Is 'space' expanding or not?
  • B
  • Thread starter rede96
rede96
659
I've spent quite a bit of time researching cosmology on here and various other sources (NOT pop science) and although I feel I have a much better understanding in general, there is one specific thing that I just can't get my head around. Is the space between galaxies expanding or is it just the distance between galaxies growing.
The reason this seems so confusing is that from posts I've made before I understood it as just the distance between galaxies growing. (at an accelerated rate due to dark energy) and not because there was some property of empty space the was 'expanding' causing the galaxies to move apart. But I read in many posts here that it's the space that is expanding.
One of the most popular references is related to photons from distant galaxies that are receding >c won't reach us because the 'space' in between is growing faster than c. Where I would have thought that if it is just the distances growing at a rate >c the photons would still reach us eventually.
So can someone help clear this up for me once and for all! I'm sure I'm missing something simple, but I just cant get it!
Answers and Replies
Chalnoth
447
The average distance between galaxies certainly increases over time.
Whether you refer to this increasing distance as the expansion of space is more or less a matter of taste. The purpose of the "expanding space" description is to make it easier to grasp certain features of the expansion, namely that recession velocity can exceed the speed of light and that the expansion also affects the wavelengths of photons in the same way that it does the distances between galaxies.
It depends upon what the expansion does in the future. If the rate of expansion slows down sufficiently, yes, those photons will eventually reach us. But if the dark energy is indeed a cosmological constant (or acts like one in the future), then the rate of expansion won't slow down far enough for the light from many far-away galaxies to ever reach us.
ogg
148
36
Please explain the difference between the expansion of distance (in all directions) and the expansion of space. I am unable to understand why you think there IS a difference. Space is expanding. The distance "between galaxies" is not - unless the galaxies in question are NOT GRAVITATIONALLY BOUND. (Another way to put it is that the expansion rate is so small, that even the weakest force (gravity) is sufficiently strong to keep locally interacting objects bound.) So, it is on the scale of superclusters where you can observe the expansion of space VIA the increase in distance (as measured by red-shift). Our current model (theory) is that the expansion is the same for each point in space at a given time. (Please don't ask what I mean by "a given time"!). Our models predict that the rate of increase is increasing, but whether this will continue or not is unknown. IF the amount of space (distance) between two objects is increasing faster than the two objects are reducing that distance, and that remains true forever, then the two objects will never meet. If you are walking (against the flow) on a straight infinitely long moving walkway at a speed less than the speed of the walkway, you are "moving away" from fixed points in front of you, you will never reach them (unless something changes). To reiterate: objects in our local cluster of galaxies are NOT moving away from one another, more distant objects are moving away from us. So, we will not see (a cosmological) redshift from local galaxies, but will see red-shift with more distant ones. Space is expanding everywhere, distance isn't (in any meaningful way) if the objects are bound.
rede96
659
I'm not too sure I would agree with it being a mater of taste. I would have thought there is a fundamental difference between the 'space' between two distant galaxies expanding, causing the galaxies to move apart and the distance between those two distant galaxies getting larger due to the two galaxies moving apart.
Again, this would imply that because the 'space' the photon is travelling through is growing, it stretches or red shifts the photon. In the same way a pen mark on a piece of elastic would grow if the elastic was stretched. But from what I remember that isn't what is going on with cosmological red shift.
Sure, I think for the purposes of this post I'd assumed the rate doesn't slow down in the future. So it makes sense to think if we are moving away from a distant source at a rate >c then a photon from that source would never catch up to us. However that statement causes confusion too. Because it's said that two distant objects can't move apart at speeds > c in a conventional sense as this would violate relativity. So I've heard it explained as the two distant objects are actually at rest wrt to each other, but the space grows between them. But what I thought I'd understood is that GR does allow objects at cosmological distances to move apart at speeds >c, it just doesn't allow things locally to pass each other at speeds >c.
