Is there a local interpretation of Reeh-Schlieder theorem?
In summary, Non-philosophically inclined experts in relativistic QFT often insist that QFT is a local theory and are not convinced by philosophical arguments for non-locality. However, the Reeh-Schlieder theorem, which is based on the Wightman axioms, suggests that acting with a local operator can create an arbitrary state in a different location. This theorem is a result of quantum entanglement and does not contain any philosophical concepts, making it purely mathematical physics. Some experts argue that this does not demonstrate physical non-locality since the operators involved are not physically realizable. However, others argue that the mathematical formulation of QFT itself is non-local.
Demystifier
Insights Author
6,649
Non-philosophically inclined experts in relativistic QFT often insist that QFT is a local theory. They are not impressed much by arguments that quantum theory is non-local because such arguments typically rest on philosophical notions such as ontology, reality, hidden variables, or the measurement problem.
But how about the Reeh-Schlieder theorem? The Reeh-Schlieder theorem (recently explained in a relatively simple way by Witten in https://arxiv.org/abs/1803.04993 ) is an old theorem, well-known in axiomatic QFT, but relatively unknown in a wider QFT community. In somewhat over-simplified terms (see Sec. 2.5 of the paper above), the theorem states that acting with a suitable (not necessarily unitary) local operator (e.g. having a support only on Earth) on the vacuum, one can create an arbitrary state (e.g. a state describing a building on Mars). As all other theorems that potentially can be interpreted as signs of quantum non-locality, this theorem is also a consequence of quantum entanglement. However, unlike other theorems about quantum non-locality, this theorem seems not to contain any philosophical concepts or assumptions. The theorem is pure mathematical physics, without any philosophical excess baggage.
What I would like to see is how do non-philosophically inclined experts in QFT, who insist that relativistic QFT is local, interpret Reeh-Schlieder theorem in local terms? How can it be compatible with locality?
Likes Auto-Didact and atyy
One trouble with the Reeh-Schlieder theorem is that the Wightman axioms, say, that are required to prove it are not satisfied by interacting Lagrangian fields. Hegerfeldt proves something similar with much more restricted assumptions, almost only the spectrum condition (that the energy-momentum must be in or on the forward light-cone), which an interacting quantum field ought to satisfy, but it seems often to be argued that this is not an example of nonlocality, and perhaps the proof is not compelling because it can be dismissed on a quick reading as being about nonrelativistic QM.
More constructively, the 2-point Wightman function (the non-time-ordered 2-point Vacuum Expectation Value) has to have the Källén-Lehmann form even for an interacting field (the scalar boson case, to keep at least some simplicity), so it's definitely non-zero at space-like separation (and so is the time-ordered VEV). Microcausality shows up in this context as the imaginary part of the 2-point VEV being zero at space-like separation, but the real part is always non-zero except on the light-cone, where it's undefined (there's a delta function on the light-cone, as well as inverse square scaling at small invariant distance from the light-cone).
Even for Gibbs' states of the classical Klein-Gordon field there are nonlocal correlations, however, even though the advanced and retarded propagators of the classical KG dynamics are definitely zero at space-like separation, so we can't just point to nonlocal correlations and say, "look, nonlocality!" For the classical KG equation, it's not the advanced or retarded propagator that shows up when we compute the Gibbs' state, but (at space-like separation) we obtain the inverse Fourier transform of ##(\vec k\cdot\vec k+m^2)^{-1}##, corresponding to different boundary conditions. The Gibbs' state, it should also be noted, is either a consequence of an infinite-time convergence to equilibrium because of non-KG dynamical perturbations (one supposes), or else it's just a superdetermined-by-minimum-free-energy initial condition.
What I think is curious about the quantized KG field, and might turn at least some heads that might not be turned by any of the above discussion, is that the real part of its 2-point Wightman function is the inverse Fourier transform of ##\left(\sqrt{\vec k\cdot\vec k+m^2}\right)^{-1}##, where the operator ##\sqrt{-\vec\partial\cdot\vec\partial+m^2}## is said to be "anti-local" by mathematicans (see my Physics Letters A 338 (2005) 8–12, arXiv:quant-ph/0411156, and, much more definitively, I.E. Segal, R.W. Goodman, "Anti-locality of certain Lorentz-invariant operators", http://www.jstor.org/stable/24901461. This last might possibly be the reference for some physicists to be confronted with, because its conclusions are quite similar to Hegerfeldt's conclusions.)
