Is xxz model integrable?
  • Thread starter wdlang
  • Tags
    Model
In summary, an integrable model in physics is a system that can be solved exactly due to its conserved quantities. The integrability of a model is determined by its number of conserved quantities, often found through symmetries. The XXZ model is not always integrable, but integrable models have significant implications in various fields. Integrable models can also be generalized to higher dimensions, although not all models can be easily extended.
wdlang
307
consider a spin 1/2 xxz model
is it integrable?
See Cambiaggio et al, Nuclear Physics A vol 624 p 157-67 (1997)
1. What is an integrable model in physics?
An integrable model in physics is a system that can be solved exactly, meaning all of its properties and behaviors can be calculated without approximation. This is possible because integrable models have a sufficient number of conserved quantities, such as energy and momentum, which allows for their exact solutions.
2. How is the integrability of a model determined?
The integrability of a model is determined by its ability to possess an infinite number of conserved quantities. These conserved quantities are often found through symmetries in the model, such as time translation symmetry or rotational symmetry. If a model has enough symmetries to yield an infinite number of conserved quantities, it is considered integrable.
3. Is the XXZ model integrable in all cases?
No, the XXZ model is not integrable in all cases. It is integrable for certain values of its parameters, such as when the anisotropy parameter is equal to 1. However, for other values of the parameters, the XXZ model is not integrable and its exact solution cannot be found.
4. What are the implications of a model being integrable?
The implications of a model being integrable are significant. Integrable models allow for exact solutions, which can provide deeper insights into the behavior of the system. They also have important applications in fields such as statistical mechanics, quantum mechanics, and condensed matter physics.
5. Can integrable models be generalized to higher dimensions?
Yes, integrable models can be generalized to higher dimensions. In fact, some integrable models, such as the Ising model and the Heisenberg model, have been successfully generalized to higher dimensions. However, not all integrable models can be easily extended to higher dimensions and further research is needed to understand the behavior of these models in higher dimensions.
  • Quantum Physics
  • Quantum Physics
