- #106
sylas
- 9
Xnn said:Appreciate your feedback and understand that Ruddiman's original hypothesis should not be completely accepted. However, my impression it is accepted that there was a pre-industrial age human contribution of roughly 10 ppm CO2 and 100 ppb CH4 to the atmosphere. In addition, we know that over the last 5000 years orbital changes have lead to a gradual cooling of the arctic that is expected to continue for several thousand years. So, absent human activities, we could have expected an expansion of glacial coverage in the northern hemisphere. This doesn't mean that there should have been a rapid expansion of ice conditions, but rather a continuation of what is known as the little ice age. That is, there would have been an gradual icing of the earth, especially in the northern hemisphere.
Fair enough. 10 ppm CO2 is a forcing of about 0.2 W/m2, and 100 ppb CH4 is a forcing of about 0.06 W/m2, using approximation formulae for estimating forcings from a change in greenhouse gas concentrations. (Formulae are in the http://www.grida.no/publications/other/ipcc_tar/?src=/climate/ipcc_tar/wg1/222.htm [Broken].) If climate sensitivity is sufficiently high, this could make a significant difference. Climate sensitivity is about 0.8 +/- 0.4 degrees per W/m2, so this anthropogenic pre-industrial forcing could drive as much as 0.3 degrees... not much more, I think.
I was reacting to the phrase "the world would be icing up". If you mean a little bit of additional glaciation, then yes; but it could easily be taken as something much more than this; a new ice age. I think that is unlikely. The Holocene would more likely continue mild, with small variations and perhaps a very slow cooling trend of the order of fractions of a degree per century.
An example of Holocene cooling trend estimation is
- Kullman, L (1993) http://www.jstor.org/pss/2997659, in Global Ecology and Biogeography Letters 2, pp 181-188.
I've only read the abstract. It derives a cooling trend of 0.12 degrees per millenum, a bit less than one hundredth of the current warming trend. The abstract indicates this value is consistent with the work of Berger on a long interglacial, cited previously. This trend is over some 8000 years, and corresponds to a drop in temperatures of about a degree, which seems about right. It would mean current temperatures are not quite as high as at the Holocene thermal maximum as yet, which makes sense to me. So 0.3 degrees off set from that helps.
We came out of the little ice age mainly because of natural variations, I think; it was not part of a longer trend but more of a dip... and mostly regional rather than global.
Unfortunately, I haven't been able to locate copies of the papers criticizing Ruddiman's work to study. However, I notice that a integrated analysis of solar insolation such as that performed by Huyber (figure 2E) appears to distinguish between recent solar forcing and that of 420 Kyrs ago.
http://www.sciencemag.org/cgi/reprint/313/5786/508.pdf [Broken]
Found a freely available preprint of that:
- Huybers, P.J. (2006) Early Pleistocene glacial cycles and the integrated summer insolation forcing in Science 313(5786): pp 508-511.
However, the 100-ky glacial cycles of the late Pleistocene have a more complicated relationship with the forcing, and their explanation will require a better understanding of ice sheet–climate interactions.
420,000 years ago is still part of the late Pleistocene. The paper seems to divide early and late at about 1 million years ago, according to figure 2E, which is all labeled as part of the late Pleistocene.There's another source you might find interesting. Ruddiman has a guest post available at the realclimate blog, which is a deliberate attempt to communicate issues in climate science to a wider general audience. He discusses the contrasts between his ideas and those of Berger and indicates what it would take (in his view) to distinguish them. It is a nice informal and open ended discussion.
Cheers -- sylas