At the end of the day, I think all the nonlocality can be attributed to boundary and initial conditions, which, not being dynamical, for some people makes it not nonlocality. After dark, however, this somewhat pushes us towards the introduction of some form of superdeterminism, so perhaps it's just that you take your choice of poison.
Likes bhobba, vanhees71 and atyy
The theorem is essentially a consequence of analyticity, where knowledge of a function in some neighborhood implies knowing it everywhere.
The theorem is compatible with locality since it is proved from the Wightman axioms, which are based on locality.
As mentioned by Witten on p.12, field creation and annihilation operators are not unitary operators, hence not physically realizable in time. So there is no interpretation problem.
Likes bhobba, vanhees71, Peter Morgan and 2 others
This indeed is a good argument that there is no physical non-locality. But since the creation and annihilation operators are well defined mathematically, one could still argue that there is something non-local about QFT in its mathematical formulation.
Well, mathematically, all nonlocal theories ever discussed were created locally from some desk. But this has no philosophical consequences.
Likes bhobba and vanhees71
I am not convinced that all axioms are based on locality. In particular, the axiom that there exists an invariant state (called vacuum) looks quite non-local to me. Intuitively, this axiom says that there exists a state that everywhere looks the same.
Isn't then analyticity itself a kind of mathematical non-locality?
Likes Peter Morgan
All states of any field theory are nonlocal, since they specify the field everywhere. But this is an irrelevant meaning of nonlocality. The latter means either nonlocal dynamics (not valid in relativistic QFT by definition) or nonlocal correlations (valid by direct construction). Locality of the dynamics and nonlocality of the correlations are fully compatible.
Yes. But arbitrarily small deviation in the given neighborhood may have arbitrarily large consequences at any given other point, so this has no physical relevance.
Fort compatibility it is sufficient that the dynamical locality axiom is among the Wightman axioms, and that there are examples satisfying these axioms.
What do you mean by "direct construction"?
This sheds some light on the origin of Reeh-Schlieder theorem, but why does it not have physical relevance?
By the way, this reminds me of the butterfly effect in chaos theory. Would you say that butterfly effect also does not have physical relevance?
Likes Peter Morgan
Whether or not nonlocality of correlations requires some kind of nonlocal dynamics (perhaps at the level of hidden variables) is a part of usual philosophical discussions about the meaning of Bell theorem, which I want to avoid in this thread.
Likes Peter Morgan
e.g., two entangled photons a la Bell.
because in observable physics, consequences must depend smoothly on causes.
It involves no philosophy, only shut-up-and-calculate, since free QED (which is dynamically local) suffices to do the argument in the traditional, purely mathematical way.
Why?
Likes Peter Morgan
Demystifier said:
Why?
Because one can prepare and measure only to finite precision.
Likes bhobba
The Wightman axioms enforce analyticity — in other words significantly more than smoothness, which finite precision could never confirm or deny. How significant is it that thermal and other non-vacuum states require, so to speak, less analyticity?
Also, smoothness wouldn't be expected of a classical ideal model, particularly in statistical mechanics, where discontinuity is commonplace. We might expect that smoothness would reappear if one modeled more accurately, but in practice we work with the discontinuous model because it is accurate enough.
Likes bhobba and dextercioby
A separate aspect of nonlocality in QM/QFT is the commonplace use of the vacuum projection operator by practicing physicists. Whenever a physicist discusses a transition probability, meaning ##\bigl|\langle\phi|\psi\rangle\bigr|^2=\langle\psi|\phi\rangle\langle\phi|\psi\rangle##, the measurement ##|\phi\rangle\langle\phi|## in the state ##\hat A\mapsto\langle\psi|\hat A|\psi\rangle##, they are implicitly using a modulated form of the vacuum projection operator ##|0\rangle\langle 0|##, thereby erasing all the careful construction of microcausal locality. ##|\phi\rangle\langle\phi|## does not commute with any local observable.
