Does Glass Actually Flow Over Time?
In summary, the belief that glass is a super-cooled liquid of infinite viscosity is not supported by evidence. The thicker bottom of old windows is due to the manufacturing process, not flow over time. Glass at room temperature is strongly on the solid side of the spectrum and does not flow at a noticeable rate over time. This is evidenced by the lack of observed changes in ancient glass objects and precision lenses. The misconception likely arose due to the crude methods used by medieval glassblowers to make flat glass.
Harut82
didn't know where to post it so I put it hereo:)
do you guys agree with the following?
One common belief is that glass is a super-cooled liquid of practically infinite viscosity when at room temperature. Supporting evidence for this position is that old windows are often thicker at the bottom than at the top. It is then assumed that the glass was once uniform, but has flowed to its new shape.
One possible source of this belief is that when panes of glass were commonly made by glassblowers, the technique that was used was to spin molten glass so as to create a round, mostly flat and even plate (the Crown glass process, described above). This plate was then cut to fit a window. The pieces were not, however, absolutely flat; the edges of the disk would be thicker because of centripetal forces. When actually installed in a window frame, the glass would be placed thicker side down for the sake of stability. Also, the sparkle is greater and the visual effect stronger when the thicker side is down. There is anecdotal evidence that occasionally such glass has been found thinner side down, as would be caused by carelessness at the time of installation.
Writing in the American Journal of Physics, physicist Edgar D. Zanotto states "...the predicted relaxation time for GeO2 at room temperature is 1032 years. Hence, the relaxation period (characteristic flow time) of cathedral glasses would be even longer" (Am. J. Phys, 66(5):392-5, May 1998). In layperson's terms, he wrote that glass at room temperature is very strongly on the solid side of the spectrum from solids to liquids.
Evidence against glass flow
If medieval glass has flowed perceptibly, then ancient Roman and Egyptian objects should have flowed proportionately more—but this is not observed.
If glass flows at a rate that allows changes to be seen with the naked eye after centuries, then changes in optical telescope mirrors should be observable (by interferometry) in a matter of days—but this also is not observed. Similarly, it should not be possible to see Newton's rings between decade-old fragments of window glass—but this can in fact be quite easily done.
Likewise, precision optical lenses and mirrors used in microscopes and telescopes should gradually deform and lose focus. This is also not observed.
http://encyclopedia.thefreedictionary.com/glass
Perhaps windows are more prone to flow because they are in a harsher environment while telescope and other lenses are typically well protected. Perhaps it's the shape of windows and that they're typically much larger and stand up right while lenses are typically smaller, lighter, and are more rounded shaped.
Whether or not glass is a solid really depends on the definition of solid. If I remember correctly from chemistry, a solid has a definite melting point and breaks with blunt edges while semi-solids have a melting temperature range and break with sharp edges.
I believe that glass is what is referred to as an Amorphous Solid.
Yes, that is correct, Harut.
Jelfish, small telescopes may be thicker and well-supported, but large research telescopes are enormous and so heavy that they require special external structure to keep them from bending/breaking under their own weight (in fact, structural stability is a severe impediment to making large refractors). So the forces at work there are far larger than on windows and any change noticeable in a window in decades by the naked eye would indeed be noticeable in a telescope in days. And don't forget - many such telescopes are decades old too.
Glass and in fact, most, if not all ceramics flow - but very, very slowly - i.e. it creeps. I can't necessarily vouch for specific cases, but my company specializes in developing models for concrete behavior, including creep.
I don't know about any other materials but common glass doesn't flow over time. The whole notion that it does was a misunderstanding of the way stained glass window were made hundreds of years ago, and as the OP mentioned no ancient glass that we have shows any evidence of flowing over time.
The notion that glass flows over time is just the mistaken thinking of someone who was unaware that medieval glass blowers had not developed a way of making very flat glass of even thickness. The method they had of making flat sheets of glass was very crude by comparison to later methods: you blew the best sphere you could, and then spun it by rolling the blow tube with the hot glass sphere at the end on an elevated rail letting the sphere flatten into a disc as you rolled. The only flat glass they could produce was in disc form, and there's nothing remotely resembling precision in the uniformity of the thickness of these discs. Any piece you cut from such a disc is going to be visibly thicker on one end than another.
As the OP quote points out, for stability and aesthetic reasons the thicker side was most often oriented toward the bottom. It's easy to find examples of pieces where they didn't follow this rule, though, which are thicker at the top. How could that be explained if glass authentically flowed?
This, I think, ought to stand as the best evidence that glass is not flowing:
I'm not sure how anyone can read that and still lend any credence to the obvious mistake made by the person who first happened to notice that cathedral stained window glass seemed to be thicker at the bottom than the top. That person obviously jumped to an erroneous conclusion.
