Is $\mathcal{A}$ a $\sigma$-algebra over $M$?
  • MHB
  • Thread starter mathmari
Yes, you are correct! There are indeed 15 ways to pick 2 elements from $\mathcal{A}$ since order doesn't matter. Great job! (Smile)
mathmari
MHB
5,049
Hey! :eek:
We have the set $M=\{1,2,3,4\}$. I want to check if the following are $\sigma$-algebras over $M$.
  1. $\mathcal{A}=\{\emptyset, \{1,2\}, \{3,4\}\}$
  2. $\mathcal{A}=\{\emptyset, M, \{1\}, \{2,3,4\}, \{1,2\}, \{3,4\}\}$
  3. $\mathcal{A}=\{\emptyset, M, \{3\}, \{1,2,4\}\}$
  4. $\mathcal{A}=\{\emptyset, M, \{1\}, \{2\}, \{1,2\}, \{3,4\}, \{2,3,4\}, \{1,2,4\}, \{1,3,4\}\}$
$\mathcal{A}$ is a $\sigma$-algebra over $M$ if the following hold:
  • $M$ is in $\mathcal{A}$.
  • If $A$ is in $\mathcal{A}$, then so is the complement of $A$.
  • If $A_n$ is a sequence of elements of $\mathcal{A}$, then the union of the $A_n$s is in $\mathcal{A}$.
I have done the following:
    • $M \notin \mathcal{A}$.
    Therefore, $\mathcal{A}$ is not a $\sigma$-algebra over $M$.
    • $M \in \mathcal{A}$.
    • $\emptyset \in \mathcal{A} \rightarrow \emptyset^c=M\in \mathcal{A}$
      $M \in \mathcal{A} \rightarrow M^c=\emptyset\in \mathcal{A}$
      $\{1\}\in \mathcal{A} \rightarrow \{1\}^c=\{2,3,4\}\in \mathcal{A}$
      $\{2,3,4\} \in \mathcal{A} \rightarrow \{2,3,4\}^c=\{1\}\in \mathcal{A}$
      $\{1,2\} \in \mathcal{A} \rightarrow \{1,2\}^c=\{3,4\}\in \mathcal{A}$
      $\{3,4\} \in \mathcal{A} \rightarrow \{3,4\}^c=\{1,2\}\in \mathcal{A}$
    • Do we have to check if the union of all the elements of $\mathcal{A}$ is again in $\mathcal{A}$ ?
    • $M\in \mathcal{A}$.
      $\{3\} \in \mathcal{A} \rightarrow \{3\}^c=\{1,2,4\}\in \mathcal{A}$
      $\{1,2,4\} \in \mathcal{A} \rightarrow \{1,2,4\}^c=\{3\}\in \mathcal{A}$
      $\{2\} \in \mathcal{A} \rightarrow \{2\}^c=\{1,3,4\}\in \mathcal{A}$
      $\{3,4\}\in \mathcal{A} \rightarrow \{3,4\}^c=\{1,2\}\in \mathcal{A}$
      $\{1,2,4\} \in \mathcal{A} \rightarrow \{1,2,4\}^c=\{3\}\notin \mathcal{A}$
    So, $\mathcal{A}$ is not a $\sigma$-algebra.
Is what I have done correct? Could you give me a hint how we could check the last property? (Wondering)
mathmari said:
[*] Do we have to check if the union of all the elements of $\mathcal{A}$ is again in $\mathcal{A}$ ?
Hey mathmari! (Smile)
Yep. It's all correct.
To check the last property formally we need to check every sequence of elements.
With 6 elements that is $2^6=64$ possible sequences. (Sweating)
However, it suffices if we check every combination of 2 elements.
We can break up the union of a sequence of n elements into a series of unions of 2 elements after all.
With 6 elements that is 6 x 5 = 30 possible sequences.
Furthermore, combinations that contain $\varnothing$ or $M$ trivially satisfy the requirement.