This is such a commonplace that I doubt it can be eradicated in general use, but it seems too free and easy with nonlocality that the implicit use of the vacuum projection operator is a step in the most common computations that show that QM violates Bell-CHSH inequalities [of course one has constructions that violate Bell-CHSH inequalities that are entirely local, such as Landau's Phys Lett A 120, 54(1987), "On the violation of Bell's inequalities in quantum theory", so this is merely a criticism of using the vacuum projection operator when it does not have to be used.]
Likes dextercioby
I am having trouble with your notion of locality or the lack of it in QFT. Locality in QFT refers to all (localizable) quantities that can be measured in practice, i.e., the self-adjoint elements of the polynomial algebra [itex]\mathcal{A}(\mathcal{O})[/itex] generated by operators of the form [tex]\int d^{4}x_{1} \cdots d^{4}x_{n} \ \varphi_{k_{1}} (x_{1}) \cdots \varphi_{k_{n}}(x_{n}) \ f(x_{1} , \cdots , x_{n}) , \ \ n = 0 , 1 , 2 , \cdots [/tex] with [itex]\mathcal{O}[/itex] being a (bounded) open set in [itex]\mathbb{R}^{(1,3)}[/itex] and [itex]f \in \mathcal{D} (\mathcal{O}^{n})[/itex]. When [itex]\mathcal{O} \subset \mathbb{R}^{(1,3)}[/itex] is a finite space-time region, the self-adjoint elements of [itex]\mathcal{A}(\mathcal{O})[/itex] are called local observables. When [itex]f \in \mathcal{S} (\mathbb{R}^{4n})[/itex], the resulting polynomial algebra is called the field algebra [itex]\mathcal{A}[/itex].
In theories with positive-definite Hilbert space [itex]\mathcal{H}[/itex], one can show that the following statements are equivalent to one another:
i) Uniqueness and cyclicity of the vacuum: There exists a unique vector [itex]\Omega[/itex] invariant under any translation [itex]P_{\mu}\Omega = 0[/itex], which is cyclic with respect to [itex]\mathcal{A}[/itex], i.e., [itex]\mathcal{A}\Omega[/itex] is dense in [itex]\mathcal{H}[/itex] with respect to an admissible topology [itex]\tau[/itex]: [itex]\overline{\mathcal{A}\Omega}^{\tau} = \mathcal{H}[/itex].
ii) Irreducibility of the field algebra [itex]\mathcal{A}[/itex].
The R-S theorem states that for any open set [itex]\mathcal{O}[/itex] in space-time, the equality [tex]\overline{\mathcal{A}(\mathcal{O})\Omega}^{\tau} = \overline{\mathcal{A}\Omega}^{\tau} = \mathcal{H} ,[/tex] holds for any admissible topology [itex]\tau[/itex]. In English, the theorem asserts that if the field algebra is irreducible (or cyclic with respect to the vacuum [itex]\Omega[/itex]) then the set of states obtained by applying a polynomial algebra of fields (taken from arbitrarily small but open set in space-time) to [itex]\Omega[/itex] also spans the whole Hilbert space [itex]\mathcal{H}[/itex]. In other words, the theory says that the physical states in [itex]\mathcal{H}[/itex] cannot be localized although the observables can. So, the non-local features are carried by the vacuum.
Of course, many aspects of particle physics can be explained using the assumption that particle states are localized excitations of the vacuum, i.e., they arise by applying local field operator to the vacuum as per Wightman. Similarly, in the algebraic setting of Haag, Roberts and others, it is assumed that a particle state cannot be distinguished from the vacuum by measurements done in the space-like complement of sufficiently large but bounded regions of space-time. Particles carrying a non-gaugable-symmetry charge, such as iso-spin, strangeness, baryon number or lepton number, fit well into this scheme. But, we know this method does not work in gauge theories: For example in QED, Gauss’ law allows the charged states to be distinguished from the vacuum in the causal complement of any bounded region, because it is possible to evaluate the charge by measuring the flux through a very large sphere. Thus, in gauge field theories charged states are not localizable.
