Is the matrix Diagonalizable
  • Thread starter Dank2
  • Tags
    Matrix
In summary, the Attempt at a Solution states that A is diagonalizable if and only if there is a matrix S such that:p(A+5I) < p(A)p - is the rank of the matrixI - is the identity matrix, andS(A+5I)S^{-1} = SAS^{-1} + 5I = diag(α+5,β+5,γ+5)
Let A be a 3x3 singular Matrix that satisfy:
p(A+5I) < p(A)
Is A Diagonalizable?
I know that A diagonalizable matrix can be Singular from every rank, even at 0 rank, so i can't see how i can conclude anything.
You can exclude many cases by the given assumptions. What does it mean for A to be singular?
Can A or A+5I equal the zero matrix?
Likes Dank2
singular means it isn't invertible or the columns are linearly independent or the rank is lower than 3.
i think A + 5I cannot be the zero matrix, but how's that even related to the Diagnolization of A, since any rank of matrix can be diagonliazable.
There is only one possibility for the ranks of A and A + 5I. Assume that A is diagonalizable. What does it mean for the eigenvalues? This gives you a criterium.
Likes Dank2
You mean the eigenvectors? they are independent. if not i don't know, i know that if A is diagonalizable it means that the amount of the same eigenvalues should be equal to the dimension of the eigenvectors space that is related to the current eigenvalue.
also the rank of A<3
and i can't see how to prove that A+5I > 0 it does look reasonable to me.
So A+5I > 0 ==> A+5I = > 1
and then rank of A = 2.
How is that helps me determine if A Diagonalizable
Still need help
I meant the eigenvalues.
##p(A)=2## and ##p(A+5I)=1## are the only possibilities for the ranks, since ##p(A) < 3## and neither matrix can be zero which is equivalent to rank zero. (If ##A+5I = 0## then ##A = -5I## of rank ##3##. If ##A=0## then there is no way for another rank below that.)
Now assume ##A## is diagonalizable, i.e. there is a matrix ##S## with ##SAS^{-1} = diag(α,β,γ)##.
Then ##S(A+5I)S^{-1} = SAS^{-1} + 5I = diag(α+5,β+5,γ+5)## and without loss of generality ##γ=0## because ##p(A)=2.##
Now we still have ##p(A+5I)=1## which is only possible for ##α = β = -5##.
Likes Dank2
So if the rank of the matix nxn is k , then the amount of 0 eigenvalues is n-k ? .
and also if i get two eigenvalues that are 0, how can i know if the matrix is diagonal or not ?
Why do you say p(A) < 3? All you were told is that p(A+5I) < p(A), and so you can have p(A) = 3, p(A+5I) = 1 or 2.
Because A is singular, that means it has linearly independent columns, and that means the rank must be less than 3.
I think I've got it, the rank of P'AP = Rank of A .
Then Rank of A = Rank of it's Diagonal matrix . therefore the rank - n is equal to the number of 0 on the diagonal.
But, still haven't figured out if it's Diagonalizable or not.
Amount isn't a good word here. In case of an eigenvalue ##\lambda## we speak of geometric multiplicity (dimension of the eigenspace of ##\lambda##) and algebraic multiplicity (power of ##t-\lambda## in the characteristic polynomial ##det (A-tI) = 0##) . If ##A## is diagonalizable then they are equal.
In general (in the situation asked) ##n = p(A) + \dim \ker(A) = k + (n-k)## and ## \ker(A) = \{x \in V | Ax=0=0 \cdot x\}## the eigenspace of eigenvalue ##0##.
You can't. It heavily depends on the scalar domain that make up your coordinates.
Likes Dank2
Or maybe A is diagonalizable since the rank of A is 2, and ker of A=1, and it does have only one eigenvalue = 0 , and so the dim of the eigenspace of 0 is 1 .
How can i see the the dim of the Eigenspace of -5 is 2 ?
Dank2 said:
The question in my book says if A is Diagonalizable? Maybe they have mistake ?
If ##A = diag(-5,-5,0)## then ##A## is diagonal and all conditions are met. We only derived that there can't be other eigenvalues.
Likes Dank2
Thanks, think i got it.
I wondered one more thing, if i could show that the dim of the eigenspace of -5 is 2 ? or do i must have values of the matrix for that ?
