Is there a limit to how small distance can be?
  • Thread starter eehiram
In summary, the conversation begins with a discussion about the smallest amount of distance an object can move. The concept of space being continuous or having discrete increments is brought up, as well as the idea of objects vibrating at Absolute 0. The uncertainty principle is mentioned and its application to determining an object's position before it turns into a black hole. The conversation then shifts to discussing the minimum length in quantum gravity and the potential existence of a grid-like structure in space. The topic of loop quantum gravity is also brought up. The conversation concludes with questions about how string theory and branes move in 10 dimensions and the possibility of a minimum amount of space affecting quantum gravity.
eehiram
116
My friend and I stayed up one night when we were in junior high school, and we were discussing science, and he asked me if I knew if there was a smallest amount of distance that an object could move.
I was really into computer graphics (1980s-90s), so I said space might be continuous, or there might be increments (like pixels or quanta) that objects use to move in little jumps, if you will.
Later I pointed out that most small constituents are vibrating anway, and only slow to a stop at a temperature of Absolute 0. However, this is sort of an aside answer, not a real answer to the stated question.
Anyone know or care to offer their thoughts? I hope this is not another overly used thread topic...
Try googling on the Heisenberg uncertainty principle.
Here is a little homework, using the uncertainty principle calculate how strongly you can localize an object before it turns into a black hole.
In response to the uncertainty principle response: what if the moving object is macroscopic and not a single particle? Would there still be uncertainty in its position and momentum when trying to determine the continuity of its motion?
f-h: I did some quick Internet research and came across a paper with the sentence: It is commonly believed that quantum gravity implies the existence of a minimum length [7]. This is in the third paragraph after the abstract on http://www.iop.org/EJ/article/0264-9381/20/15/101/q315l1.html" .
Am I getting warmer? From the article I gleaned that the minimum length delta x sub min = 2 (alpha')(Planck's length).
However, this alone does not clear up for me enough whether or not motion is continuous and whether we live on a grid, like graph paper, of space.
Planck's length 1
..------------- (dots are simply placeholders)
Planck's length 2
Above, we can see that there is still locations in between two points a Planck's length apart.
Just do the calculation yourself it's straightforward high school algebra!
As for the second part of your question I think the question is insufficiently precise to have a well defined answer.
For example: Basic quantummechanics says a particle can have spin up or down, but it can "move" between these states continuously in some sense (the expectation value can). Now in a theory of QG spacetime intervals required for operationally defining velocities should be QM measurements. How to correctly interpret these is a subtle and open question in general.
But it does make for a great ATM argument. Shifting states instantaneously looks a lot like spooky action at a distance - assuming you make a few bold assumptions.
Although I don't know the value of alpha', I can see that it is on the scale of a Planck's length. Isn't that the length of a string? Therefore, how does motion occur, one string length at a time?
I should have entitled the thread: "Is there a shortest distance for motion?"
I talked to my friend again over the phone just now. He said his question had to do with something he read in Discover magazine back in the 1980s or early 1990s about the smallest amount of volume that space can be. He read something about loops and some sort of loop theory of space, and he wasn't sure what was outside the individual loop (inbetween loops, I suppose) -- as it would not be space, one would infer.
He also mentioned Xeno's paradoxes, on which I had posted in the Philosophy forum already.
Any thoughts on this?
o| Hiram
This is Loop Quantum Gravity, please use the search function on the forum and you will find a wealth of information on this.
eehiram said:
My friend and I stayed up one night...
Oops, I thought you we`re going in a different direction.
If you start talking about strings and branes, it is perhaps difficult to visualise what is going on in 10 dimensions, let alone "distance" they propagate. I don't really know how to properly answer your original question. But I can make these remarks: Physics as we know it is only good up to a certain point; in terms of length/energy scale, Planck length is the limit, and that's why we need a new theory... string theory is one of them. Strings and branes propagate and move on the Worldsheet and how would that correspond to physical movement in 3+1 dimensions... can be a bit tricky to visualise. I am sure a string expert can answer that much better than I can.
msjd et al.: Thanks for a valiant effort. I had read 10 chapters from The Elegant Universe and I didn't know how the Planck's length applied to the smallest increment of motion of a meter-or-so sized body. I guess it would be difficult to verify anyway.
Keep in mind the HUP limits our ability to measure, it does not forbid the universe from acting on scales beyond the reach of our instruments. From a scientific viewpoint, actions beyond observational limits complicate our efforts to do 'science'. That does not mean they are impossible, or necessarily irrelevant. We have taken some leaps of faith in cosmology that incorporate unobserved aspects of the universe into theory - e.g., dark matter. If DM resides in hidden dimensions, as suggested by ST, we may never be able to detect it by means other than gravitational effects.
-The question is, if there is a minimum amount of space then why can't we have Quantum Gravity??, since the Feynman Path-integrals would become just ordinary multi-dimensional integrals that could be evaluated by Numerical methods to calculate propagators without recalling to (divergent) perturbation theory.
-Another Question is how do you define 'Geommetry' in a discrete space-time?, since Riemann only worked with continuous surfaces so [tex] g_{ab}dx^{a}dx^{b} [/tex] were just the line element, although they have mentioned uncertainty principle to show that there's a minimum distance (could anyone provide the demonstration please??) i think this fact should come up from the theory when 'Quantizying' the surface.
-It really surprises me (not in bad sense) how this question arose to 'eehiram' and his friend using computers ,since there's hardly a connection between informatics (in classical sense) and Gravity, ain't this amazing??
Your argument is fascinating. I'm curious why you think Riemann failed to consider, or mention this potential flaw in his argument.
Doesn't HUP and QM intrigue you >.< Apparently stars that we can't see are in a superposition of states where it is in nuclear fusion and where it isn't >.< When Observed HUP applies and that's why the Sun can do it...
I have no idea what you are talking about. Were I a mod, this thread would be locked.
1. Is there really a smallest distance in the universe?
Yes, according to our current understanding of physics, there is a smallest distance known as the Planck length. It is approximately 1.616 x 10^-35 meters, and it is the smallest length that can be measured or defined.
2. How was the Planck length discovered?
The Planck length was first proposed by the German physicist Max Planck in 1899 as part of his work on quantum mechanics. It was later confirmed by modern theories such as general relativity and quantum field theory.
3. Can we ever reach or observe distances smaller than the Planck length?
No, the Planck length is considered the smallest meaningful unit of measurement, and it is currently impossible to reach or observe distances smaller than it. This is due to the limitations of our current technology and the laws of physics.
4. Is the Planck length the same everywhere in the universe?
Yes, the Planck length is a fundamental constant of nature, and it is believed to be the same everywhere in the universe. It does not change based on location or time.
5. Why is it important to know about the Planck length?
The Planck length is important in understanding the fundamental laws of physics and the behavior of matter at extremely small scales. It also plays a crucial role in theories of quantum gravity and the search for a unified theory of physics.
  • Astronomy and Astrophysics
  • Thermodynamics
9K
  • Other Physics Topics