So that leaves us with 4 x 3 = 12 combinations to verify.
Why does this suffice to check every combination of 2 elements? (Wondering)
How do we get that number of possible sequences? I got stuck right now. (Wondering)
Let's take a look at the sequence $(A_1, A_2, A_3, ..., A_n)$.
Then we need that $A_1\cup A_2\cup A_3\cup ...\cup A_n \in \mathcal{A}$ yes?
Or written otherwise that $((((A_1\cup A_2)\cup A_3)\cup ...)\cup A_n) \in \mathcal{A}$.
But we also need that $A_1\cup A_2\in\mathcal A$, since that's also a possible sequence.
Every parenthesized expression of effectively 2 elements must be in $\mathcal A$.
In other words, if we pick each combination of 2 elements and verify that it's in $\mathcal A$, it follows that each sequence that is built from more than 2 elements is also in $\mathcal A$.
In how many ways can we pick 2 elements from $\mathcal A$ if it has 6 elements? (Wondering)
I got it! (Nerd)
We use here the fact that $\emptyset \cup S=S$ and $M\cup S=M$, for any set $S$, right? (Wondering)
So, we have the following:
$\{1\}\cup \{2,3,4\}=M\in \mathcal{A}$
$\{1\}\cup \{1,2\}=\{1,2\}\in \mathcal{A}$
$\{1\}\cup \{3,4\}=\{1,3,4\}\notin \mathcal{A}$
Therefore, $\mathcal{A}$ is not a $\sigma$-algebra.
$\{3\}\cup \{1,2,4\}=M\in \mathcal{A}$
So, $\mathcal{A}$ is a $\sigma$-algebra. Is everything correct? (Wondering)
Aren't there $\binom{6}{2}=\frac{6!}{2!\cdot 4!}=\frac{4!\cdot 5\cdot 6}{2\cdot 4!}=5\cdot 3=15$ ways? (Wondering)
Yep.
And actually we also have $S\cup S=S$ for any set $S$. (Nerd)
Yep. (Nod)
Indeed.
As I wrote it, I took 6 choices for the 1st element and 5 choices for the 2nd element, giving us 6 x 5 = 30 ways.
Using $S\cup T=T\cup S$, we can reduce that by a factor 2 giving the 15 ways that you found. (Mmm)
I like Serena said:
Yep.
Yep. (Nod)
Indeed.
I understand! Thank you so much! (Mmm)
1. What is a σ-algebra over M?
A σ-algebra over M is a collection of subsets of a given set M that satisfies three properties: (1) it includes the empty set, (2) it is closed under complement (i.e. if A is in the σ-algebra, then its complement is also in the σ-algebra), and (3) it is closed under countable unions (i.e. if A1, A2, ... are all in the σ-algebra, then their union is also in the σ-algebra).
2. What is the purpose of a σ-algebra over M?
A σ-algebra over M is used in measure theory to define a measure, which assigns a numerical value to each set in the σ-algebra. This measure can then be used to calculate the size or probability of events in the context of probability theory and statistics.
3. How is a σ-algebra over M different from a power set of M?
A σ-algebra over M is a subset of the power set of M, but not all subsets of the power set of M are σ-algebras. A σ-algebra over M must satisfy the three properties mentioned above, while the power set of M includes all possible subsets of M.
4. Can a σ-algebra over M be finite?
Yes, a σ-algebra over M can be finite. As long as it satisfies the three properties mentioned above, a σ-algebra over M can have a finite number of subsets.
5. How is a σ-algebra over M related to a Borel σ-algebra?
A Borel σ-algebra is a special type of σ-algebra that is generated by the open sets of a topological space. In other words, it is the smallest σ-algebra that contains all the open sets. A σ-algebra over M may or may not be a Borel σ-algebra, depending on the specific set M and the topology on M.
  • Topology and Analysis
  • Quantum Physics
  • Linear and Abstract Algebra