Likes bhobba, odietrich, Peter Morgan and 2 others
In statistical mechanics, everything is analytic until one takes the thermodynamic limit (a conventional approximation), in which case discontinuities arise in some relationships, due to phase transitions. But the sensitivity in analytic continuation (and hence in the Reeh-Schlieder nonlocality) is very different - it is a generic ill-posedness, not just on a set of measure zero.
Likes Peter Morgan
samalkhaiat said:
the theorem asserts that if the field algebra is irreducible (or cyclic with respect to the vacuum ##\Omega##) then the set of states obtained by applying a polynomial algebra of fields (taken from arbitrarily small but open set in space-time) to ##\Omega## also spans the whole Hilbert space ##\mathcal{H}##. In other words, the theory says that the physical states in ##\mathcal{H}## cannot be localized although the observables can. So, the non-local features are carried by the vacuum.
"the physical states in ##\mathcal{H}## cannot be localized although the observables can" is a nice accessible summary of the Reeh-Schlieder theorem, but I think the difficulty that Demystifier has focused on is a consequence of particle physicists not believing that interacting quantum fields in the Lagrangian formalism fall under the Wightman or Haag-Kastler axioms.
It can't be the case that irreducibility (or cyclicity) is sufficient on its own, because one at least needs there to be a concept of space-time, which irreducibility does not speak to, but can any theory to which a physicist's interacting quantum field can be an asymptotic expansion —with all the mathematical troubles that different types of regularization and renormalization imply— be proved to satisfy the requirements for a derivation of the Reeh-Schlieder theorem? Because of Hegerfeldt, and also because of Arnold Neumaier's point above,
it seems that a representation of the translation group and the spectrum condition alone might be sufficient axioms to prove that "the physical states in ##\mathcal{H}## cannot be localized although the observables can", independently of irreducibility, additivity, microcausality, representation of the Lorentz group, and primitive causality. [The difficulty with Hegerfeldt is that none of his many papers are definitively enough stated or proved. Have a look at his paper arXiv:quant-ph/9809030, for example, which I believe is his most recent. Because of the way Hegerfeldt does things, one hears it said that Hegerfeldt only applies to nonrelativistic QM, however it more seems that positive frequency is sufficient, the (stronger) spectrum condition is not required. The connection of positive frequency with analyticity through the Hilbert transform is relatively more elementary than working with the spectrum condition.] It seems that indeed physicists might agree that any theory they would be willing to accept would have to satisfy positive energy/the spectrum condition, because that is associated with stability.
Likes Auto-Didact
it is crucial for causality, bot in the nonrelativistic and the relativistic case. in the relativistic case, the spectral condition of Wightman is essential for Poincare invariance.
But the Poincare group present produces flat space-time through the Fourier transform.
Likes Peter Morgan
Absolutely, but if the translation group is sufficient and the proof is independent of whether the Lorentz symmetry is present, then best not to include the Lorentz group. Irreducibility is a purely analytic property of the algebra of observables that doesn't imply any geometrical properties, not even the translation group.
One source of wiggle room for physicists is that one cannot be absolutely certain of Poincaré covariance for interacting Lagrangian quantum fields because neither regularization nor renormalization is absolutely certain to preserve Lorentz covariance; the translation group is more certain (although even that might be denied by those who say that we can't have a conversation with anything less than full quantum gravity).
With causal renormalization theory one can be absolutely certain. One cannot dispense with it in elementary particle physics.