If
[tex] A = \pmatrix{-5 & 1 & 0 \\ 0 & -5 & 0 \\ 0 & 0 & 0} [/tex]
then all the conditions are met and ##A## cannot be diagonalized.
You mean can be ? if not :
I = Identity matrix
I' = Inverse
I'AI = A
which means A is diagonlaziable. We just found matrix I that Diagonalize A.
I = Identity matrix
I' = Inverse
I'AI = A
No, it was deliberately chosen to be NON-diagonalizable. Look again: the element ##a_{12} \neq 0##. The matrix ##A## is a 3x3 Jordan canonical form for eigenvalues -5,-5,0, with a non-diagonal Jordan block in the top left 2x2 location.
The eigenvalue -5 has algebraic multiplicity 2 but geometric multiplicity 1; that means that you cannot find three linearly-independent eigenvectors, only two. You need to include a so-called "generalized" eigenvector in order to have a full 3-dimensional basis. That is why the matrix cannot be diagonalized.
Where did that a12 =1 came from ?
and how do you know that the Geometric multiplicity of -5 is 1 ?
This ##a_{12}=1## has been willingly chosen, as I have chosen ##diag(-5,-5,0).##
However, as @Ray Vickson has said: it is the Jordan normal form for matrices (basically achieved by choosing a basis in which a matrix can be written as the sum of a diagonal and a nilpotent (strict upper triangular) matrix) which allow you to see the dimensions of eigenspaces. Diagonalizability depends on whether the geometric and algebraic multiplicities of eigenvalues coincide or not (see above).
These are two examples of possible matrices ##A##, one of which is diagonal and one is not diagonalizable.
(I haven't done it so far but it might be possible to make a finite conclusion if we take additionally the fact that ##p(A+5I)=1## into account?)
Likes Dank2
We don't have nilpotent in our course, is possible to see that the geometric multiplicity of -5 is 2 or 1 ?
Ray Vickson said:
If
but Rank of A+5I is = Rank of A
Therefore I added "strict upper triangular".
Assume you have a matrix ##S## for which ##SAS^{-1} = B## where ##B## is either a diagonal matrix or of the form Ray suggested, i.e. has only two eigenvectors, one to the eigenvalue ##0## and one for ##-5##. Then examine ##A+5I## and remember it has to be of rank one.
see post #23,
Dank2 said:
see post #23,
You already know the defect of ##A+5I## that is the dimension of its kernel. What happens to a basis of this kernel, if you apply ##A##?
Sorry , dimension of it's kernel? you mean the dim of the nullspace of A+5I ?
Yes. Take basis vectors ##v_i## of it and calculate ##Av_i.##
basis nullspace of A is v1 = (1,0,0),v2 = (0,1,0)
Av1 = -5*v1
Av2 = -5*v2
That is for A =
-5 0 0
0 -5 0
0 0 0
Because A as in post 23 doesn't satisfy p(A+5I) = 1
Av1 = -5*v1
Av2 = -5*v2
That is for A =
-5 0 0
0 -5 0
0 0 0
Almost. It only guarantees you that ##SAS^{-1}## is of this form, i.e. ##A## is diagonalizable. And recalculate ##p(A+5I)## in this case. (It is also sufficient to state the linear independency of ##v_1## and ##v_2##. No need for coordinates.)
  • #31
p(A+5I) = 1
Likes fresh_42
  • #32
I got confused a bit now.
We took a diagonalized matrix and we proved that it can be diagonalized ? still I am not sure if there is a matrix that is not diagonalized that stratify this.
  • #33
What is the criterion you use by saying ##A## is diagonalizable?
  • #34
If it has 3 linearly independent eigenvectors,
or if it has distinct eigenvalues
or if geometric multiplicity is equal to the algebraic multiplicity.
  • #35
So, the second isn't applicable. How many eigenvectors of ##A## arise from the dimension of the nullspace of ##A+5I##?
And how many from the nullspace of ##A## itself? Are all of these linearly independent? And why?
The former considerations showed us which eigenvalues there have to be and which possibilities exist. They are not really necessary but were easy to do.
Likes Dank2
Suggested for: Is the matrix Diagonalizable