So for me, I thought using the words 'space is expanding' is not only confusing but technically incorrect.
Chalnoth
447
Nope.
The statement that the average distance between galaxies is increasing is the precise interpretation of the expansion.
General Relativity is interesting in that there are a lot of different ways of describing the exact same system that can sound very different from one another. You have to be really careful when making statements about how General Relativity describes the expansion (or other things) in order to avoid making ambiguous statements.
In this particular case, the ambiguity comes from time: before you can ask how far away two points are, you first have to find a way to synchronize your clocks between the two points. With an expanding universe, this is pretty easy: the same time at two different points is the time where they both measure the same CMB temperature. Once you've used the CMB to synchronize the clocks, the proper distance between any two points in the universe is well-defined, and the proper distance between any two points that are stationary with respect to the CMB increases with the expansion.
Other descriptions are used to try to get people to understand other interesting features of the expansion (as I mentioned), but they don't necessarily succeed. Many people on these forums tend to think that the "expanding space" description can be misleading. I don't know. Maybe it is, maybe it isn't. But either way, the "distance increasing" description is the most accurate way of describing it.
This isn't true in General Relativity, for the simple reason that in General Relativity, the relative velocity between two objects is only well-defined at a particular point. You can't actually subtract the velocity between two objects that are far away and get a single, definite answer. Because you can't get a definite answer for far-away objects, there can't be any speed limit for far-away objects.
The speed-of-light limitation in General Relativity instead is the statement that no object can outrun a light beam.
Likes Buzz Bloom and QuantumQuest
rede96
659
Thanks for the further explanation. This is basically how I understood it. But this still doesn't answer the question about whether the distances are increasing due to the galaxies moving through space wrt each other or if the distances are increasing because space itself is expanding and moving the galaxies apart. That is where I read so many contradictory things about expansion.
Even watching Leonard Sussskind's lectures on Cosmology he explains expansion something like "As space expands, imagine little bits of space filling in the gaps" I'll need to find the exact quote, but that is roughly what he implied. Space itself grows, not just distances getting bigger.
Again still confusion here for me because if a distant galaxy emits a photon in our direction and we are far enough away (assuming no slowing down of expansion) then we will be moving away at a rate >c and thus the photon will never catch up to us. I think it is safe to say that is an accurate statement. Which then begs the question will we catch up with photons that had already passed us from that far away galaxy before our respective recession velocities were >c ?
George Jones
Staff Emeritus
1,434
Care is needed with respect to the definition of "speed" in a cosmological setting.
this isn't true. It is true that recession speeds of galaxies that we now see will eventually exceed c, but it is not true that we loose sight of a galaxy once its recession speed exceeds c. If we see a galaxy now, then we will (in principle) always see the galaxy, even when its recession speed exceeds c.
Suppose we now see galaxy A. Assume that at time t in the future, A's recession speed is greater than c, and that at this time someone in galaxy A fires a laser pulse directly at us. Even though the pulse is fired directly at us, the proper distance between us and the pulse will initially increase. After a while, however, the pulse will "turn around", and the proper distance between us and the pulse will decrease, and the pulse will reach us, i.e., we still see galaxy A.
This can happen because the Hubble constant decreases with time (more on this near the end of this post) in the standard cosmological model for our universe. Consider the following diagram:
Code:
O                                B        A        C
O                    B     A     C
The bottom row of asterisks represents the positions in space (proper distances) of us (O) and galaxies B, A, and C, all at the same instant of cosmic time, [itex]t_e[/itex]. The top row of asterisks represents the positions in space of us (O) and galaxies B, A, and C, all at some later instant of cosmic time, [itex]t[/itex]. Notice that space has "expanded" between times [itex]t_e[/itex] and [itex]t[/itex].
