Is x! even possible?
  • Thread starter Elihu5991
I have been given a problem to make a problem for x!. The only restriction is, "But omit odd numbers given x is even"
Another is for x! is, "Omit even numbers, x is divisible by 3".
Is it even possible? I've thought of several manners, but I don't think I'm correct.
Thanks in advance, everyone.
Answers and Replies
Simon Bridge
17,874
1,657
What do you mean "make a problem"? Are you supposed to design a math question?
If I don't know your intended result I cannot help you. How would you know if you are "correct"?
note, if n is a positive integer, then xn=2n-1 is an odd number.
Does that help?
pwsnafu
85
What do you mean "make a problem"? Is that a typo?
I think what you are asking for is a formula for, say,
[tex]1 \cdot 3 \cdot 5 \cdot 7 \cdot 9[/tex]
Okay, start with 9!
How do you construct the product above from 9 factorial?
HallsofIvy
41,847
969
those are sometimes denoted (x)!!. If x is even it is x(x- 2)(x- 4)...(4)(2). If x is odd, it is x(x- 2)(x- 4)...(3)(1).
Note that is x is even, say x= 2n, then we have (2n)(2n-2)(2n- 4)... (4)(2)= (2)(n)(2)(n-1)(2)(n- 2)...(2)(2)(2)(1)= n(n-1)(n-2)...(2)(1) times a power of 2.
Thankyou so much everyone! This problem was a while back. I have had problems accessing this forum, that's why I haven't replied in a long time.
If I can remember what was the problem (I don't normally forget things), as it may have been a typo, then I can reiterate the issue. I still want it solved, but till then, thanks.
Simon Bridge
17,874
1,657
omit even means only odd numbers: 1,3,5,7,9,11,13,15,17
but only divisible by three means that 1,5,7,11,13,17... are not allowed; which leaves: 3, 9, 15, ... which is 3(1,3,5,...) ...
i.e. it is another way of asking for the product of odd-integer multiples of three.
So-
If x is an odd-integer multiple of 3, then the product of odd-integer multiples of 3 up to x is given by:[tex] 3\prod_{n=1}^{x/3}(2n-1) = 3\left ( \frac{x}{3} \right )!![/tex]... isn't it?
This sort of word problem is an exercise in curly thinking.
Related Threads on Is x! even possible?
  • Last Post
  • Last Post
  • Last Post
  • Last Post