Is glass liquide or Solid?
At the page 1 of Introductory Solid State Physics Second by H.P. Myers states that: From the present point of view, solid state physics is mainly the physics of crystalline solids. Most of the inorganic solids we encounter in our daily lives are crystalline, the notable exceptions being glass, which is supercooled liquid, and soot which is amorphous...
Therefore glass is counted as Solid materials.
Regards Kouros
Zoob, that's not entirely correct. What is correct is that (silica based) glass does not flow noticeably over a time-scale of centuries. However, independent of the "observation" of uneven windows, physicists have studied the properties of glasses theoretically and arrived at the roughly same conclusion - that glasses flow (and most certainly creep). The only difference between the physical theory and the myth is the time-constant for flow. Theory predicts that this is of the order of about 1010 years or thereabouts for silical glass - not anything as small as a few centuries.
Is the glass solid or liquids?
It depends in which way one classifying the materials. For example one can say that there are crystalline, amorphous inorganic and organic materials in this case we are concerning with crystal structure of the materials. In crystalline solids the atoms are arranged in a regular manner which is significant for their behaviour.
Glass are counted as solid material when we are looking at its structure and behaviour because most of inorganic materials which we are encounter in our daily lives are crystalline, the notable exception being glass which is super cooled liquid.
Myers stated that Solids are not necessary crystalline. They may also be obtained as glasses (page 58)1 and amorphous aggregates that are not crystalline on any significant scale; i.e there is no long-range correlation between atom positions and no translational symmetry.
Short range order over distances corresponding to one or two atomic spacing may arise, the degree of ordering depend on the type of bond that is formed. Amorphous metals are well described as random close-packed structure.
Nevertheless we can imagine the time average of a liquid structure, which may be approximated by radial distribution function (RDF).
Taking the origin as the momentary position of a given atom we define the probability of finding another atom in an element of volume d3 R at distance R from our choosen atom as
N/Vg2(R) d3 R
N/V is the average particle density and g2(R) is call the pair distribution function. Now when R is large let's say > 20 angstrom we do not expect any correlation between position of two atoms and probability can depends only on the size of d3 R and the average density, so g2(R) is unity for large R. At very small distances, g2(R) is zero because two atoms can not occupy the same position. However, for a certain range of values of R, entered around the average particle separation, g2(R) varies in a pronounced manner. For an isotropic liquid, the radial distribution function is defined as RDF=4*piR2 g2(R)
Integration of the RDF between the time limits 0 and R tell us how many atoms are contained within a sphere of radius R described around our chosen atom. One can define higher distribution functions, e.g. the three particles distribution g3(R12,R13) that are important in the liquid, but since no way of obtaining experimental knowledge about them, discussion of liquid and other disordered structure is usually confined to g2(R) and RDF.
1.
This literature about the glass written by H.P.Myers and specifically Second Edition of Introductory Solid State Physics are quite known and are teaching in so many institutions around the world. Printed 2002.
OK, I stand corrected: technically glass flows. Anyone engineering anything they expect to last ten billion years should take this into consideration.
Yes, it is right as you mention glass flow, and different type of glasses have their own time limit, but the point is are we taking into the consideration if really glass is solid or not . The answer to this as Myer stated it is counted as solid, but it is still is under question and as I feel there is some uncertainty about that. What do you think about that?
Oh great. One more thing we have to put on our requirements documents..."must remain operational for 1 billion years."
1. Is glass a liquid or a solid?
The answer to this question is not as straightforward as it may seem. Glass is technically classified as an amorphous solid, meaning it does not have a crystalline structure like most solids. However, it also exhibits some properties of liquids, such as the ability to flow over time.
2. Why do some people say glass is a liquid?
This is a common misconception that stems from the fact that old windows and other glass objects appear thicker at the bottom. However, this is not due to the glass flowing like a liquid, but rather the result of the way glass was made in the past, which caused uneven thickness. Modern glass does not exhibit this phenomenon.
3. How can glass be a solid if it can flow?
Glass is a special type of solid known as an amorphous solid. Unlike crystalline solids, which have a specific arrangement of molecules, amorphous solids have a disordered arrangement. This allows the molecules in glass to move around slowly, giving it the ability to flow over time.
4. What evidence is there to support that glass is a solid?
One piece of evidence is the fact that glass has a definite shape and volume, which are characteristics of solids. Additionally, the molecules in glass do not have the same amount of freedom as those in liquids, and they are held together by strong chemical bonds, further supporting the solid classification.
5. Can glass ever turn into a liquid?
No, glass cannot turn into a liquid at normal temperatures. It can only flow over an extremely long period of time, but it will still retain its solid properties. In order to melt glass and turn it into a liquid, it would have to be heated to temperatures over 1000 degrees Celsius.
  • Beyond the Standard Models