Suppose that at time [itex]t_e[/itex]: 1) galaxy A has recession speed (from us) greater than c; 2) galaxy A fires a laser pulse directed at us. Also suppose that at time [itex]t[/itex], galaxy B receives this laser pulse. In other words, the pulse was emitted from A in the bottom row and received by B in the top row. Because A's recession speed at time [itex]t_e[/itex] is greater than c, the pulse fired towards us has actually moved away from us between times [itex]t_e[/itex] and [itex]t[/itex].
Now, suppose that the distance from us to galaxy B at time [itex]t[/itex] is the same as the distance to galaxy C at time [itex]t_e[/itex]. Even though the distances are the same, the recession speed of B at time [itex]t[/itex] is less than than the recession speed of C at time [itex]t_e[/itex] because:
1) recession speed equals the Hubble constant multiplied by distance;
2) the value of the Hubble constant decreases between times [itex]t_e[/itex] and [itex]t[/itex].
Since A's recession speed at time [itex]t_e[/itex] is greater than c, and galaxy C is farther than A, galaxy C's recession speed at time [itex]t_e[/itex] also is greater than c. If, however, the Hubble constant decreases enough between times [itex]t_e[/itex] and [itex]t[/itex], then B's recession speed at time [itex]t[/itex] can be less than c. If this is the case, then at time [itex]t[/itex] (and spatial position B), the pulse is moving towards us, i.e., the pulse "turned around" at some time between times [itex]t_e[/itex] and [itex]t[/itex].
If the value of the Hubble constant changes with time, what does the "constant" part of "Hubble constant" mean? It means constant in space. At time [itex]t_e[/itex], galaxies O, B, A, and C all perceive the same value for the Hubble constant. At time [itex]t[/itex], galaxies O, B, A, and C all perceive the same value for the Hubble constant. But these two values are different.
Likes Buzz Bloom
rede96
659
Ok, I didn't mention speed in the section you quoted so could you elaborate a little more please?
And here we have it! Another contradictory statement. You statement:
Chalnoth's statement:
George Jones
Staff Emeritus
1,434
No, the posts by Chalnoth and me are not contadictory. I dd not say that there do not exist galaxies whose light we will never be able to observe, I said that if we can observer a galaxy now (or at any time in the past), then we always be able to observe that galaxy, even if its proper recessional velocity exceeds c.
rede96
659
Ah ok, sorry I missed read that. Although that still confuses me.
EDIT: However on one of Susskind's lectures he does say that in many billions of years to come the only stars we will see will be from our own milky way. So that does contradict you.
Chalnoth
447
"Space is expanding" is one way of looking at it, and it isn't inaccurate. It's just that it's not really a precise statement.
The way I like to think of it is this: imagine you're driving down a road, and pass a telephone pole. It's completely accurate to say either that the pole passed by you and that you passed the pole. There's no right answer between those two choices: it's just a difference in reference frame.
Saying that space is expanding is sort of like that. You could describe it that way, but you can just as accurately describe it as objects getting further apart.
This isn't entirely accurate, because the rate of expansion changes over time. A photon that started traveling in our direction, but was still carried away from us due to how fast the expansion was, might eventually start to gain ground as the expansion slows over time. In fact, most of the galaxies visible from Earth are in this situation, because the expansion rate in the past was much, much faster than it is now.
The picture here is that the photon leaves the galaxy, traveling in our direction. But the expansion is so fast that the distance between us and the photon still grows as it moves at speed c away from its source galaxy. Over time, the expansion slows down enough that the photon starts to gain ground instead, eventually reaching us.
Note that the rate of expansion is now decreasing very slowly, and seems to be approaching a constant (the cosmological constant). So the limit beyond which we can no longer see galaxies is a little bit further than the point at which their recession velocity reaches c.
Chronos
747
See the article by Davis and Lineweaver ; http://arxiv.org/abs/astro-ph/0310808, Expanding Confusion: common misconceptions of cosmological horizons and the superluminal expansion of the Universe, for further discussion.
