculus)
161
d/dx of e^-x = -e^-x
if all else fails or you want further explaination try using the chain rule
when e^-x the coefficiant of x is -1 right? so you time e by -1 (not very clear i know sorry)
is that the answer your looking for?
1,056
The way I like to look at that problem is: Let Y = e^(-x), then InY = -x. While we know that the derivative of -x = -1, it is also necessary to know the derivative of InY, which I leave to others.
(So that this way is actually a little advanced and is part of differential equations.)
HallsofIvy
41,731
884
:confused:
What people have been trying to tell you is to use the chain rule.
The derivative of f(g)(x) is [f(g)(x)]'= f'(g)(x)g'(x) or df(g)(x)/dx= (d(f(g))/dg)(dg/dx). Now to differentiate e-x so that g(x)= -x. Then f(g)= eg and, apparently, you know that d eg/dg= eg. What is dg/dx= d(-x)/dx?
Multiply those together.
epenguin
651
Yes, you need to go back to basics.
Plus get the habit of checking for what sounds right and reasonable, plausible. E.g. you probably know ex is always positive and always increases with x. I.e. d(ex)/dx is always positive.
So e-x which is 1/ex, must be positive and always decreasing with increasing x. i.e. d(e-x)/dx is always negative. One way to know your initial conjecture had to be wrong.
How do you differentiate
e^3x (sinx+2cosx)
i understand that you use the product rule but its the very last bit of the expression that confusses me
do i use the chain rule on the (sinx+2cosx) because im unsure hows to differentiate the 2cosx
i know cosx goes to -sinx but what happens to the number at the front?
It's a constant, and d(c*f(x))/dx=c*d(f(x))/dx
As an example, the derivative of 2x is 2. Nothing changes about that when you do trig.
HallsofIvy
41,731
884
I am very confused as to what you are doing. Where are you getting these problems if not from a calculus book? And if you have a calculus book then surely it has the basic rules like (cf(x))'= c f'(x), (f+ g)'(x)= f'(x)+ g'(x), (fg)'(x)= f'(x)g(x)+ f(x)g'(x), (f/g)'(x)= (f'(x)g(x)- f(x)g'(x))/g2(x), and the chain rule. Those are what you need to learn.
Fredrik
Staff Emeritus
406
You don't need the chain rule for 2 cos x. This is covered by the product rule: (fg)'(x)=f'(x)g(x)+f(x)g'(x). If f and g are defined by f(x)=2 and g(x)=cos x, the first term vanishes (f'(x)=0), so you're left with f(x)g'(x)=2 (-sin x).
Edit: Oops, I didn't realize that there was a second page of posts where this had already been answered.
Related Threads for: Is d/dx e^-x = e^-x ?
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
11K
Hot Threads
