What is the working principle of an isolated induction generator?
In summary, an isolated induction generator is a self-sustaining machine that generates an AC frequency equal to the LC resonant frequency of the winding inductance with the capacitor bank. It will not start to generate until the rotation rate exceeds the speed synchronous with the LC resonant frequency. As you draw more current from the generator the slip will increase. If you draw too much current you will kill the excitation and so the system will protect itself.
nand arora
can anyone give me a detailed description of working of isolated induction generator or self excited induction generator
it has been mentioned about it in the following link in the last paragraph but no details are given
http://electricalstudy.net/lesson/poly-phase-induction-generator-or-asynchronous-generator-2/
can anyone refer me a link or book from where i can study about it in detail.
a demonstration here
Typically it's explained as "The capacitor supplies excitation current."
That's counterintuitive - a capacitor doesn't "supply" current, it allows current.
So - you already know the answer, from your studies of parallel resonance.
Excitation current is magnetizing current and that is inductive, 90 degrees behind terminal voltage.
Capacitive current is 90 degrees ahead of terminal voltage.
So if they're of equal magnitude, their sum is zero.
In a parallel resonant circuit, current circulates between inductor and capacitor.
Apply KCL to junction of L-C and you see there's hardly any external current , just enough to replenish the I2R losses.
In a lossless circuit there'd be zero external current.
In your induction generator , those losses are made up by shaft power instead of by external current.
So, with enough capacitance the machine will make its own excitation current.
Motors work the same way , so one must be careful applying power factor correction capacitors to motors. Never correct one all the way to unity .
One of many hits from a google search:
http://www.nrel.gov/docs/fy00osti/26713.pdf
it's difficut to predict which explanation will "click" with an individual, we're all different.
I find it useful to think of VARS as instantaneous real power .
Vars are instantaneous real power that flows between machine and load(or source), reversing direction every quarter cycle.
So averaged over a whole cycle VARS move no real power, hence their old name "wattles current".
But -- instant by instant, joules are moving back and forth between the magnetic field in the machine and the electric field in the capacitor.
When the balance is just right you have a self excited induction machine.
As you saw in the video.
Like any other tank circuit with an energy input, it's self sustaining
Hopefully this simple mental model will help you work through the formulas.
Fundamentally, an isolated induction generator, with a capacitor bank, generates an AC frequency equal to the LC resonant frequency of the winding inductance with the capacitor bank.
1. What is an isolated induction generator (IIG)?
An isolated induction generator (IIG) is a type of electric generator that is commonly used in small-scale power systems, such as in remote locations or for backup power. It is typically designed to operate without being connected to a larger power grid.
2. How does an isolated induction generator work?
An IIG works by using a rotating magnetic field to induce voltage in the stator windings, which are connected to the load. The rotor is not connected to any external power source, so it relies on the load to provide the necessary excitation current to maintain the magnetic field.
3. What are the advantages of using an isolated induction generator?
One of the main advantages of an IIG is its simplicity and reliability. It does not require any external power source or complex control systems, making it a cost-effective option for small-scale power systems. It is also able to operate in remote locations, where connecting to a larger power grid may not be possible.
4. What are the applications of an isolated induction generator?
IIGs are commonly used in off-grid or isolated power systems, such as in rural or remote areas, to provide electricity for small communities or individual households. They are also used as backup power sources in case of power outages or emergencies.
5. What are the potential challenges of using an isolated induction generator?
One potential challenge of using an IIG is its limited power output compared to larger generators connected to a power grid. This can limit its applications to smaller power systems. Additionally, the load must be carefully managed to ensure the proper amount of excitation current is provided to the rotor.
  • Electrical Engineering
  • Electromagnetism
