Isobaric processes
  • Thread starter oftigus
Main Question or Discussion Point
Hello.I'm studying thermodynamics and i'm having trouble understanding processes where the pressure is constant.How can temperature alone modify the volume without doing pressure.An example would be appreciated.Thanks.
Answers and Replies
10,479
Usually, systems with constant pressure are at atmospheric pressure and have some way to change their volume. Look at a balloon, for example: If you heat the air inside, it will expand, while the pressure is (nearly) constant.
haruspex
Insights Author
5,467
You can also take away the balloon and use it in modelling atmospheric changes.
In an engine, you could supply heat to a chamber to drive a piston that's subject to constant external load over some part of the cycle.
Related Threads on Isobaric processes
  • Last Post
  • Last Post
