Isobaric Process
  • Thread starter traveler7
Pf
429
Q
-754
ΔU
819
The table above shows the measurements taken while an ideal gas underwent an ISOBARIC process. Fill in the appropriate values for the table below.
ΔP=?
Q= ΔU+W=ΔU=PΔV
I dont know how to go about solving this
Answers and Replies
rock.freak667
6,223
31
For an isobaric process, what is constant? Hence what is ΔP ?
vela
Staff Emeritus
Education Advisor
15,231
1,831
Do you know what isobaric means? If not, look it up.
isobaric means same pressure
but i tried 429 and that didnt work
Is the difference in pressure 0? so 0 would be delta p?
rock.freak667
6,223
31
Right so if it means the same pressure, then the final pressure and the initial pressure are the same. So the change in pressure would be 0.
vela
Staff Emeritus
Education Advisor
15,231
1,831
It sounds like you're just guessing. You need to understand that the equations have meanings and the quantities that appear in them have precise definitions. If you don't know what ΔP represents, the first thing you need to do is figure that out.
In this case, ΔP=Pf-Pi represents the change in pressure between the initial and final states, so your answer of 429 (units?) would mean that the pressure increased by that amount. Clearly, this doesn't meet the condition of an isobaric process, where the pressure is, by definition, constant. Since the pressure is constant, you know that Pi=Pf, so ΔP=0.
Related Threads on Isobaric Process
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
