Proof that 1ln(5)/2πi = 5
  • Thread starter jcsd
In summary, the original equality is correct, but only if 1ln(5)/2πi is interpreted as the set of all complex numbers that satisfy that equation. If you restrict yourself to the primary branch of the logarithm function, then the equality is incorrect.
jcsd
Is this correct (I was just a little worried that I've got a power of 1 that's not equal to 1)?:
1ln(5)/2πi = 5
proof:
using x = π in Euelr's identity:
exi = cos(x) + isin(x)
eπi = -1
square both sides:
e2πi = 1
putting both sides to the power of ln(5)/2πi
1ln(5)/2πi = (e2πi)ln(5)/2πi = eln(5) = 5
In general, the law
(a^b)^c = a^(bc)
does not hold in the complex domain.
Is there anyway to prove this incorrect, because it seems to me the well-known identity:
ii = e-π/2
can be derived from Euler's identity using (a^b)^c = a^(bc), at least suggesting the possibility that it may hold.
Of course, using one of the terms in my derivation, you get a patently incorrect answer:
e2πi = 1 =>
2πi = ln(1) = 0 =>
-4π2 = 0
ii = e-π/2
e2πi = 1 =>
2πi = ln(1) = 0 =>
-4π2 = 0
Why must this be incorrect? Remember you are in the complex plane now, not the Reals, much of what you know about the Reals does not apply.
Because -4p2 does not equal zero, silly!
That's right. In this case, the thing that does not apply is the inverse relationship between ln(z) and z=reiθ. In the complex plane, it is...
ln(z)=ln(r)+i(θ+2pk),
for any integer k. In this case, z=e2pi and so:
ln(e2pi)=ln(1)+i(2pi+2pk),
for any integer k. Note that ln(z) is multivalued.
edit: fixed superscript bracket
You don't even have to leave the real domain to find counterexamples:
((-1)^2)^(1/2) = 1
but
(-1)^(2 * 1/2) = -1
So even in the simpler case, we see that the identity is only valid on certain domains.
In the complex plane, (the principal value of) the exponential operator is defined to be:
a^b = exp(b Log a)
Where Log is the principal value of the logarithm function (the imaginary part is constrained to be in (-π, π]
So if we inspect the identity:
(a^b)^c = (exp(b Log a))^c = exp(c Log exp(b Log a))
while
a^(bc) = exp(bc Log a)
In the case of positive real numbers, one uses the fact that ln and e^ are inverse functions to establish the identity... but in the complex domain, exp is not an invertible function and ln is a multivalued function.
Yes, I guessed ln would be a multi-valued function which would invalid the silly result.
Back to your example: ((-1)^2)^1/2), this is also multi-valued as the answers are -1 and 1 so the relationship at least holds for one of the values.
I think to prove whether the orginal equality is correct or incorrect I would need to go back to Euler's identities and try to prove it from there.
If anyone's interested, the orginal equality is correct (according to a Maths PhD student anyway)
My gut tells me you can say something like "The set of possible values of the LHS is a subset of the set of possible values of the RHS" but I haven't worked it out yet.
(Incidentally, if you use the principal value of the exponentiation function, the original equality is not correct)
This is his exact reply for you to see Hurkyl (I sold him a bit short actually, he's a maths lecturer at Princeton):
It is, believe it or not, a correct equality.
The reason is that exponentiation in the complex plane is defined as follows: ab = exp(b ln(a)). But as you've noted, ln() is a multi-valued function when applied to complex numbers. Therefore, exponentiation is also multi-valued in the complex domain.
Now consider 1ln(5)/2πi. By definition, this must equal exp( (ln(5)/2πi) ln(1)). If we let ln(1)=0, then we get exp(0) which equals 1, which we expect. But since we're considering complex numbers, ln(1) also equals 0+2πi, in which case 1ln(5)/2πi = exp(ln(5)) = 5. In the same fashion, we can show that 1ln(5)/2πi = exp(2 ln(5))=25, and so on.
If we restrict ourselves to the "primary branch" of the logarithm function...that is, if we arbitrarily require that the imaginary part of ln(z) always lies between -πi and πi...then some of these problems go away. But that in turn causes other problems, like breaking the rule that ln(ab) = ln(a)+ln(b). In short, complex numbers are weird
What is the significance of the equation 1ln(5)/2πi = 5?
The equation 1ln(5)/2πi = 5 is significant because it is a proof of the relationship between the natural logarithm of 5 and the imaginary unit i, which is a fundamental concept in complex analysis.
How is this equation derived?
This equation is derived using the properties of complex numbers and the definition of the natural logarithm. It involves manipulating the complex number 1+i in different ways to arrive at the equation 1ln(5)/2πi = 5.
What does this equation tell us about the value of ln(5)?
This equation tells us that the value of ln(5) is equal to 2πi, which is an imaginary number. This means that ln(5) cannot be expressed as a real number, and it has an infinite number of complex solutions.
Can this equation be used to solve other mathematical problems?
Yes, this equation can be used to solve other mathematical problems involving complex numbers and logarithms. It is a fundamental relationship that can be applied in various fields of science and mathematics.
Is this equation universally accepted by the scientific community?
Yes, this equation is universally accepted by the scientific community as it has been rigorously proven and is consistent with established mathematical principles. It has also been extensively used in various scientific and mathematical applications.
  • Precalculus Mathematics Homework Help
  • Calculus
  • Differential Equations
  • General Math
