Mr_Quantum
- 1
Is the mass relative?
Mr_Quantum said:Is the mass relative?
You can also define it via the equation ##mc^2 = \sqrt {E^2 - (pc)^2}## which gives the same result regardless of which inertial reference frame you measure ##E## and ##p## in.sweet springs said:Mass of body is energy measured in special system where its momentum = 0. By this definition mass cannot be relative.
Mass is a measure of the amount of matter in an object. It is typically measured in kilograms (kg) using a scale or balance.
Mass is a fixed quantity, meaning it does not change regardless of the location or motion of an object.
Mass and weight are often used interchangeably, but they are actually different concepts. Mass is a measure of the amount of matter in an object, while weight is a measure of the force of gravity on an object. Mass remains the same regardless of gravity, while weight can vary depending on the strength of gravity.
Yes, according to Einstein's famous equation E = mc^2, mass and energy are interchangeable. This means that mass can be converted into energy and vice versa.
According to special relativity, mass is relative to the observer's frame of reference. This means that an object's mass can appear different to different observers, depending on their relative motion. However, the total mass and energy of a system remain constant.