Likes vela, Hernik, QuantumQuest and 1 other person
George Jones
Staff Emeritus
1,434
I have not seen any of Susskind's lectures, but he could mean in a "for all practical purposes sense". From
http://arxiv.org/abs/0704.0221
While objects will not be observed to cross the event horizon, light from them will be exponentially redshifted, so that within a time frame comparable to the longest lived main sequence stars all objects outside of our local cluster will truly become invisible.
The expansion of the universe in three ways diminishes the energy flux that we receive from distant galaxies.
1) a dimming due to increasing distance.
2) The energy of light is inversely proportional to its wavelength (energy of a photon is ##E=hc/\lambda)##. As the light travels to us, the expansion of the universe expands the wavelength of the light by a factor of 1+z, where z is redshift.
3) Also, the expansion of the universe decreases the rate at which we receive photons, as compared to the rate at which photons left a source, by another factor of 1+z (gravitational time dilation).
This triple whammy means that we will lose contact in *practical* terms with most of the universe in the distant future.
Likes QuantumQuest
anorlunda
Staff Emeritus
Insights Author
10,714
8,009
I always thought the OP question was related to observational versus theoretical science. We can observe the light of distant galaxies, but not the intergalactic space. What happens in distant intergalactic space can be inferred but not observed. Therefore, if we stress what we know from observation, expansion of empty space is deprecated.
Where I think I sense disagreement among experts is if we consider a small region containing no mass, no photons,and no gravitational field. Does it expand? The answer would seem to depend on vacuum energy because to have a time evolution, the region needs a nonzero Hamiltonian. If I got it right, expert opinions on vacuum energy differ.
Another way to say it is that particles (massive and massless) and fields have properties. Take them away and we have nothing. It is meaningless to discuss the properties of nothing.
Is my description of the disagreement correct?
P.s. My spell checker just tried to correct "discuss" to "rickshaw". To me, that is an even deeper mystery.
rede96
659
Thanks for the link. I've had a quick look but will review it in more detail over the weekend. However there is on thing that I'd like to mention, which comes from the quote below taken on page 5...
The general relativistic interpretation of the expansion interprets cosmological redshifts as an indication of velocity since the proper distance between comoving objects increases. However, the velocity is due to the rate of expansion of space, not movement through space, and therefore cannot be calculated with the special relativistic Doppler shift formula
...in particular where it states that separation velocities are due to expansion of space and not movement through space. This implies to me that expansion is due to 'empty space' growing, or in other words, some physical framework which energy and matter ect are embedded, is growing. Moreover that dark energy therefore isn't a force that is 'pushing' galaxies apart, it is a force acting on the expansion of empty space, causing that to accelerate.
That does make sense to me, but it is different to many things I've read about expansion. This is fundamentally what I am trying to clear up.
rede96
659
That is pretty much where my confusion is. As I posted above, the article Chronos referred to would seem to suggest there is 'something' expanding.
16,306
If there is no mass, no photons, and no gravitational field, then spacetime is empty and flat. So how could we possibly tell whether it was "expanding" or not? There is nothing to observe.
The way I would resolve the question raised by the OP is to say that the term "expansion", properly speaking, applies to a family of worldlines, not to "space". That is because "space" is not an invariant concept; what "space" is, and whether it is "expanding", depends on your choice of coordinates. But if we pick out a particular set of worldlines, then the question of whether those worldlines are "expanding" has an invariant meaning. Any set of worldlines has an invariant scalar associated with it called the "expansion scalar". If this scalar is positive, the set of worldlines is expanding; if the scalar is negative, it is contracting; and if the scalar is zero, the set of worldlines is not expanding or contracting.
When cosmologists say "the universe is expanding", what they actually mean, put in precise technical language, is that the expansion scalar of the set of "comoving" worldlines--that is, the worldlines of observers who see the universe as homogeneous and isotropic--is positive. That is an invariant statement and does not depend on any choice of coordinates, nor does it require one to say that "space" is expanding, or that it isn't, for that matter. Whether "space" is expanding is simply not a meaningful question as far as the physics is concerned.
