Is This Equation a Valid Definition for Set A?
  • Thread starter transphenomen
  • Tags
    Set
In summary, the conversation discusses the issue of defining a set with the equation A={x|x is in A}. It is pointed out that this definition is not sufficient as it does not uniquely determine A. The conversation also mentions the need for a more interesting axiom of existence to define an interesting set.
transphenomen
52
Or is it too circular?
[tex]
A = {x | x \in A}
[/tex]
I take it that you mean [tex]A=\{x~\vert~x\in A\}[/tex]. This is not a good definition of a set, since it does not determine A. The problem is that every set will be a possible A. I.e. every set A willl satisfy
Thus you have not determined A uniquely, this means that this is not a good definition of a set.
A={x|x is in A} iff {[for all u(u is in A iff u is in A) and A is set]or[There is no set B such that for all u(u is in B iff u is in B) and A=the empty set]}
Since the right side of the Iff is true by virtue of the tautology, x is in A iff x is in A, A={x|x is in A} is a valid but "uninteresting" definition, i.e. to define an interesting A, we must define A elsewhere with a more "interesting" axiom of existence.
To phrase it in different terms, claiming your equation as an implicit definition of A doesn't work, because the equation has more than one solution for A.
I would say that this equation is not a valid definition for Set A. It is too circular and does not provide any meaningful information about the set itself. A valid definition for a set should clearly and concisely describe the elements that belong to the set, rather than just stating that the elements belong to the set itself. Additionally, the use of the same variable (A) on both sides of the equation can lead to confusion and is not a standard practice in mathematics. In order for this equation to be a valid definition, it would need to be more specific and provide a clear understanding of what elements are included in Set A.
What does it mean for a set to be valid?
A valid set is a collection of distinct elements that follow the rules of set theory. This means that each element in the set must be unique and the order of the elements does not matter. Additionally, there should be no duplicates or repetitions within the set.
How do I know if a set is valid?
To determine if a set is valid, you can check if it follows the rules of set theory. This includes making sure there are no duplicate elements, the order of elements does not matter, and all elements are distinct. You can also use set notation to represent the set and check if it follows the correct format.
Can a set be partially valid?
No, a set is either valid or invalid. If a set does not follow the rules of set theory, it is considered invalid. This means that there are either duplicate elements, the order of elements matters, or there are repetitions within the set.
Why is it important for a set to be valid?
A valid set is important because it allows for accurate and consistent representation of data. Sets are commonly used in mathematics and science to organize and analyze data, and having a valid set ensures that the data is represented correctly and can be used for further calculations and analysis.
Can a set be changed from invalid to valid?
Yes, a set that is initially invalid can be changed to become valid. This can be done by removing any duplicate elements, ensuring the order of elements does not matter, and making sure all elements are distinct. It is important to note that changing a set from invalid to valid may alter the data and should be done carefully.