Likes dextercioby
For any [itex]|\Phi \rangle \ , |\Psi \rangle \in \mathcal{A}| \Omega \rangle[/itex], the spectrum postulate can be written (in a form which is suitable for Hilbert space with indefinite metric) as [tex]\int d^{4}a \ e^{-i p \cdot a} \ \langle \Phi | U(a) | \Psi \rangle = 0, \ \ \mbox{if} \ \ \ p \not\in \overline{\mathcal{V}}_{+} = \{ q \in \mathbb{R}^{4}; q_{0} \geq 0, \ q^{2} \geq 0 \},[/tex] where [itex]U(a)[/itex] is the [itex]U(1 , a)[/itex] element of the group of unitary operators [itex]U(\Lambda , a)[/itex] on [itex]\mathcal{H}[/itex], i.e., the groups homomorphism [itex]U: \ ISO(1,3) \to U( \mathcal{H})[/itex]. Using translational invariance of the vacuum, we may define a “function” [itex]W_{k_{1} \cdots k_{n}}(y_{1}, \cdots y_{n-1})[/itex] by [tex]W_{k_{1} \cdots k_{n}}(x_{1}-x_{2}, \cdots , x_{n-1}-x_{n}) = \langle \Omega | \varphi_{k_{1}}(x_{1}) \cdots \varphi_{k_{n}}(x_{n})| \Omega \rangle ,[/tex] and rewrite the spectrum condition in the form [tex]\int d^{4}y_{1} \cdots d^{4}y_{n-1} \ e^{i \sum_{j = 1}^{n-1}q_{j}y_{j}} \ W_{k_{1} \cdots k_{n}} (y_{1} \cdots y_{n-1}) = 0, \ \ \mbox{if} \ \ q_{j} \not\in \overline{\mathcal{V}}_{+}. \ \ (1)[/tex] Next, we would like to continue [itex]W_{k_{1}\cdots k_{n}}(y_{1}, \cdots , y_{n-1})[/itex] analytically to the complex analytic function [itex]W_{k_{1}\cdots k_{n}}(z_{1}, \cdots , z_{n-1})[/itex] in the permuted extended tube. For this we need to combine the spectrum postulate (1) with the postulate of Poincare’ covariance: [tex]U^{\dagger}(\Lambda , a) \varphi_{a}(x) U(\Lambda , a) = D_{a}{}^{b}(\Lambda) \varphi_{b} \left( (\Lambda , a)^{-1}x \right) ,[/tex] and the postulate of microcausality (the local commutation relations): [tex][\varphi_{i} (x) , \varphi_{j} (y)] = 0, \ \ \ \mbox{when} \ \ (x-y)^{2} < 0 .[/tex] The above together with the vacuum postulate allows us to prove the Reeh-Schlieder theorem. If [itex]\mathcal{H}[/itex] has a positive-definite inner product, then the vacuum postulate can be replaced by the irreducibility of the field algebra [itex]\mathcal{A}[/itex]. The theorem can also be proved for Hilbert space with indefinite metric. In this case, however, the vacuum postulate is no longer equivalent to the irreducibility of [itex]\mathcal{A}[/itex].
Likes bhobba, dextercioby and Peter Morgan
The Reeh-Schlieder theorem says that you can reach all states by repeated application of local operators to the vacuum. However, it doesn't say anything about locality, because there is no physical process that is modeled by an application of a local operator to the state. All physical processes are modeled by unitary evolution or projection and both these operations respect locality. The Reeh-Schlieder theorem is just a mathematical fact about the cyclicity of the vacuum state with respect to local algebras.
Likes dextercioby and Peter Morgan
The completeness of the algebra of operators generated by a Wightman operator-valued distribution ##\hat\phi(x)## means that we can construct the vacuum projection operator ##|0\rangle\langle 0|## (the spectrum is ##\{0,1\}##, so this is in ##\mathcal{B(H)}##, although I've never seen an explicit construction). This is a projection but it's definitely not a local operator.
We also know, however, that no operator in a local algebra ##\mathcal{A(O)}## annihilates any given state with bounded energy (Haag LQP, Ch. II, Theorem 5.3.2), which the vacuum projection operator does, so although Reeh-Schlieder proves that all states in the Hilbert space ##\mathcal{H}## can be approximated by the action of a local algebra ##\mathcal{A(O)}## on the vacuum state, not all operators in ##\mathcal{B(H)}## can be approximated by operators in ##\mathcal{A(O)}##.
I think your claim, @rubi, that "physical processes are modeled by unitary evolution or projection" would be better stated as "physical processes are modeled by unitary evolution or local projections".
A separate difficulty, however, is that unitary evolution is not local insofar as the generators of time-like translations do not commute with ##\mathcal{A(O)}##; one uses in quantum field theory not advanced or retarded propagators, but instead the time-ordered Wightman function of the free scalar field (where we can state something concrete) is the Feynman propagator, a Greens function corresponding to different boundary conditions, so that it does not respect locality quite so much (which comes down to analyticity again). Of course there are cases when boundary conditions are such that classical physics also uses noncausal propagators, so this is not anything new to QFT.
