Can Every Object Be Split Into 3 Equal Parts?
  • Thread starter bmcgann
In summary, the conversation discusses the possibility of splitting objects into three equal parts. While it may seem possible with a 60cm ruler, it becomes more challenging with a 100cm ruler. The question also arises whether this is a limitation of mathematics or if there is a way to accurately divide any object into three equal parts. The conversation also considers the idea of quantized space and how it could affect the ability to divide objects accurately.
bmcgann
Sorry for the very vague title but my brother and I had a long chat the other day and we could not come to a conclusion.
Our question was, can every object be split into 3 equal parts?
Scenario 1: If you split a 60cm ruler into 3 20cm parts you would say that yes the object is in 3 completely equal parts.
Scenario 2: Now when you try to split a 100cm ruler into 3 parts it doesn't seem possible, no matter how accurate you measure it, one part will always measure longer than the other 2 parts.
Now the question is can every physical property be split into 3 equal parts or is maths misleading us.
We imagined changing the scale of the maths involved, i.e. calling the 100cm ruler 60(whatever units), now the ruler is still the same size but maths now tells us that it can be split into 3 equal parts, but how can this be?
I know that I am talking ridiculously small distances and accurate measuring beyond imagination, but the picture in my head that all the pieces line up against the (whatever scale) and that one of the pieces is always bigger against the cm scale is really confusing! Its the same piece
So what are your opinions, are we missing something simple?
Mathematics news on Phys.org
You are able to split 60 cm equally because factoring 60 gives you 60=2x2x3x5, and dividing by 3 cancels out, leaving multiple of 2x2x5=20 as your answer, that is, pretty, whole number. If you try the same with 100 you have 100=2x2x5x5 dived by 3. Because your prime factorization of 100 clearly has no factor of 3 in it, the division of it by number 3 will not produce whole number as quotient. So youll end up with a repeating decimal, going forever, that is, 33.333... In a number system where base has a factor of 3 too, that would not be the case.
You can divide a line into N equal segments without measuring anything "exactly". All you need is a way to "copy" the same length several times. Here's one way to do it.
http://www.mathopenref.com/constdividesegment.html
The fact that one stick has markings on it that you can assign numbers to and that you can then divide those numbers without a remainder has no effect on whether either physical object can be divided into smaller pieces.
You could take either one of those rulers and erase the markings and redraw them so that the metre long stick has markings divisible by 3 and the 60cm one does not - and it will not make a whit of difference.
I agree with Dave. In fact, I don't even think you are able to split the stick of 60cm in three! You could argue: I split the stick at 20cm and 40cm. But how do you measure 20cm? You can never do it exactly! You always have a degree of uncertainty.
In fact, if space were quantized, then you would never be able to split it exactly!
Also, (as Dave noticed): what if I had another measuring scale where the stick of 60cm now measures 100 units. Could you then split the stick?
1. Can every object be split into 3 equal parts?
No, not every object can be split into 3 equal parts. It depends on the size, shape, and material of the object. Some objects may be too small or too irregularly shaped to be split into exactly 3 equal parts.
2. What is the significance of splitting an object into 3 equal parts?
The significance of splitting an object into 3 equal parts varies depending on the context. In mathematics, it may be used to demonstrate the concept of equal parts or fractions. In manufacturing, it may be necessary for creating precise measurements or for dividing resources equally among a group of people.
3. Is it possible to split an object into 3 equal parts without measuring?
It is unlikely to be able to split an object into 3 equal parts without measuring in some way. Even if the object appears to be visually divided into thirds, it is important to measure and confirm the exact measurements to ensure equal parts.
4. Are there any objects that are specifically designed to be split into 3 equal parts?
There are no objects that are specifically designed to be split into 3 equal parts. However, there are objects that can be easily divided into 3 equal parts, such as a bar of chocolate or a pizza.
5. How can I split an object into 3 equal parts?
To split an object into 3 equal parts, you will need to measure the object and divide the measurements by 3 to determine the exact length, width, or volume of each part. You can then use a ruler, knife, or other tools to carefully divide the object into equal parts.
  • Quantum Interpretations and Foundations
  • General Math
  • General Math