The expansion scalar is actually one piece of a very useful mathematical tool in GR, called the "kinematic decomposition" of a set of worldlines (the more precise technical term is a "timelike congruence"). Some more information about that can be found here:
https://en.wikipedia.org/wiki/Congr...atical_decomposition_of_a_timelike_congruence
Likes Buzz Bloom, PAllen, spacejunkie and 1 other person
Chronos
747
The concept of distance has no intrinic meaning under GR, which is a theory only of 'space-time coincidences'. This means all such measurement can only be local (at an event) . This destroys the notion of length and time co-ordinates as observables. To quote Einstein "All our space-time verifications invariably amount to a determination of space-time coincidences. If, for example, events consisted merely in the motion of material points, then ultimately nothing would be observable but the meeting of two or more of these points. Moreover, the results of our measuring are nothing but verifications of such meetings of the material points of our measuring instruments with other material points, coincidences between the hands of a clock and points on the clock dial, and observed point-events happening at the same event. The introduction of a system of reference serves no other purpose than to facilitate the description of the totality of such coincidences." So, in this light it is no more meaningful to say that space-time is expanding than it is to say the distance between far away galaxies is increasing. It is strictly a frame dependent convenience to characterize the relationship between non-local events and space-time. Some users prefer to talk in terms of an expanding coordinate system to characterize expansion. This too, however, is little more than a convenient illusion.
Likes Buzz Bloom
rede96
659
For me personally, my question isn't about how we describe expansion. In the context of the questions I guess the words we use or choice of coordinates etc are for the most part irrelevant.
What I am asking is much more fundamental. Another way of putting this would be as the universe expands, is new 'space' being created? Are quantum fields, such as the quark field or higgs field etc being constantly created OR do they already exist and the universe is just 'moving' into those pre-existing fields?
16,306
I don't know what "new space being created" means.
I don't know what it would mean for new fields to be "created" vs. the universe "moving into pre-existing fields".
I understand that these seem to you like meaningful questions. But they don't correspond to anything in the actual models we use. That was part of my point.
Likes Buzz Bloom
rede96
659
This was something I picked up on from Suskind's lectures on cosmology. He explained expansion as new space being created, but I didn't really follow what he meant.
Simply, if I take any two galaxies at some large distance moving apart, when they are at some certain distance apart there is a finite amount of energy (from some quantum field for example) between them. As the distance between them gets larger, if the energy density stays the same, then there must even more energy between them. This could be because the energy density of that field is the same everywhere in the universe, and those two galaxies are simply separating in to that existing energy field (e.g. moving through the field), hence there is more energy between them, or if could be because that energy field is actually expanding with the universe, so the energy density is going down but as they separate, more energy is being created in the space between the galaxies.
From what I understand it doesn't really make a difference to the predictions of current models which one of those situations we imagine. But they are at least to me two different fundamental processes.
I guess that is where I am struggling. GR, Eisenstein's field equations etc. tell us very well how gravity works and operates through the interactions of spacetime and energy/matter. But they don't tell us what gravity actually is.
I suppose it's the same with expansion. Current cosmological models tell us very well what is happening, we can do the math, make predictions etc but for me at least, they don't tell me just what expansion actually is, or what does indeed 'expand'. Moreoever, unlike GR, there is a lot more ambiguity in the words used in explaining expansion.
16,306
That's because there isn't really anything in the actual physical model that corresponds to what he meant. The words he used are commonly used when describing the model to lay people, but they're not meant to actually describe the model in technical terms that you can use to draw inferences. You are finding that out because you are trying to draw inferences from those words, and the inferences aren't working.
This reasoning applies to dark energy, but not to other quantum fields. Even for dark energy, though, it is coordinate-dependent, because "distance" and "space" are coordinate-dependent. If you look at invariants, there aren't any that change in the way you are describing. The energy density is an invariant (when correctly defined), but the "energy contained in a given distance" is not.
