Is there any way to calculate this integral?
In summary, the theory is that if you change the form of the parameter σ to implicit form, then you need to know how to convert between the two forms. However, the theory does not explain what the symbols mean or how to use them.
Rafa Ariza
Moved from a technical forum, so homework template missing
I have done it by the parametric form of σ, but if I change σ to implicit form that is G(x,y,z)=x^2+y*2+z^2-R^2=0 I don't know how continue.
The theory is:
where Rxy is the projection of σ in plane xy so it's the circumference x^2+y^2=R^2
Hello Rafa, :welcome:
Maybe the problem statement is correct, but you don't tell what you are actually doing (parametric form of ##\sigma## ?)
Maybe the theory is correct, but you don't explain all the symbols, so to me it's of no practical use.
In the past I learned to change to spherical coordinates for something like this and if I do that here I have no problem coming up with the answwer. How about you ?
[edit] Oh, and: for homework you should post in the homework forum and use the template there.
Thanks,
I want to calculate this integer but σ:x^2+y^2+z^2-R^2=0
The theory is:
You can do the integral in spherical polar coordinates. http://hyperphysics.phy-astr.gsu.edu/hbase/sphc.html
Write x and y and also the surface element in the spherical coordinates.
PF requires you to do something too. You said you had done it
Show your work
[edit] on a friendlier note (for a first-time poster:smile:): is there something in the link ehild gave that you don't understand ? Do you know what you need from there ?
Show your work
here is my problem but in the other form is resolved yet
And what does the theory say about z on ##R_{xy}## ?
Rxy is the projection of S in the plane xy.
So ##
R_{xy}## is a quarter circle (not just the circumference).
But ##z=0## in the plane xy, so what do you do with that ##R\over z## ? Where does this theoretical formula come from ? Is it applicable ?
Would you be interested to follow the path ehild and I learned long ago and proposed here in #2 and #3 ?
BvU said:
So ##
yes i am interested. here is the resolution by put the sphere in parametric form r(u,v)
my problem is to resolve it with surface in this form: G(x,y,z)=x^2+y^2+z^2-R^2=0
the theory is
or equivalent
or
the real problem is in the f(x,y,z(x,y)) or the other equivalent
Excellent work.
So -- if the theory is correct and applicable -- we (or rather, your helpers) are back to understanding what is needed for the alternative route.
What is meant with ##\left | dG\over dz\right |## in the formula ?
Does it perhaps mean you need to evaluate this factor in the numerator at ##z= \sqrt{R^2 - (x^2+y^2)\,}\ ## ?
[edit] oopsed & fixed.
BvU said:
Excellent work.
I will try it, thanks!
BvU said:
Excellent work.
but ##x²+y²=R²## so ##z= \sqrt{R^2 - (x^2+y^2)\,}=0##
this way of solve it is so difficult
No. That is on the rim of the circle, not in the interior. The projection of S on the xy plane is the whole quarter circle, not just the edge.
could you write it ?
So your bounds are e.g. 0-1 for x, 0-##\sqrt{1-x^2\,}## for y
o-R for x right?
Yes. You can work R out of the integral and forget about the R4 -- it's just a scale factor.
re x, y bounds:
But here too there are more suitable coordinates to be chosen
re x, y bounds:
so difficult.. i don't know
Come on... it looks simple enough now:$$\iint xy\ {R\over \sqrt{R^2-(x^2+y^2)\,}} \ dx dy$$
$$R\iint {xy\over \sqrt{R^2-(x^2+y^2)\,}} \ dx dy=\int {r³\over \sqrt {R²-r²\,}} \ dr...$$
My mistake. #23 is correct, though.
Polar coordinates: ##\displaystyle{\int_0^R \int_0^{\pi\over 2}... dr\;d\phi}##
i edit it
##\displaystyle{\int_0^R {r³\over \sqrt{R²-r²}\,}\int_0^{\pi\over 2}{\sin \phi\cos \phi}\ dr\;d\phi}## ?
Why the question marks ? The ##d\phi## part we've seen already. To be honest, I have to look up the ##dr## part :rolleyes:. How about you ?
YESSSS DONE! THANKS MEN AWESOME
You are welcome. Not bad for a first thread !
Likes SammyS
  • #31
it was awesome, really love maths
1. Can this integral be solved analytically?
It depends on the specific integral in question. Some integrals can be solved using known mathematical formulas or techniques, while others may require numerical methods.
2. What is the best method for calculating this integral?
The best method for calculating an integral depends on the complexity of the integral and the desired level of accuracy. Some common methods include substitution, integration by parts, and numerical integration.
3. Is there a software or tool that can calculate this integral for me?
Yes, there are many software programs and online tools available for calculating integrals. Some popular options include WolframAlpha, MATLAB, and Microsoft Excel.
4. Can I use the definite integral to find the area under a curve?
Yes, the definite integral can be used to find the area under a curve. This is known as the fundamental theorem of calculus.
5. How can I check if my calculated answer is correct?
You can check your calculated answer by using a different method to solve the integral or by using a software or tool to verify the result. Additionally, you can estimate the integral using numerical methods and compare the results.
