Is Time Compression possible?
In summary, time compression is the opposite of time dilation. It is possible to have time compression by going on a rocket trip into deep space, as far away from any gravity wells as you can get.
Michio Cuckoo
84
Time Compression - the opposite of Time Dilation.
Similar to Lorentz Length Expansion
Ignoring gravity, in an inertial reference frame, stationary clocks tick at the same rate as the coordinate clocks. Moving clocks tick slower than the coordinate clocks. The faster they move the slower they tick. So in an inertial reference frame, clocks can only experience time dilation.
This means that any inertial clock will observe all other clocks to be ticking at its same rate (if there is no relative motion between them) or ticking slower than its rate (if there is relative motion).
However, a non inertial clock can observe other clocks to be ticking faster than its rate. A simple example is a clock that is traveling in a circular path. Its time will be slowed down compared to any coordinate clock which means that it will observe those clocks to be ticking faster than it own rate.
It's only when you have two inertial clocks that they each see the other one as ticking slower than their own.
Does this make sense to you?
As in the resolution to the Twin's Paradox ... it's how the traveling twin ends up younger.
Lets add one important clarification/assumption. I'll assume that you want one observer to be on the Earth, and a second observer to start and end co-located with the Earth observer, but to experience more time on their wristwatch than the Earth observer experiences.
With this assumption about what you're asking, you can get an inisgnificant amounts of "time compression" by going on a rocket trip into deep space, as far away from any gravity wells as you can get. Insignificant being time compression by a factor of 1.00000001
In theory you might get larger time compression if you could find a large enough quantity of exotic matter and use it to create a sufficiently steep gravity "hill" (the opposite of a well). It's unclear if such exotic matter actually exists in the real universe, though, and especially unclear if it exists in a form usable to create time-compression.
Here is a version of the "travelling twin" ageing more, without using gravity. The stay at home twin remains at the rear of Rindler rocket while the traveling twin is launched towards the nose of the rocket. The traveling twin is inertial in this case (after launch) and turns around when he reaches apogee near the nose of the rocket and free falls back to the rear. Upon his return the traveling twin will have aged more than the twin that remained at the rear of the rocket.
So...it IS POSSIBLE. Just depends on your frame of reference.
But this is weird, now we need to figure out exactly when Time Dilation or Compression would occur.
If Time Compression is possible, is Length Expansion also possible?
1. Can time really be compressed?
There is currently no scientific evidence or theoretical framework that supports the idea of time compression. While time dilation has been observed in certain situations such as near black holes, there is no indication that time can be compressed in the same way.
2. Is time compression a real phenomenon or just a concept?
Time compression is currently considered to be a concept or theory, rather than a proven phenomenon. It has been explored in science fiction and speculation, but there is no concrete evidence to support its existence.
3. How would time compression be possible?
There are several theories and ideas about how time compression could potentially work, but none have been scientifically proven. Some propose that manipulating the fabric of space-time or using advanced technology could allow for compression of time, but these are currently only speculations.
4. Could time compression have negative effects?
Since time compression is currently only a concept, it is impossible to say for certain what potential effects it may have. However, some theories suggest that altering the flow of time could have unforeseen consequences and disrupt the natural order of the universe.
5. Is there any research being done on time compression?
While there is no current scientific research being conducted specifically on time compression, there are ongoing studies and experiments related to time dilation, which is a related concept. However, these studies are primarily focused on understanding the fundamental nature of space and time, rather than achieving time compression.
