Is it possible to convert/transform Electricity to matter
In summary, the conversation discusses the possibility of using electricity to create matter for a chemical thruster or ion propulsion. However, it is stated that this is not possible due to the law of conservation of energy. The conversation then shifts to alternative methods of propulsion, such as using plasma or a pulse jet fired by an electrical discharge. The possibility of using magnetism for propulsion is also mentioned. The conversation concludes with the idea that magnetism could potentially increase the efficiency of propulsion through high energy collisions.
GurfX
28
Hello,
For a future development, Me and a friend of mine were talking about some thruster technology and we wondered if it was possible to transform electricity to matter to create some sort of chemical thruster or using the matter to create an ion and use it as the thrust. well at least something like that and if that wasn't possible (which law of conservation of energy says so) then i have something below. I also heard something about transforming light to matter and you make light from electricity right? so if you can do that then could you use the matter created to make ions
Anyways i have an energy source (however big it needs to be) and the thruster which needs to be able to lift something like 100kg, what is needed and how could it be done. if at all possible, what type of different approaches can it be done in.
I think you forgot this "energy can neither be created nor destroyed but transform form one form to the other. "
Yeah, its included in the law of conservation
The short answer is that no, you won't be able to transform energy, whatever its form, into matter. (I'm not saying it is not possible, just that it's not the answer to your problem.)
I don't know much about the subject, but I would venture to say that to lift 100 kg, you will need a chemical rocket, an airplane, or a helicopter.
The energy/matter rate of conversion of energy to matter is well known - and large by any practical measure.
I respectfully disagree (to some extent)
<< inappropriate source deleted by Mentor >>
But anyways if its not the answer could and electricity somehow be converted to a sort of thrust
Electricity is converted to low-level thrust in existing spacecraft . Can you research that please and post any specific questions about that reading?
Yes i have researched some information about spacecraft propulsion but my focus is not on outer atmosphere thrusters, rather in Earth's atmosphere but the only one i found usefull was using ion propulsion to creat thrust using electricity to make ions for thrust
You think you can do better than NASA in your design? :smile:
If you have a gas such as Earths atmosphere available, then the creation of a plasma by an electrical discharge would not require the conversion of electricity into matter.
Another technique could be to build something like a small pulse jet fired by a pulsed electrical discharge rather than a liquid fuel.
https://en.wikipedia.org/wiki/Pulsejet
haha no, not at this moment at least. but what I mean is that i don't want to use some of their projects because for example a solar sail *won't work on earth
So for the plasma thruster, you can just use electricity to create a hot plasma from the air and to use it as a propellant? If I'm correct...
And for the pulse jet, they do require fuel as shown in this diagram
Yes, traditional pulse jets do require fuel to burn with air containing oxygen and so produce hot combustion products. You should be able to use an electrical discharge to do the same, without any fuel, just the discharge. The pulse would be a discharge of plasma heated air. Inlet valves would allow cold air to enter the plasma chamber, the cycle would then repeat with the next discharge.
Perfect, my friend was thinking the same thing but without the pulse jet engine. Great idea, thanks.
In physics as per mass-energy equivalence we can convert. even at thigh temperature even photon -photon collsions lead to create mass I hope we can do the same in case of electric current but i hope even magnetism can play the role in it .
Brilliant question!
yep e=mc2 makes heat give the atom more mass virtually(if I am correct) so its why plasma or a hot gas can be used for propulsion, noticed it when welding and had a hot gas inside a cube with a hole, all the hot gas trying to escape made the cube move a little
By this do you mean using magnetism to speed up atoms to create more high energy collisions for more thrust efficiency?
Yes My friend.
Yes, a very good idea. hope to make this into practice soon
Well I think we need high energy for this purpose ..
haha yeah my next problem (ironman did it :smile:)
Thread closed for Moderation...
Thread will remain closed because of the low signal to noise ratio of the discussion.
To the OP -- please do some reading about Specific Impulse: https://en.wikipedia.org/wiki/Specific_impulse
You will find that trying to gain propulsion by ionizing air is extremely inefficient.
1. Can electricity be converted into matter?
Yes, electricity can be converted into matter through a process called pair production, which involves the creation of an electron and a positron (antimatter equivalent of an electron) from a high-energy photon. This process requires a significant amount of energy and is typically only observed in high-energy environments such as particle accelerators.
2. How is electricity converted into matter?
Electricity is converted into matter through the pair production process, where a high-energy photon interacts with the electric field of an atom and creates an electron-positron pair. This process obeys the law of conservation of energy, as the energy of the photon is converted into the mass of the two particles.
3. Is it possible to convert matter into electricity?
Yes, matter can be converted into electricity through several processes such as chemical reactions or nuclear reactions. In chemical reactions, the energy released from breaking and forming bonds between atoms can be harnessed to generate electricity. In nuclear reactions, the energy released from splitting or combining atomic nuclei can also be converted into electricity.
4. Can electricity be transformed into different types of matter?
Yes, electricity can be transformed into different types of matter by varying the energy of the original photon in the pair production process. The energy of the photon determines the mass of the resulting particles, so a higher energy photon can produce heavier particles such as protons and neutrons.
5. Are there any practical applications of converting electricity into matter?
Currently, there are no practical applications of converting electricity into matter on a large scale. However, pair production is a fundamental process in particle physics and is essential for understanding the behavior of matter and antimatter. It is also used in medical imaging techniques such as positron emission tomography (PET) scans. In the future, with advancements in technology, it may be possible to harness this process for energy production.
  • Electrical Engineering
  • Aerospace Engineering