Yes, it does. The energy density is an observable, so predicting that the energy density is constant everywhere and at all times is observably different from predicting that the energy density goes down with time. The first of the two is the correct prediction, as far as we can tell from our best current observations. (More precisely, it's the correct prediction for dark energy. For all other quantum fields, the observed energy density in empty space is zero.)
In the sense you appear to mean that term, no physical theory tells you what "actually is". Physical theories tell you how to make predictions that will match observations.
There is plenty of ambiguity in the words used to describe GR in general. "Gravity", for example--there are at least three things in the math of GR that I can think of off the top of my head that that word can refer to (the metric tensor, the Christoffel symbols, and the Riemann curvature tensor). This is why, to be precise, you shouldn't use ordinary language; you should use math.
Likes anorlunda
rootone
3,388
946
Yes, astronomical observations confirm that stuff is getting more distant from 'us' all the time.
rede96
659
But just to clarify once and for all.... Is it correct to say that when we talk about expansion, as far as we know, all that is physically happening is the distances between matter which isn't bound in any way, are simply getting bigger, or in other words moving apart, due to the pressure from dark energy pushing matter apart? And that there is no physical thing (e.g. space, space time, energy fields etc.) that is 'stretching'?
What about the higgs field? Is that just another type of scaler field like dark energy?
16,306
Yes, this is fine, as long as you are aware that "distance" here is coordinate-dependent. An invariant way of describing what is going on is to say that the congruence of "comoving" worldlines has a positive expansion scalar.
This only applies to the acceleration of the expansion; it does not apply to expansion in itself. If there were no dark energy, the universe would still be expanding, but the expansion would not be accelerating.
Yes--that is, there is nothing in the actual model that corresponds to any physical thing "stretching".
The Higgs field is a scalar field, but it does not have the same effect in cosmological models as dark energy. AFAIK the Higgs field plays no role in cosmological models at all. (I believe there have been some speculations that the Higgs field might be what produces dark energy, but AFAIK those speculations have not worked out; the Higgs field doesn't have the right properties.)
Btw, we don't know that dark energy is a scalar field at all; that is just one possibility.
PAllen
2,085
And this gets at those 'more than one valid way of interpreting the same mat' that Chalnoth referred to. Co-author Tamara Davis of this paper wrote a later paper arguing for the view that recession speed is highly misleading, and that the GR analog (ambiguous though it is) of relative velocity is always subluminal; and that it is completely valid to view cosmological redshift as a generalization of Doppler; and that 'the universe losing energy' is misleading and better phrased as 'there is no such thing as total energy of the universe'.
PAllen
2,085
Observation: in the limit of decreasing density without dark energy, the FLRW cosmology has increasing expansion rate while approaching flat Minkowski space geometrically. Thus, we have maximal expansion rate as the manifold becomes static and flat! That's why I strongly prefer Peter's terminology of expanding comoving congruence, or the popular phrase, 'expanding universe' rather than expanding space.
Also, note that the closest SR analog of recession rate is a celerity (not a relative velocity), which has no upper bound at all even in SR. And recession rate as function of distance is maximal in the flat spacetime limit of FLRW - i.e. when there is no curvature at all.
bahamagreen
993
48
Maybe I can help because I've been puzzled here before about the same question.
What concerned me about distinguishing increasing distance and space expansion was that both the increasing distance and space expansion ideas present that there is a mutual acceleration between objects...but these objects don't seem subject to inertial effects of this acceleration. My coffee stays in my cup without sloshing out!
The idea that helped me reconcile comoving objects as both inertial and yet accelerating was to consider a similar familiar situation of two "co-falling" objects in the Earth's gravitational field - both are inertial in free fall, yet both are accelerating towards each other because their individual fall lines point toward the center of the Earth's mass and converge.
For me, once I understood comoving as co-falling, the distinction between more distance and more space seems ill-formed and irrelevant.