Likes Demystifier
How is this relevant to my comment? I never claimed that you can approximate ##\mathcal B(\mathcal H)## by local operators.
That's just a special case of my "claim", which is not really a claim but rather an axiom of quantum mechanics.
That would not make any sense, because that would mean that ##\mathcal A(\mathcal O)## were conserved quantities, i.e. the fields were not dynamical. The relation between the field algebra and the Poincare group (and hence time evolution) is made precise by one of the Wightman axioms, which just says that the fields transform appropriately under Poincare transformations (see samalkhaiats post). Nothing is non-local about this transformation behaviour. It's the same as in classical field theory. If the fields did commute with ##H##, then this transformation behaviour would be spoiled.
Likes dextercioby
"physical processes are modeled by unitary evolution or local projections" is a restriction of "physical processes are modeled by unitary evolution or projection". Not all projections "respect locality", only local projections "respect locality". I take it that the vacuum projection operator is a counterexample to "[all] projections respect locality".
Granted that it's not a "claim"; I think I would call it an "empirical principle", though "axiom" will do well enough.
rubi said:
The relation between the field algebra and the Poincaré group (and hence time evolution) is made precise by one of the Wightman axioms, which just says that the fields transform appropriately under Poincaré transformations (see samalkhaiats post). Nothing is non-local about this transformation behaviour.
The other aspect of the relation between the field algebra and the Poincaré group is the spectrum condition, which has consequences for analyticity and for locality.
That doesn't make it less true. Physical processes are modeled by unitary evolution or projections. There was no need to be more precise, because my argument was just that that the repeated application of local operators doesn't model any physical process and hence the Reeh-Schlieder theorem is consistent with locality.
The spectrum condition isn't concerned with the field algebra, but only with the the spectra of the Poincare generators (more specifically the translations), independent of the field algebra. It has no negative consequences for locality either.
This indeed is an argument that QFT physics is local, but it doesn't convince me that QFT mathematics is local.
  • #31
In what way would "mathematics" be local?
  • #32
I too don't know what you mean by "mathematics is local", but you can also perform similar non-local mathematical operations in classical relativistic field theory. For instance, take a field configuration with compact support, compute the Fourier transform, multiply that by some function with compact support and then compute the inverse Fourier transform. You will get a field configuration with support everywhere. I wouldn't call that "non-local mathematics" and I don't think it is problematic.
  • #33
In this context, math would be local if all operators (not only unitary ones) with support in A would (by acting on vacuum) create states that empirically differ from vacuum only in A.
  • #34
Is [itex]\mathcal{L}_{int} = J^{\mu}(x)A_{\mu}(x)[/itex] “local or global mathematics”, whatever that means?
Look, the best way to look at the Reeh-Schlieder theorem is to understand it as a NO-GO theorem in relativistic QFT: If you encounter equation of the form [itex]\hat{O}|\Omega \rangle = 0[/itex], where [itex]\hat{O}[/itex] is a self-adjoint operator on [itex]\mathcal{H}[/itex], then the theorem tells you that either [itex]\hat{O} = 0[/itex] or else [itex]\hat{O} \not\in \mathcal{A}(\mathcal{O})[/itex], i.e., the observable [itex]\hat{O}[/itex] is not a local observable. For example: since the number operator in relativistic QFT can annihilate the vacuum state [itex]|\Omega \rangle[/itex], the theorem tells you that there is no local number operator in relativistic QFT.
Likes bhobba, Demystifier, strangerep and 1 other person
  • #35
That's very illuminating, so let us continue in the same spirit.
How about the charge current operator ##J^{\mu}(x)##? It also annihilates the vacuum. Would you say that ##J^{\mu}(x)## is also nonlocal? It is built from the field operator ##\psi(x)## as ##J^{\mu}=\,:\!\bar{\psi}\gamma^{\mu}\psi\!:## . Does it mean that ##\psi(x)## is also nonlocal? Or perhaps the nonlocality is in the normal ordering ##:\; :##?
  • Quantum Interpretations and Foundations
10K
11K
18K
