Is my calculation correct?
  1. Oct 5, 2009 #1
    dvn
    Hello,
    I have been researching on electrical output and it power and working out how much power I use at home and have been doing a project to make power.
    I wanted to make sure if this calculation is correct...
    I use a 12V DC motor with an output of 70mA which creates 0.84 Watt according to PIE method. 12 X 0.07 = 0.84W
    So I use 20 x dc motors and combined of 20 motors will make 16.8 Watt?
    = 20 X 0.84 = 16.8W
    If I get the motors running for an hour then it will create 1.008 kWh??
    = 16.8 x 60 = 1008W
    Please correct me if I am wrong.
    Thank you
  3. Oct 5, 2009 #2
    MATLABdude
    Everything's correct, except for the last line. You'd use up 1008 J, but only 16.8 Watt*hour. Why? You're multiplying 16.8 watts by, well, 1 hour!
    It won't actually produce 16.8 Watt*hour of energy, since a portion of the input power goes to heat.
  4. Oct 5, 2009 #3
    dvn
    I multipled 60 because of 60 minutes in an hour. So you are saying that the energy 16.8W is applied as an hour?
  5. Oct 5, 2009 #4
    One watt is one joule per second.
  6. Oct 5, 2009 #5
    dvn
    So if I get the dc motors running for 2 hours then it will produce 33.6W?
    = 16.8 x 2 = 33.6W
    So how do I work out the watt for minutes and seconds?
  7. Oct 5, 2009 #6
    russ_watters
    Staff: Mentor
    A watt-hour is a watt for an hour, so 16.8 watts for an hour is 16.8 watt-hours.
    No, 16.8 Watts x 2 hours = 33.6 Watt-hours. Make sure you follow through with your units!
    Watts are a unit of power - they are already in terms of seconds (as already stated: joules per second). Energy is power times time. Watt-hours.
  8. Oct 5, 2009 #7
    dvn
    If I want to measure the power output for 1 minute.
    Do I divide 16.8 by 60 = 0.28 joules?
  9. Oct 5, 2009 #8
    russ_watters
    Staff: Mentor
    No, watts is power: 16.8 watts. It doesn't matter if you measure it for a second, an hour, or a day, 16.8 watts of power is 16.8 watts of power. And a watt is a joule per second, so you can express it as 16.8 joules per second.
    If you take a book that weighs 1 N and pick it up off the floor and put it on a 1m table, that's 1 N-m -- 1 Joule of energy. If you do it in 1 second, that's still 1 joule of energy, but expended at a rate of 1 joule per second or 1 watt.
    Take your car: if your car is moving at 60 miles per hour, does measuring it for 2 hours mean you were driving at 120 miles per hour? No, it is still 60 miles per hour.
  10. Oct 5, 2009 #9
    dvn
    Now I understand what you mean. Sorry I was thinking about recharging theory.
    Yes you are right about the constant energy output that the dc motor make. What I have forgotten to tell is that if I recharge the battery or secondary battery or so, so if I use 16.8W and recharge the battery in 2 hours then it will recharge as 33.6w or something?
  11. Oct 5, 2009 #10
    russ_watters
    Staff: Mentor
    No, still 16.8W. Watts is power. Power is energy per unit time. If you want to know how much energy it takes, that's watt-hours.
    This could all be cleared-up if you write down your math and include the units when doing the math. You'll see that multiplying a watt by an hour can't yield a watt, it must yield a watt-hour!