Likes PAllen
rede96
659
I understood how we measure distance may be coordinate-dependent, but I thought if a distance increases or not is fairly absolute? My simple logic tells me there are only three physical possibilities. Two objects are either moving closer together, are at rest wrt each other or are moving further apart. We know they are moving further apart. Isn't that correct or have I misunderstood something?
Yes sure, and in that case I'd just replace 'due to dark energy' with 'due to the initial inertia from inflation' is that correct?
Just as an aside, is there anything in the cosmological models that prevents us from describing expansion in just 3 dimension, such as a field growing as opposed to describing expansion using the 3 sphere analogy?
Ok, thanks. I was thinking more that the energy density of the Higgs field would have to remain constant, i.e. not dilute with expansion or there would be an effect on the mass of objects.
16,306
A congruence of worldlines having a positive expansion scalar is an invariant way of having distance increasing. But having a coordinate-dependent distance that increases in one set of coordinates does not guarantee that the coordinate-dependent distance between the same objects will be increases in all sets of coordinates.
The "initial inertia from inflation" is really the inertia from reheating--from the transfer of energy from the inflaton field to the Standard Model matter and radiation fields at the end of inflation. That process does not continue to push things apart; it's just a one-time event that creates the hot, dense, rapidly expanding "Big Bang" state.
I'm not sure what you mean here.
The Higgs field effect on the mass of objects is not, as I understand it, due to the Higgs field having a nonzero energy density. It's due to interaction between the Higgs field and other Standard Model fields, but I don't think that interaction has a simple description as a nonzero energy density.
  • #31
Dale Tortorelli
I have always had difficulty with the big bang theory as the cause of the expansion of the universe. Our perception of the expansion could be the result of a spinning universe, or light having a time dependant redshift as a part of its nature. We really do not have enough information to claim the knowledge of either.
  • #32
Chronos
747
The ideas of a 'spinning' universe or one with time dependent redshift have long since been discredited.
  • #33
rede96
659
I'm not disagreeing with this of course, but I am finding it difficult to understand how a spacial 'separation' between two objects can be coordinate dependent. Are there any simply examples you could point me to that show where this is the case? Thanks.
Yes, understood. I sometimes generalize reheating as part of the inflation process.
The balloon analogy is often used to describe how everything moves away from everything else in an expanding universe. As I understood it, this is a 2 sphere. So mathematically it follows that the 3 sphere describes how everything moves apart in the 3 spatial dimensions of our universe.
The problem I have conceptually with this explanation, taking the 2 sphere as an example, is that implies an extra dimension for the sphere to 'grow' in to. Which would be the same with the 3 sphere, it implies there is another dimension for our universe to expand in to. I know this isn't the case, it's not embedded in another dimension but still confuses me. So I was wondering if it were possible to model the movement of matter in an expanding universe just in a 3 spacial dimensional context? Hope that makes sense.
  • #34
PAllen
2,085
A 3-d analog of the balloon analogy is the raisin bread analogy. As cooking loaf rises, the distance between all the raisins increases isotropically and homogeneously (in the ideal) except near the edges. If you imagine there is no edge, you have a model of 3-d expanding congruence.
  • #35
Hernik
101
Now I'm not a physicist and might get some slamming for this, so please correct me if this is wrong - but I was once told to think of the expansion of space as an increase in distances between objects without movement.
That helped me a lot because it delivers an easily understandable explanation for why special relativity does not apply. There is nothing moving apart faster than the speed of light, just distances increasing - and for particles, stars or galaxies separated by a very large distance the increase can be more than 300.000 km/s.
It kind of helped me to understand what goes on in inflation also. Nothing moves. No inertia. Just distances suddenly grow enormously.
Best, Henrik
Suggested for: Is 'space' expanding or not?
10K
  • Last Post
18K
  • Last Post
  • Last Post
  • Last Post
13K
  • Last Post
