Homework Help: Ising Model issue
  1. Dec 6, 2009 #1
    I'm trying to program the 2D Ising model with Java, but for some reason, I cannot get magnetization to come out right. The energy and magnetization appear to be acting right for increase and decrease in temperatures, but I don't see anything significant at a critical temperature when I set it to one. It seems to be just like any other temperature in terms of how it effects it.
    2. Relevant equations
    The change in magnetization if a spin is flipped would be
    M2 = M1 - 2 * flippedspin
    Right?
    3. The attempt at a solution
    Code (Text):
     * ising.Ising2D.java
    package ising;
    import java.util.*;
    import java.io.*;
    public class Ising2D
        public static final int DEFAULT_LATTICE[][] = new int[5][5];
        public static final double DEFAULT_INTERACTION_STRENGTH = 1.0;
        public static final double DEFAULT_EXTERNAL_FIELD = 0.0;
        public static final String OUTPUT_FILE = "C:/spins.txt";
        PrintWriter outputStream = null;
        Scanner reader = null;
        Random random = new Random();
        int spinLattice[][] = DEFAULT_LATTICE;
        double interactionStrength = DEFAULT_INTERACTION_STRENGTH;
        double externalField = DEFAULT_EXTERNAL_FIELD;
        double temperature = 1.0;
        double energy = 0.0;
        double magnetization = 0.0;
        double averageEnergy = 0.0;
        double averageMagnetization = 0.0;
        double totalAverageE = 0.0;
        double totalAverageM = 0.0;
         * Creates a new instance of Ising2D that takes in
         * the lattice rows, columns, interaction strength,
         * external field value, temperature, and spin pattern.
         * Then it runs through 5 000 flips 100 000 times to
         * come up with a total average energy and magnetization
         * @param rowsIn the rows to set spinLattice to
         * @param columnsIn the colums to set spinLattice to
         * @param interactionStrengthIn the interaction strength to use
         * @param externalFieldIn the external field value to use
        Ising2D(int rowsIn, int columnsIn, double interactionStrengthIn,
                double externalFieldIn, double temperatureIn, int spinPattern)
            setLattice(rowsIn, columnsIn);
            interactionStrength = interactionStrengthIn;
            externalField = externalFieldIn;
            temperature = temperatureIn;
            for(int i = 0; i < 10000; i++)
                switch (spinPattern)
                    case 1: setRandomSpins(); break;
                    case 2: usePreviousSpins(); break;
                    case 3: setCheckerSpins(); break;
                    case 4: setEqualSpins(); break;
                System.out.println(magnetization / (20 * 20));
                for(int j = 0; j < 5000; j++)
                    spinFlip();
                averageEnergy = averageEnergy / (20 * 20) / (5000) / 2; // per spin
                averageMagnetization = averageMagnetization / (20 * 20) / 5000;
                totalAverageE += averageEnergy;
                totalAverageM += averageMagnetization;
                System.out.println(averageEnergy + "     " + averageMagnetization);
            totalAverageE /= 10000;
            totalAverageM /= 10000;
            System.out.println("Average E   &   Average M");
            System.out.println(totalAverageE + "    " + totalAverageM);
         * Sets spinLattice to the specified amount of rows and columns
        public void setLattice(int rowsIn, int columnsIn)
            spinLattice = new int[rowsIn][columnsIn];
         * Sums the nearest neighbors of the passed in location on the
         * array spinLattice using periodic boundary conditions.
         * @param rowIn the row to find nearest neighbors of
         * @param columnIn the column to find nearest neighbors of
         * @return the sum of nearest neighbor interactions
        public int sumNearestNeighbors(int rowIn, int columnIn)
            int sum  = 0;
            int top = rowIn - 1;
            int bottom = rowIn + 1;
            int left = columnIn - 1;
            int right = columnIn + 1;
            if(rowIn == 0)
                top = spinLattice.length - 1;
            else if(rowIn == spinLattice.length - 1)
                bottom = 0;
            if(columnIn == 0)
                left = spinLattice[0].length - 1;
            else if(columnIn == spinLattice[0].length - 1)
                right = 0;
            sum = spinLattice[top][columnIn] + spinLattice[bottom][columnIn] +
                    spinLattice[rowIn][left] + spinLattice[rowIn][right];
            return sum;
         * Sums the spin interactions with each other over the entire lattice
         * then multiplies it by their interaction strength to get the spin
         * energy sum.
         * @return the sum of the spin energy
        public double sumSpinEnergy()
            double spinEnergy = 0.0;
            for(int i = 0; i < spinLattice.length; i++)
                for(int j = 0; j < spinLattice[i].length; j++)
                    spinEnergy += spinLattice[i][j] * sumNearestNeighbors(i, j);
            spinEnergy *= -interactionStrength;
            return spinEnergy;
         * Sums the magnetization over the entire lattice.
         * @return the sum of the magnetization
        public double sumMagnetization()
            double sumOfMagnetization = 0.0;
                    sumOfMagnetization += spinLattice[i][j];
            return sumOfMagnetization;
         * Generates a random spin of either 1 or -1
         * @return a number of either 1 or -1
        public int generateRandomSpin()
            return (int)Math.pow(-1, Math.abs(random.nextInt()) % 2);
         * Uses the Monte Carlo method to flip a spin based on the change
         * of energy. If energy change < 0, flip the spin, if > 0, flip it
         * with a certain probability.
        public void spinFlip()
            int randomRow = random.nextInt(spinLattice.length);
            int randomColumn = random.nextInt(spinLattice[0].length);
            int trialSpin = -spinLattice[randomRow][randomColumn];
            double deltaEnergy = 2 * (trialSpin * interactionStrength *
                                 sumNearestNeighbors(randomRow, randomColumn)
                                 + externalField);
            if(deltaEnergy < 0 || Math.exp(-deltaEnergy / temperature)
                                               <= random.nextDouble())
                spinLattice[randomRow][randomColumn] = trialSpin;
                energy += deltaEnergy;
                magnetization -= 2 * spinLattice[randomRow][randomColumn];
                averageEnergy += energy;
                averageMagnetization += magnetization;
         * Sets the spins in spinLattice to be random 1 or -1
        public void setRandomSpins()
            try
                outputStream = new PrintWriter(OUTPUT_FILE);
            catch(FileNotFoundException e)
                System.out.println("Could not open file: " + OUTPUT_FILE);
                System.exit(0);
                    spinLattice[i][j] = 1;
                    spinLattice[i][j] *= generateRandomSpin();
                    outputStream.println(spinLattice[i][j]);
            outputStream.close();
            energy = sumSpinEnergy();
            magnetization = sumMagnetization();
            averageMagnetization = magnetization;
            averageEnergy = energy;
         * Sets up a checkerboard pattern of spins in spinLattice
        public void setCheckerSpins()
                    if(i % 2 == 0)
                        if(j % 2 == 0)
                        else
                            spinLattice[i][j] = -1;
                    else
                        if(j % 2 == 0)
                        else
            energy = sumSpinEnergy() - sumMagnetization() * externalField;
         * Sets spinLattice to use the previously recorded spins
        public void usePreviousSpins()
            try
                reader = new Scanner(new File(OUTPUT_FILE));
                System.exit(0);
            while(reader.hasNextLine())
                        spinLattice[i][j] = Integer.parseInt(reader.nextLine());
            reader.close();
         * Sets up all the spins in spinLattice to be the same, in this case, 1
        public void setEqualSpins()
    If someone knows what I'm doing wrong, I'd really appreciate the help.
Draft saved Draft deleted
