Exploring Relativity: Is Everything Absolute in Our Universe?
  • Thread starter quawa99
  • Tags
    Relative
In summary, relativistic mass is not absolute and is something of a matter of taste which one considers to be "mass".
quawa99
67
Is everything we know relative or is there something absolute in this universe?
This is rather vague. Let's start with something clearer.
Do you know about Special Relativity? Yes? Then what have you concluded from that?
No? Then maybe we can start you with that.
Secondly, what do you mean by "everything"? There are covariant/invariant values and expressions in physics that are NOT relative.
Zz.
Zz.
I just have a basic idea about special theory of relativity.by everything I meant the physical quantities like energy,mass,velocity.
From special theory of relativity I have concluded that velocity of light is the same for all observers so maybe velocity of light is not relative?
The speed of light is absolute. So is mass. The charge of an electron is absolute. Etc
Isn't mass relative?
Mass is NOT absolute.
##M=\frac{M_0}{\sqrt{1- \frac{v^2}{c^2}}}##
EDIT
Mass, length, time, kinetic energy are all relative.
Charge, spin, baryon no. etc are not relative
I believe it depends on how you learn special relativity. I learned it as mass being absolute, but I only just learned it in a classroom this semester, so I'm not an expert.
edit-
Why is this necessary?
Mass?But I heard that mass increases with Speed(Kinetic Energy)
EDIT:Look at the Equation given by Enigman.
So bottom line velocity of light and charge are the two physical quantities which aren't relative ?
I hate arguing anything that I'm not too confident in, but for the sake of education!:
I learned relativistic kinetic energy as:
[itex]T=(\gamma_u - 1)mc^2[/itex] where mass is absolute. This is from the book "Modern Physics" second edition by Randy Harris
Also, total relativistic energy:
[itex]E=\gamma_u mc^2[/itex]. Where mass is absolute.
edit-
There are most certainly other quantities as well..
Isn't charge relative because electric and magnetic fields are relative?
No charge is a Lorentz invariant. This follows from local charge conservation which is itself a consequence of Maxwell's equations.
Rest mass (more appropriately called invariant mass) is also a Lorentz invariant.
Perhaps you are talking about the rest mass or the invariant mass? This the mass observed in an inertial frame where the object in question is at rest. (I perhaps should have mentioned this before)
gives the mass as observed from a frame in which object in question is moving with velocity v.
But often mass and rest mass are used interchangeably
Derivation here- http://www.scribd.com/doc/98591006/Simple-Derivation-for-Relativistic-Mass.
(WBN beat me to it...)
The quantity ##M## in that equation is not frame-invariant, but ##M_0## is. It's something of a matter of taste which one you consider to be "mass", and that taste has changed over the years.
Yes, I was talking about relative or 'observed mass' as I thought it would be obvious from the context and not rest mass which is by definition frame-invariant.
This is of course correct, provided m represents relative mass. And as ##m_{rel}=\gamma m##
The mass-energy equation reduces to ##E=m_{rel} c^2##.
##m_{rel}## is the mass that would be observed from a frame in which the object moves with velocity v and m is the mass in the frame in which relative velocity is zero.
You may want to read-
Y'know, the more things change, the more they remain the same. This thing keeps coming back like an unwanted guest.
https://www.physicsforums.com/showthread.php?t=642188
Please note this FACT: when you read the mass values of the various particles in the Particle Data Book, you'll notice that they never cite the corresponding speed. If mass is "relative", then there will not be a unique, unambiguous value.
Zz.
Zz.
Thanks for this link. This person has some very interesting points :)
ZapperZ said:
If by "this person" you meant Lev Okun, he is on this forum:
https://www.physicsforums.com/showthread.php?t=696144
Zz.
Why would I be referring to Lev Okun? He doesn't even make an appearance in the link I quoted...
e-
And when you say "Zz." at the end of your post it makes it seem like you are facepalming at the post you quoted lol
Zz.
Lev Okun's name appears in the link if you scroll down to my post. So I mistakenly thought you were referring to his view on why we shouldn't be using the term "relativistic mass". The OP's view in that link isn't that interesting considering that it was mainly a question that needs clarification.
In any case, I obviously thought you were referring to something else.
Zz.
ZapperZ said:
We may need a FAQ entry on this topic since this keeps popping up.
This view seems pretty interesting too...
:biggrin:
P.S. Don't listen too him the Zz is one of the best signatures in the forum.
Still, if he wanted to facepalm about an argument on whether mass is relative, which uses the word "invariant", I'd sympathize.
1. What is the theory of relativity?
The theory of relativity is a scientific theory proposed by Albert Einstein in the early 20th century. It describes how the laws of physics apply to objects that are moving at a constant speed in a straight line, and how they differ from objects that are accelerating or in a gravitational field.
2. Is everything absolute in our universe?
According to the theory of relativity, there is no such thing as absolute space or time. Instead, space and time are relative and depend on the observer's frame of reference. This means that the laws of physics are the same for all observers, regardless of their relative motion, but their measurements of space and time may differ.
3. How does relativity impact our understanding of the universe?
The theory of relativity has had a major impact on our understanding of the universe. It has helped us to understand the behavior of objects at high speeds, such as the effects of time dilation and length contraction. It also plays a crucial role in our understanding of gravity and the structure of the universe.
4. What is the difference between special and general relativity?
Special relativity deals with the laws of physics in non-accelerating frames of reference, while general relativity extends these laws to include accelerating frames and the effects of gravity. Special relativity is also limited to flat, uncurved space, while general relativity can explain the curvature of space caused by massive objects.
5. Are there any practical applications of relativity?
Yes, there are several practical applications of relativity, including the development of GPS technology, which relies on the precise synchronization of clocks in orbit and on the ground. Relativity also plays a crucial role in nuclear energy and particle accelerators, allowing us to study the behavior of particles at high speeds.
  • Other Physics Topics
9K
  • Cosmology
